Question about Sony Playstation 3 (PS3) Console
Ps3 wont turn on
SO like when i go to turn on my PS3 system nothing shows up on the tv & the light on the front goes green for about a sec the it flashes yellow to red. I tried everything to get it to work but s*** aint happening and my COD4 is stuck in side too so thats double s*** for me. Anyways what do i do??
signed devilmaycry707© of the PS3network
Re boot ps3
Posted on Dec 13, 2008
My ps3 is not working it wont show a picture and when you try to turn it og it goes bip bip bip
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 28, 2010 | Sony Playstation 3 (PS3) Console
My ps3 screen wont show when i turn the ps3 on.
Jun 28, 2010 | Sony PlayStation 3 40GB System
Ps3 only works on my HD tv.
when you turn on the ps3 from the switch on the back, when the light turns red, hold down the power button on the front instead of tapping it to turn the light green. Hold it for atleast 5 secs. This restores the display settings.
Feb 20, 2010 | Sony Video Game Consoles & Games
Can't get system to come back on to tv screen after unplugging and now plugging back into tv. Worked just fine for over a year. Unplugged system and disconnected audio/video cables from front of TV to...
how was it connected at this other residence? was it via HDMI cable by any chance? if so try this, with the PS3 in stand by mode Press and hold the power button for 5 secs.. (until you hear the second beep) this causes the PS3 to reset the display properties back to 480i..follow the onscreen instructions to set it back up to 1080i
Feb 17, 2010 | Sony Playstation 3 (PS3) Console
PS3 can turn on, but T.V screen is black
turn power switch on in the back. red light on in the front, hold the power button until system turns back off. this resets all hardware settings. if this doesn't work and the system is ok (green light) then you have a connection problem to the tv
Jul 14, 2009 | Sony Playstation 3 (PS3) Console
TV Blank when powering PS3
When tv and ps3 backswitch turned on hold down the front power button when off until the ps3 has done a double beep after the intitial beep and wait for a max of 1 min and initial set up screen should appear
Apr 20, 2009 | Sony Playstation 3 (PS3) Console
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
PS3
Hello. There are a few causes for this. I will list acouple solutions for you.
1. Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
2. If option 1 does not work call Sony because the video out chip has blown or come unsoldered.
I hope this helps. Good luck to you.
Jul 25, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont show up on tv
Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
If while manually changing the Video Output Settings, the screen remains blank for more than 30 seconds, you may need to perform the following steps to reset the Video Output Settings.
  1. Make sure the Component AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
107 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
