Question about GE Spectra JBP78 Electric Kitchen Range
The lcd scrren on my range displays F7 in red and flashes d6 in g
My range just starting beeping for no reason at 4:00 a.m the lcd display shows F7 in red and flashes d6 in green and none of the buttons work
    President:
  • 373 Answers
The code is because of bad keypad/the control panel.Have it changed.It probably non-functional and constant beeping sound is followed as you mentioned.Theres a link to explain more about this for reference.The only solution is to replace the control panel.
http://www.askgene.com/2007/06/23/oven-error-codes/ge-oven-error-code-f7-and-how-to-fix-it/
Posted on Dec 13, 2008
Was low temp roasting of ribs in Jenn Air JMW9530AAB convection oven. Heat webt ofand stove started to beep and displayed "-F7-". Cancel failed to do anything. Shut power off and when turned...
The electronic control may not be set correctly. If the control is not programmed correctly the oven will not start and you will usually hear a series of beeps instead of the microwave starting. See your Use & Care Guide
Aug 09, 2008 | Jenn-Air Kitchen Ranges
Oven beeps and displays F7. Hit stop/cancel, starts up again in about 10 seconds
Hi cpwdavis,
The F7 failure code shows a Function key shorted or stuck. To resolve this problem, you need to replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Sep 22, 2011 | Jenn-Air JES9800A Electric Kitchen Range
Displays "F7" and a continuous
If your Maytag range displays the "F7" error code, it means that the programmed fault error 7 occurred with the range. Luckily the error is easily fixed in most cases and requires no new parts.
Identification:
Once the error appears on the range it is usually followed by seven loud beeps to represent the number. Clear the error by holding a button down for a minute. The LCD will flash and the code will disappear.
Effects:
The most common cause of the "F7" error is a stuck button on the LCD panel. Look around the range control panel and examine to see if any buttons appear pushed in, stuck or out of place.
Prevention/Solution:
Take a damp rag and light wipe around the buttons to clear out any grease, food particles or sticky substance that may have built up around the button. Attempt to use your range and see if the error appears again.
Considerations:
If the error continues to appear, there could be permanent damage to your electronic range control. Contact your Maytag dealer for warranty information and replacement parts.
Keep us updated.
May 24, 2011 | Kitchen Ranges
Oven and control panel not working for model # JS900B0K2BB. Stove top is working fine. Panel is flashing some sort of code: F7 and d6. F7 D6. Any help
Sounds like a stuck keypad. Push all pads at random several times each then try it again. If that does not work the clock will have to be replaced.
Apr 06, 2009 | GE JS900WK / JS900CK / JS900BK Electric...
Constant beeping and F7 is displayed
Hi tahitian,
The error code F7 means that the Function key is shorted or stuck. To fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Dec 16, 2008 | Magic Chef 31000 Gas Kitchen Range
F7 display
Good news
The problem was solved by disconnecting the power supply for three minutes and power up again and F7 diaper.
Thank you all
Aug 18, 2008 | GE Profile JB968 Electric Kitchen Range
Function error F7 d6
CONTACT GE and ask for their assistance .
Dec 07, 2017 | GE JGS905SEKSS Stainless Steel Gas Kitchen...
Keypad Start and Clear are the only keys that work. F7 S6, S7, SA, d6
f-7 mean stuck button on key pad or stuck relay on oven control. if the problem started while oven was in use replace oven control. if problem started while oven was not in use replace key pad
Nov 19, 2007 | GE JSP42 Electric Kitchen Range
F7 Code and stove beeps
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F7 Shorted key sensed for 32 seconds 1. Membrane shorted, or,
2.
Display board defectiveIf touch pad is a separate unit then unplug it and see if code comes back.  Unplug range before doing so.  Once touch pad is disconnected, plug range back in and see if code shows.  Wait a few minutes.  If no code then replace touch pad.  If code does come on while touch pad is disconnected then replace main control.  If touch pad and main control are all one part then replace the whole control.  Doubt if you would have any luck trying to unstick the bad button as stated above.
Oct 15, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
GE Spectra JBP78 Electric Kitchen Range Logo
620 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
