Question about Canon EF 24-70mm f/2.8L USM Lens
EF 24-70 lens droop...
My barrel zoom on my 24-70 is so loose that gravity makes the lens extend itself. Is this an easy fix?
I heard you can tighten screws under the rubber zoom ring to make the zoom less loose...
thanks for any help you can provide...
  • 36 Answers
The zoom creep is an easy fix for Canon. I really do not recommend trying to tighten it yourself, since that would void your warranty.
It is usually free to tighten the zoom ring.
/Chris
Posted on Jan 19, 2009
I bought Canon EF 75-300mm III Zoom Lens, but the len is very loose, is it problem
Long and short of it...if the photos are close to "decent", dont worry bout it :) It aint no L Lens but can still throw out a good pic every now n then. Tip it from one end to the other whilst holding it...if you hear something go \'ring-a-chicka-chink-chink-clunk\', then youve got problems, otherwise grin and bear the looseness - mine lasted 6 years of hard yacker before i dropped it in the drink!
Mar 27, 2014 | Canon 75-300mm f/4-5.6 III USM EF Lens
Very loose lens 75-300mm canon zoom
If it is loose on the camera mount, try to avoid using it. If it causes your camera mount to distort, then you won't have much luck with any other lenses!
If it is "loose" meaning: it rattles and there's a bit of play in the 'barrel'...yuuup - get used to it. She's an oldie but a goodie.
Oct 24, 2013 | Canon 75-300mm f/4-5.6 III USM EF Lens
My lens is really loose when I zoom out , how can I fix it, I have a canon ef 75mm to 300mm
There's a screw located on the barrel of the lens. This may help tighten things up, but don't count on it. Don't try to take it apart unless you know what you're doing. There are a series of sleaves within the barrel which need to match up and you might have to fork out more than the lens is worth just to get it fixed
Oct 16, 2013 | Canon 75-300mm f/4-5.6 III USM EF Lens
Hi, I have a Canon EF 75-300mm f/4-5.6 II Lens. I recently noticed that if the lens is pointing down, the zooming barrel is going to 300 by itself. Is there anything i can do to fix this? Whet it was...
Definitely do NOT open the lens!
This can cause much bigger problems like misalignment of glass etc.
Take this lens to a professional if it's causing that much of an annoyance to you.
Mar 07, 2011 | Canon EF 75-300mm f/4-5.6 II Lens
Front Extending Lens Barrel Loose on my EF 28-135 IS USM. How can I fix it DIY? how to disassembly? thank you!
To save the lens from total destruction have the repair done by those that work on this stuff professionally. If you have to ask how to do this then that tells me first you do not have the proper tools to dismantle a lens of this type or have the alignment scope to re-assemble the lens elements properly. From what you are saying here I would think that the packing needs to be replaced or at least cleaned and tightened and the lens is worth the repair. Sorry this is not a DIY job and have it survive.
Jan 17, 2011 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Hi- purchased the Extender EF 2X II; it seems fine with my fixed focus 300mm, but the auto-focus doesn't operate with my 70-200mm EF IS USM zoom, in any mode. Any suggestions? Thanks G
You haven't stated which body you have but the AF will not work with the extender if the effective lens aperture is too low (remember that a 2x extender doubles the focal length but halves the effective aperture).
Canon's own website states: "Autofocusing does not operate if the effective maximum aperture is greater than f/5.6 (greater than f/8 on the EOS 1V and EOS 3)."
Aug 01, 2010 | Canon Extender EF 2x II Lens Converter
There are 2 Canon fittings, EF for all EOS cameras and EF-S for 'crop' cameras. The Canon extender does not fit crop cameras. Whichever make you look at, make sure it will fit the type of mount you have.
If you have not yet bought your lens of choice, Sigma are good and do their own extender compatible with their own lenses but not Canon's. This may be a good option for you
Mar 07, 2010 | Canon EF 2x II Extender Lens 6846A004
Tamron 17-50 loose ZOOM ring (not Focus ring or Front Element)
the same thing just happened to me like 3 days ago. The zoom ring was kinda sticky and then all of a sudden it just spins around and doesnt extend the barrel at all.
Nov 16, 2009 | Cameras
Zoom ring is loose and drops/slides on its own
Yes, this happens even when the lens is brand new. Some other lenses have a Zoom lock to prevent it. What I did was to slip a flat rubber band around the black area just behind the zoom ring, the area where there is s white mark or line, with the band ring just touching the zoom ring. The rubber band should be fairly tight, but not too tight. When the zoom ring revolves, the rubber band touching it gives it just enough friction to prevent it from turning. You can adjust it to give as much friction as you want. Hope this helps. Jay
Oct 02, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Barrel slides
A fat rubber band tight enough to stop the barrel movement, but not so tight it restricts manual zooming is the best, extremely effective, low-tech fix for this problem - I have done it for years
Apr 20, 2008 | Canon AF EF 100-300mm f/4.5-5.6 USM Lens
Canon EF 24-70mm f/2.8L USM Lens Logo
731 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
