Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso washing machine keeps saying LD and will not complete its cycle. I have the motor replaced several time and I am hoping that it is not bad.....AGAIN.
  • jthorn_97 Dec 23, 2008
    we are having the same problem. took the bottom off and removed the hoses and the base of the pump to clean out any debri. found a dime and a penny amongst the other sludge that had built up and put the stuff back together. running a cycle on my carport now to see if it will work. from the comments of others, this seems to be a common problem.
    Scholar:
  • 48 Answers
LD - Long Drain - as when the pump is not running (jammed or clogged with debris, socks, or draw strings!) or when it has failed. Make sure, if you are having someone replace the pump motor, that they upgrade it with the redesigned motor that has the impeller and motor in a single part which cannot be separated. The original design was 2 parts and was a metal motor shaft into a plastic impeller socket that would strip when the impeller got jammed. There are several companies which sell the new design and for a small extra fee you can get a lifetime warranty on the pump assembly. Google for it.
Posted on Jun 13, 2009
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
Get alarm code ld
CI code comes on just seconds after I start the machine. The machine itself is leveled on all sides.
Dec 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer is not completeing "normal" was cycle
could be or you may have a problem with the lid switch ( Ld )
Aug 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Jul 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My Kenmore Calypso Elite HD Top Loading washer quit cycling through a complete wash today. I've drained all the water from the interior hoses and found them clean and uncloged. The washer belt looks good...
skipneal,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Check the intake and exit hoses of the recirc pump for debris. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. the hoses to the pump have spring clips holding them on. Be careful taking the hoses off, have something to catch the water from the hoses.
Hope this helps.
-samson39
Jul 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Machine shows LD even when water pump was replaced
dccvan,
OK, now that you have a new pump, look at the back ouf the unit. You will have to take off the back cover. On the back of the tub you can see where the 'check balls' are for draining & recirculation. Here's a picture: click here. It might be a little difficult to see through the plastic, but check to see if there is anything stuck inside there near the check balls. If so, you have to take the pump hoses off at the tub connections. You can use mechanical finger grabbers to get stuff out. Check this picture also: click here. If you take the hoses off, check them for debris inside. Check your drain hose to the house drain also, could be something in that hose too. Flex shaft mechanical fingers look like this: click here. you can get them at just about any autoparts store.
Hope this helps,
-samson39
Jul 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
HELP? ob & ld codes
Ld means long drain you probally have a bad water pump.Those models have a seperate motor for pump, the shaft on the motor is a star type and has probally stripped out the pump.Replace your water pump
Jan 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stops in middle of cycle,
Junk it! Cut you losses now. I had a Calypso for 6 years and went through 3 pumps, various circuit boards , a drive motor ,etc..... not to mention the down time of not having a washer in a 4 person household. We bought a Whirlpool Duet HT 9200. Clean , fresh laundry not all balled up anymore. Junk it. You'll thank me.
Nov 01, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
107 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
