Question about La Crosse Radio Controlled Atomic Clock
Ws-9520u outside temp not working
I have the WS-9520U LA CROSSE weather station and the outside temp will not read
4 Suggested Answers
SOURCE: Lost my manual and cannot manage to find the menu
I found my manual so it is up and running again. Thanks
Posted on Oct 11, 2009
homedesigner
  • 583 Answers
SOURCE: We have an atomic clock with calendar and
Press and hold the SET key for 5 seconds. Press set key repeatedly until TZ is displayed on the bottom. Use the "+" key to set the time zone. -8 is for Pacific Time Zone, it will display -8 PST in the display. Press set to go to the DST setting, and so on until you've cycled through the options.
Posted on Feb 20, 2010
Need manual for la crosse weather station model: WS - 1612 - 11
https://www.manualslib.com/manual/91064/La-Crosse-Technology-Ws-1612.html
Oct 25, 2017 | La Crosse Measuring Tools & Sensors
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
What does an OF symbol mean in the indoor temp window with no readings from the outside?
Based on a different, but similar, LaCrosse model (the WS-8611), it would appear to be an OverFlow indication, meaning that it's out of range. Here's a quote from that unit's manual:
SPECIFICATIONS:
Temperature measuring range:
Indoor : 14.2F to +139.8F with 0.2F resolution
(-9.9C to +59.9C with 0.1C resolution)
("OF.L" displayed if outside this range)
Outdoor : -39.8F to +139.8F with 0.2F resolution
(-39.9C to +59.9C with 0.1C resolution
It is likely that their convention remains the same across models, but I don't work for them, so I can't guarantee it.
Sep 25, 2014 | La Crosse LaCrosse Technology Weather...
My outside temperature and humidity sensor appears to have failed. I'd like to buy a replacement. 433 MHz. The system is WS-7395U. Please advise price. taylor.norman1@gmail.
The WS-7395U uses the La Crosse TX8U outdoor temperature and humidity sensor. That part has a $49.99 MSRP. It is $46.95 from La Crosse; see http://www.lacrossetechnology.com/tx8/index.php to order the part. Other vendors that I checked do not have the sensor in stock for sale separately.
I hope this helps.
Aug 21, 2013 | La Crosse Technology La Crosse C86234...
The sensor from my weather station is not registering outside temperature
I've had the same problem since I bought this unit 2+ years ago; when the outside temperature moves into the freezing zone, the sensor stops transmitting. I contacted Lacrosse-- all they could suggest was change the batteries. My solution: throw it in the trash!
Aug 05, 2012 | Bushnell Measuring Tools & Sensors
I need a user guide for a La Crosse WS-9211 Weather Station clock
Solved it! La Crosse let you download manuals from their website.
Nov 23, 2008 | La Crosse Technology E. Howard Ambassador...
Outside Weather Not Displaying
Restart as if from new ie as if it is being taken out of the box
Jan 25, 2008 | La Crosse Technology WS-8001-UM Digital...
La Crosse Radio Controlled Atomic Clock Logo
308 people viewed this question
Top La Crosse Home Experts
John
John
Are you a La Crosse Home Expert? Answer questions, earn points and help others
