Question about HP Pavilion F1903 19" Flat Panel LCD Monitor
My monitor is stuck in a constant color loop...
I have an hp vs19e and i guess someone in my family pressed something and now when i turn on my monitor it goes from red blue green yellow pink lightblue white black...... i cant seem to get out of this loop
  • raymondw34 Dec 13, 2008
    i tried but the monitor is unresponsive to buttons
  • 58 Answers
What you are seeing is a test they use at the factory. Here are the instructions to reset the monitor:
1. Press the MENU button
2. Use the + and - buttons to choose Advanced Menu
3. Press the SELECT button
4. Select Factory Reset
5. Select Yes
6. Press MENU again to remove the onscreen menu
Hope that helps :)
Posted on Dec 13, 2008
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
HP vs19e monitor is blank. Power button is slowly
that is not a monitor problem that is a cpus problem disconnect the signsl cable and connect power cable you will see the post (power on self test) open the cpu draw the ram clean the dust and reinstall the problem will solved
Feb 26, 2010 | HP vs19 (Silver) 19" LCD Monitor
I have an HP vs19e monitor with several colored vertical lines near the right hand edge of the screen. I have swapped it with another monitor to ascertain if it is the monitor or the computer. It's...
jrfisher, Are you screwed? Maybe YES. MAYBE NO. If you're resourceful and smart, clever, Why don't you Search YOUTUBE for LCD monitor disassembly video clips that are about 8-10 min long. Also check for video clips of typical LCD repair, and find out the most common parts on the SMPS/inverter printed circuit boards that FAIL!! You just might be impressed and want to take a stab at doing your own repair of your monitor!! What do you have to lose? Maybe you can keep it as a spare if you fix it? Get back to me if you have a problem finding the stuff you need on YOUTUBE. I'm louie12fix on fixya or lmistyrel @aol.com good luck the repair. It sounds like the switch-mode-power-supply is failing in your unit.
Oct 07, 2009 | HP vs19 (Silver) 19" LCD Monitor
I have a hp pavillion a462x with a hp vs19e flat panel monitor. The monitor went black, totally dead. I connected it to another computer and it worked fine. The problem seems to be in the computer. Does...
That could be the video chip if have on board video. I don't know if you have an AGP or PCI slot to add a new video card. The Agp is brown color and always is just one. The PCI are white, and you can have 2, 3 or 4. You can buy some cheap video cards on ebay.
Oct 02, 2009 | Computers & Internet
My moniter wentr out.
Hmm, haven't had experience with this exact monitor, but several people have had success with my tutorial on fixing the vs19d and vs19e. Check out the link below:
http://boredprojects.blogspot.com/2009/09/hpvs19e-monitor-fix.html
Sep 28, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
I want to replace the power switch board on my hp vs19e monitor.
About your only hope for getting a replacement switch is to buy a "Parts Only" monitor off of EBay and carefully remove the switch. This one is tricky it's attached to the front bezel as you've likely found out. When you disassemble the monitor, lay it face down and remove the bac plastic then remove the 4 screws holding the button board on then take the rest apart. That's the safest way.
Mar 28, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Problem with HP VS19E monitor
you buy it at all electronic shop.
Apr 07, 2008 | HP vs19 (Silver) 19" LCD Monitor
HP Pavilion F1903 19" Flat Panel LCD Monitor Logo
311 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
