Mitsubishi VS-45609 TV Logo
paul burke Posted on Mar 10, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jagged horizontal blue lines everywhere
All of a sudden my tv has jagged blue horizontal lines over the entire screen. I can still the picture on the tv but these ghosting lines are drving me nuts. To fix the problem, I take an open hand and slap the side of the tv pretty firmly. The lines go away, but they come back shortly. Help !!!!!!!!
Anonymous
Level 3:
President:
  • Master 4,402 Answers
  • Posted on Jan 06, 2008
Anonymous
Master
Level 3:
President:
Answers
4402
Questions
0
Helped
1710778
Points
8129
Convergance amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
2answers
6helpful
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Vertical line picture
problem is caused by the loss of horizontal deflection signal. It is quite surprising that the entire unit is still working, since usually, a loss of H-Out will disable the entire set. Problem can be as simple as loose solder connection to a more complicated defective horizontal circuit. I would suggest havint it checked by a professional TV tech.
Horizontal Blue Line
WHEN YOU HAVE A SOLID BLUE LINE THAT DOES NOT MOVE...YOU HAVE A DEFECTIVE PANEL...LIVE WITH IT OR REPLACE PANEL..NOT COST EFFECTIVE TO REPLACE PANE....JOE ACE
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
Lcd tv
What is the make and model number of your set? I may b able to help you. desribe in more detail is the picture gone entirely and you only see colored horizontal lines on ablack screen?
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
