Back pannel opperation
Im jo my 5.1 works on analog but not on digital
    Genius:
  • 1,199 Answers
You must use a digital connector and have your amp set to 5.2
Posted on Dec 13, 2008
Canon np 8530 - does it have a hard drive?
Hello Jo,
There are no NP series Canon copiers (available to the public) that have a hard drive.They are analog devices and were the "proving grounds" for the current IR and ADVANCED series devices Canon makes.
Jul 29, 2011 | Canon NP 6085 Copier
How do I set the time and how do I get a user manual.
1. set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date
2. if off sync between analog and digital clock happen. You need to resyn
step 1: follow the instruction 1 to set digital clock to 12:00.
step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync mode.
step 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.
step 4: push the pusher at 3:00 to exit the sync mode.
step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Jun 18, 2011 | ESQ 07301132 Aerodyne watch
My Sony AV unit (probably 3 yrs old) suddenly switches from all 5 channels to just the two front without warning; I can push enough buttons to return it to all 5, but sometimes it switches back and forth...
You don't name the model but if there's asettign for audtomatically selecting digital vs analog when both are attached it's losing the digital signal and automatically switching to the analog feed. Find it in the manual. lacking a setting, it prefers digital over analog and will switch to analog on digital signal loss.
Analyze what source(s) are involved and investigate WHY you're losing the bitstream. Optical cables must be run with smooth loose bends so the light strength is not compromised.
Feb 04, 2011 | Sony A/V Receiver
My computer starts fine. I have a liquidvideo E19LCD1 monitor. As soon as I open Internet Explorer 8+, the screen goes dark, the analog band comes up for about 5 seconds, then the screen comes back up for...
Internet explorer can be repared as any other program.
go to control pannel.
add remove programs or Programs and features.
choose windows components.
uncheck IE.
apply .
ok
Reboot =Yes
Goback to the same place
place check mark on the IE
apply
ok
exit control pannel.
OS DISK must be kept inserted in the Drive while doing this operation because while uninstalling and installing IE. The disk is necessary
Rate this solution. coment for more explainations.
Sep 18, 2010 | Computers & Internet
We have a radio shack mobile cb radio given to us and was wondering if it's analog or digital. the only number on the front is trc-447. does it matter if it's one or the other? also have a 29 ltd...
All CB radios on the market are analog. The term digital, when used in reference to a CB transceiver, refers only to the display, not to the type of signal.
Bill B
Aug 05, 2010 | Radio Shack Radio Communications
Box wont turn on, it is plugged in to electrical outlet worked fine last night
Try to unplug it and wait for about 5 minutes then plug it back in. If that doesnt work try a different outlet. If thats not it it may be a fuse inside of it.
Feb 15, 2010 | Insignia Digital-to-Analog Converter for...
Wife has to have wireless headphones for tv
goto "The Source" by circit city and tell them that, and you will be all set. i can tell you what to do, i requires buying a head phone jack to rca male plug adaptor, then a digital splitter, then plug that into your sounds out put on the back of the T.V, and you are set, but the fellows at the source will exsplain it better then i could, im to technical.
Trust me i am the lat Pannel Guru!
Apr 11, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Want analog local tv, but getting digital response
You can't receive analog signals with a digital tuner so you are stuck with your 5 in. Sears TV
Mar 05, 2017 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Zenith DVT412
If you are using analog video output to connect to your tv set and accidentally selected progressive scan from the setup menu you will loose the analog signal output.
Turn the unit on with no dvd inside and after the " no disc" message press stop (on the front pannel button) holding it for about 5 seconds. It will restore the original progressive scan configuration (value= no).
Jul 06, 2008 | Televison & Video
Problem with Digital Input
You may need to switch monitor selection in your Display Properties. You need to activate twin/dual view in your Display Properties. Right click on any clear area of your desktop, click on Properties, click on Settings tab, select monitor 1 or 2 depending which is your primary and which is your secondary (analog/digital). Check (or uncheck-whichever works) on box "Extend....". Apply, OK.
There is an application that is supposed to facilitate twin or dual view configuration, UltraMon. This may be better/safer way to address your concern.
Hope this be of help/idea. Pls post back how things turned up or should you have other concerns.
Good luck and kind regards.
Jan 25, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Televison & Video Logo
Top Televison & Video Experts
