Question about York Yankees Bedding MLB Comforter
York hvac heat problem
I have a York D3CG 60 and two D2CG 120 s that answer the heat call, but the burners only cycle one time then they blow cold air until i shut the units off and restart them
  • toutcons Jan 11, 2009
    I have the same problem.... however the high limits are new and have no air flow problem. I do wonder if this problem can be a result of a bad static pressure sensor??
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
It could be that the flame is " Rolling out" of the burner compartment and hitting the safety device known as the "ROLL SWITCH" If this happens all the time you probably have a split / cracked heat exchanger or a heat exchanger that has holes in it. The holes allow the air pressure from the indoor blower to enter into the burner tubes and blow the flame back out of the burner compartment...not to mention allowing poisonous CO [ Carbon Monoxide ] to enter the air stream that goes into the heated space of the people down below. The holes don't have to be very big for this to happen and if the heat exchanger is split along the factory seam...it will be very heard to see unless you have the heat exchanger heated up for a while. Heat exchangers are the second most expensive part of a rooftop unit right after an A/C Compressor. they're not too difficult to change but you have to know what you're doing specifically when resealing all the sides and edges so CO doesn't leak out of a seam and kill everyone down below.
Posted on Mar 02, 2010
  • 700 Answers
Whats happenening is that the unit's nare probably going off on the high limits. Thats when the fans will run until they are cycled off manually. Check yor filters and the belts to make sure that you are moveiong enough air for the unit. theanks for usin Fixya.
Posted on Dec 23, 2008
York gas furnace pilot lights and begins heat cycle but burner quickly goes out and system continues to run blowing cold air
There is a flame sensor that holds the gas valve open when there is a flame present. Heat generates about 10 to 15 milivolts to do this. Make sure the side of the flame is touching the sensor. If it looks ok Tighten the fitting that holds the sensor to the gas valve. If it still won't stay lit after all that then replace the sensor. They do fail with time.
Mar 29, 2015 | Heating & Cooling
York diamond 90 furnace burners won't ignite ... igniter glows for a few seconds then clicks off, no burner ignition. Tried resetting the furnace by powering off and then setting thermostat to call for...
The thermocouple could be defective. If this is a high efficiency York furnace, the stack blower should start and run first. If it doesn't the blower controller may have failed.
Dec 06, 2013 | Heating & Cooling
I have two Amcor AmcorAire UCHW-H12AF2 Split System Air Conditioner units -- 2 years old. One works fine, but the other does not blow heated air (Heat Mode). It is cold outside, but the good unit is...
your unit may be have possible leak on piping then refrigerant exit or had leakage of refigerant try to locate leak then braze it then recharge a correct amoun of refrigeran. if you use heater try to check heating element if ok by supplying voltage or used ommeter to test continuity.
Feb 03, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
Blower and ignitor work and then kick off but will work again after shutting furnace off for a while and turning it back on. This problem seems to occur when it is colder outside rather than above 30...
I had the identical problem with my York. Problem was the burners. The heating element would light the first burner but the flame wouldn't move to the other burners. The flame sensor didn't detect a flame on the last burner so the gas valve would shut off. I removed and cleaned the burners then reversed the first and last.
Dec 05, 2009 | York Furnace Draft Inducer Blower Fasco #...
York dual system. Upper level Diamond 80 never seems to cool, slow blowing air, attic tubing installed. What are my options?
i would get a contractor who specialzes in york to clean and inspect your system you could be low on refrigerant or dirty filters its hard to tell but systems do need yearly maitenance so it wont be a waste of money and you will get answers from the technician
Jul 29, 2009 | Heating & Cooling
York Dianond 80 Furnace
You have a limit switch that needs to be reset. It is probably the roll out switch that is located on the burner housing. The limit switch is a disk about the size of a dime or penny and has two wires to it. There is a small button in the middle of these two wires. Press this button firmly to reset it. Look for all the limits that may be on the unit that is manual reset like the one described above and do the same. This should correct your problem.
Apr 12, 2009 | Water Heaters
Furnace blowing cold air
Nordyne Furnace, pilot is lit, thermostat is reset, Heater is on but blowing cold air.
Mar 28, 2009 | York Furnace Draft Inducer Blower Fasco #...
York Yankees Bedding MLB Comforter Logo
813 people viewed this question
Top York Sport & Outdoor - Others Experts
Paul Carew
obsteiner
ray gallant
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
