Question about LG Vu CU920 Cellular Phone
LG VU unpairs from Ford Edge with SYNC
I pair my phone with the car and almost every time I leave the car with the phone it unpairs. I had more primitive phone (2 yrs old), it never unpaired itself.
  • Anonymous Feb 25, 2009
    uncompatible !!! its crazy
Lg vu 920 does not pair with my ford sync , other set in family do only the lg vu 920
Posted on Jan 25, 2010
I have entered the wrong pass code into my lg G4 phone for pairing a nexus dsp Bluetooth sun visor car kit but it will not let me enter the correct code,
Hey Ged Gage,
Unpair the car kit, by going into the G4's bluetooth settings and then pair again... Hope that helped!
Jan 01, 2017 | LG Cell Phones
How do I connect to Ford Sync?
To use any of the phone features for SYNC such as making a call, receiving a text message, or using SYNC Services, you must first connect, or "pair" your Bluetooth-enabled phone. Pairing is what allows Bluetooth devices to communicate securely with each other.
Please note that SYNC can make and receive calls using only one paired phone at a time.
Before you start
There are a few things you should do before starting step 1:
blobserver?blobkey=id&blobwhere=1309207543643&blobcol=urldata&blobtable=mungoblobs&b=91
Turn on your
  • Mobile phone
  • Vehicle
  • Radio/SYNC
blobserver?blobkey=id&blobwhere=1309207543650&blobcol=urldata&blobtable=mungoblobs&b=91
Enable your phone's Bluetooth feature and make your phone discoverable.
Press the Phone button to access the Phone Menu. Press OK. Add a Device displays. Press OK.
SYNC prompts, "Press OK to begin pairing device." Press OK.
SYNC prompts, "Search for SYNC on your device and enter the PIN provided by SYNC." Press OK.
A six-digit number displays on the screen for three minutes, during which time SYNC actively seeks for the same number from your phone.
Type the number displayed by SYNC on your phone key pad.
Upon successful pairing, a message displays confirming the phone is connected.
Exit the phone pairing process by pressing the Arrows to select the Exit message and press OK to leave the Phone menu.
Aug 25, 2014 | Cell Phones
When I answer the phone via the sync system (blue tooth) either via the steering wheel or touching the screen, the caller hears the rigning that I hear inside the vehicle. It is ear piercing. Ford says...
Try pairing a different phone with the system and see if the problem still exists. This could be a phone issue. The Edge Sync system uses the phone for commands. It totally depends on the phone to process all requests.
If you tried a different phone with no results log into www.syncmyride.com and check to see if you have the latest software level for your Edge.
Apr 21, 2011 | 2010 Ford Edge
I am having a hard time pairing my Bluetooth to my Ford Focus 2008 to Sync. I cannot pair the phonebook. I have tried unpairing and repairing but nothing works.
hi karen dis is joahna nerry tampus i want to get dis cellphone..
manny people sending me a free cell phone in friendster..
i want to get dis..
my address is 2795 luzviminda st. timog caa laspinas city..
and im joahna nerry tampus.. i hope i get dis cell phone.. thnak you...
Aug 18, 2009 | LG Vu CU920 Cellular Phone
Can I sync my LG VU with Microsoft Outlook? If
Hi, you're right you'll need usb cable however bluetooth can be used as well.The usb cable is supplied with the phone. Vista use the new Windows Contact and Windows Calendar,but you can use MS Outlook if installed and you'll need MS IE v6.
Rate me if helped.Thanks.
Jun 18, 2009 | LG Vu CU920 Cellular Phone
LG VU does not recognize my blue tooth while trying to pair two
Help my pair my bluetooth with my LG shine phone. I have a jawbone bluetooth.
Mar 23, 2009 | LG Shine KE970 Cellular Phone
What is the default code to pair a bluetooth with a lgcu920
The Default code for my Lg Vu is 0000 so i assume it shall be the same for yours.
Jan 27, 2009 | LG Vu CU920 Cellular Phone
Lg vu pairs with xlink but connection is very bad
Try removing the device, and reconnecting it. Sometimes that helps. Good luck.
Jan 24, 2009 | LG enV VX9900 Cellular Phone
I have somewhat of a solution. when you go to www.att.com/BluetoothWizard, it will prompt you to put in the handset Make & Model and then proceed with the Make/Model of your Bluetooth. It is possible that your Bluetooth headset may not be compatible with the LG Vu.
Dec 09, 2008 | LG Vu CU920 Cellular Phone
LG VU CU920 Sync Software
You don't need software to transfer files. Here is what you need to do.
Go into your phone settings.
Click on Connection
Select USB Connection Mode
Select Mass Storage (You MUST have a 1g memory card or larger in the phone)
Connect the USB to your phone and your PC
Viola! your pc should recognize it as a mass storage device. Put files where you want them etc.
Good luck.
Aug 26, 2008 | LG Vu CU920 Cellular Phone
LG Vu CU920 Cellular Phone Logo
579 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
