Question about Canon S200X Ink-Jet InkJet Printer
Canon s200SPx black ink can`t print
When i print black ink it doesn`t show, but with color it show.
    Scholar:
  • 78 Answers
Try cleaning the black print head, It might make a difference. You need to do this through your software preferences.
Gremlin11
Posted on Dec 13, 2008
Cannon mx860 fails to print in black ink. loaded new cartridge, still doesn't print in black. will print in color..
With the Canon MX860 you can removed the print head assembly quite easily and clean it with water. I have posted a youtube video for your reference.
Mar 06, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I can't print with the black ink. I performed a print head cleaning, and then I printed the nozzle check pattern. I noticed that the Cyan, Magenta, and Yellow shows up. However, the black checkered...
Simple problem that print head cleaning will typically not fix. The black ink is pigment based so it tends to form more stubborn clogs. Just remove the print head and if you have a steamer hit the black printhead nozzles with some pressured steam. If not available, soak the surface of the printhead in shallow hot water (try not to get the contact wet or be sure to dry them if you do). You can tell if the printhead nozzles are open by folding a section of wet paper towel like 5-10 layers and then soak it, press the printhead surface up and down lightly on the wet paper towel and if the nozzles are open you will see some ink pulse in the black port screen (the colors will also pulse from the pressure of the liquid under the printhead). It's easier than it sounds so give it a try. I've saved 100s of Canon printheads this way.
Note: if you have a really dried out head, you sometimes have to soak from the top inlet ports and the bottom nozzle surface to clear, but unlikely in you case since you had a black cartridge installed with ink in it (this keeps the top port from drying).
Sep 15, 2011 | Canon MP520 All-In-One InkJet Photo...
My black ink will not print. Do I have to have
The larger of the two black cartridges is used for text only printing.
The saller cartridge is used for black in graphic images or pictures.
This saves you color ink . It allows you to put the black ink on the image without making the color inks blend the black ink.
Don
Jan 31, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Canon printer wont print colored how to reset chip
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On your printer this happen with push consistently buttons for black copy (for turn off level on black cartridge) and color copy (for turn off level in color cartridge). The printer
shows empty cartridges but it will printing.
Nov 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon printer S200SPx error code 5600
The user manual does not talk about specific error codes. From other forum I belong to, it looks like it may be a bad printhead. If that is it, Canon says to call support. I suspect the cost of a new printhead would be more than the printer is worth.
Jul 31, 2009 | Canon S200X Ink-Jet InkJet Printer
Cannon S200Spx prints blank pages
The problem is likely to come from your printer settings in your printer properties dialog box. Right-click the printer icon and select Properties. You will see within the dialog where to set the printer to print on black only and then appropriate. restart your pc and then try sending to printer again. Good luck
Jun 03, 2009 | Canon S200X Ink-Jet InkJet Printer
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Remove the printer from control panel, under installed printers, then unplug the usb cable and reinstall the printer drivers using printer cd, or download from canon support website.
Apr 27, 2009 | Canon PIXMA iP90 InkJet Printer
Canon S200SPx
I cannot print. it is showing service error 5600. What is the solution
Nov 06, 2008 | Canon S200X Ink-Jet InkJet Printer
Canon S200X Ink-Jet InkJet Printer Logo
241 people viewed this question
old marine
old marine
