Question about Onkyo Audio Players & Recorders
I cannot seem to get DTS-HD master to show on the receiver screen
    Problem Solver:
  • 5 Answers
You need to check 3 things:
1) DTS will only work through a digital connection (coaxial, optical, or HDMI) between your receiver and dvd player. DTS and Dolby 5.1 cannot carry a signal over red and white rca connections.
2) After number 1 is solved ensure the reciever is set to the digital channel, your DTS-HD in this case, or in an auto mode.
3) Finally the most important is that the signal is a DTS signal. Start a DTS capable dvd, go to the sound menu and set it for DTS.
Press play and all should be well...
Cheers,
NTIMID8
Posted on Dec 13, 2008
UNABLE TO POWER UP
Check for a bad fuse inside the receiver.
Jun 20, 2015 | Yamaha AVENTAGE RX-A1030 3D A/V Receiver -...
How do I get audio from tv to receiver?
There should be audio output's on your TV and cable box. There are usually multiple options on most newer model a/v equipment. If u check the manual look for the page showing you about the various connections on the back, you're lookin for anything to do with audio output, there are many different types optical, digital, and analog. Again depending on your specific equipment there's almost always at least one way you can connect them
Feb 15, 2015 | Pioneer HTP-071 5.1 3D Home Theater System...
How do I reset after overheating
It's getting to hot.
Needs a cooling fan.
Too many speakers or too high a volume.
Let it cool. Should restart.
If you unplug it,you will lose your presets.
Nov 11, 2014 | Marantz SR7008 A/V Receiver - 9.2 Channel...
Onkyo HT-S3400 not showing DTS-HD Master Audio
Hello, with the source playing press the display button on the remote. What format do you see? Thank you, CB
Apr 05, 2017 | Onkyo 5.1-Channel Home Theater Package...
I have a Yamaha RX-V663. I recently upgraded to 7.1, but the 6th and 7th speakers do not activate on DTS HD Master Audio Blu rays. The 6th and 7th speakers do activate on DTS True HD, DTS EX - ES,...
It is unclear to me as to what you mean when you say they do not activate. Does that mean that they just don't play, or does it mean that your receiver doesn't show them on the display? If your not hearing the sound from the speakers, are you sure your dvd movie is capable of outputting 7.1 or is it only 5.1?
If the receiver doesn't show the speakers on the display, try running through the speaker setup again to make sure you selected both sides and rears for the setup.
Good Luck
Jan 06, 2011 | Yamaha RX-V663 Receiver
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Oct 24, 2009 | Kenwood VR-405 Receiver
DTS Master HD audio problem
Hey! Make shure your amp and blu-ray player output and input signals are set to "bitsteam" and you are useing HDMI and optical connections. I hooked up my Onkyo tx sr 506 integrated amp to a Samsung BD 1400 player and everthing worked perfectly right out of the box. Perhaps your amp can"t decode DTS HD Master or your blue ray doesn't support it although i think a firmware upgrade may accomplish this. Put on The Chronicles of Narnia Prince Caspian which will DEFAULT to DTS HD MASTER 7.1 and see if it works. It's an excellent source to test your system. Picture and audio recieved 5 stars from Home Theatre magaziene and like i said, either your amp, or player doesn't support it or your interconnects are keeping it from coming thru. HDMI and OPTICAL connects and check your set up for "bitstream" Remember what Todd Rundgren allways said,"Everything will work if you just let it!"
Feb 05, 2009 | Yamaha RX-V663 Receiver
Not showing DTS MASTEr OR DG True HD
In the menu is an option for switching master and true hd on. Standard its of and played als normal dts/dolby.
also: check the input (blu ray?): maybe it is set to only output no high def signals, so the amlifier doest recieve hd sound..
Igor
Dec 14, 2008 | Audio Players & Recorders
No output of hd audio
Change audio settings on PS3 to PCM not bitstream
Jul 26, 2008 | Denon AVR 3808Ci Receiver
407 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
