Question about Asko 24 in. D3120 Dishwasher
Error lights flashing
Installed new dishwasher today. Won't turn on Error lights E EE flashing. Power is on, water on. Turned mains power on and off to reset. Could it be the fuse? Nothing in the manual about how to check the fuse. Tried each programme setting.
Model ASKO D3132XL
    Sergeant:
  • 186 Answers
Simple, go back to where you bought it, ask them, do they have a serviceman ? ity should be under some kind of warranty
Posted on Dec 13, 2008
Whirpool adp 2415
try turning off the power to the dishwasher for about 20mins then turn the power back on. sometimes this will reset the unit
May 21, 2014 | Whirlpool Dishwashers
I Have gsd422ox6BB Dish washer that all it does is flash the reset light.
Flashing reset light could mean the flood switch is turned on. There could be water in the motor compartment of the dishwasher. To get this water out, you will need to take the dishwasher out from the kitchen bench and turn it side to side a few times so that water comes out on the floor. Make sure the power mains connection is taken out.
If this does not help then the flood switch itself might be faulty.
Check parts on this site.
http://www.appliancepartspros.com/body-parts-for-ge-gsd4220x72bb.html
Feb 16, 2014 | GE Dishwasher Power Board - WD21X771
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
My dishwasher ( 66517269400) won't turn on. Circuit is fine. It is getting power. I replaced the fuse. Clean light is flashing 7 times. Manual says "dishwasher has malfunctioned. Call for...
The F7 error code(light flashes 7 times) is a one of these, Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
So what you need to check is if the correct water level is in the tub,to check that start d/w let it fill and once you longer hear water entering,open door and the water should be level or just above the heat element, if not enough water first check water pressure to inlet valve,if pressure is good replace the water inlet valve part # 8531671 it could be picked up from your local appliance parts store,or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
apdepot.com
midwestapplianceparts.com
Aug 20, 2011 | Kenmore 24 in. 17269 Built-in Dishwasher
I have a Pentair minimax 250k electronic. Opened pool today and when I turned power on to the heater, it won't get through startup sequence. Dashed lines flash, then 888 and service light comes on. ...
Most of the time I have found the problem to be the thermistor. It is located on the water manifold of the heater. Usually the panel lights, flashes then to 888 and back to dashed lines. SW light is green, and service light is red. It costs 25 to 45 dollars, and takes 5 minutes to repair. New thermistor looks identical to old so replacing it is very easy.
thanks please let me know if this was helpful
May 21, 2011 | Pentair Minimax NT Heater
The Drying light flashes and the unit beeps about once per second. At the same time the unit acts like it is washing (sounds of water washing insiide. The bottom is oompletely full of water.
so its beeping and flashing once per second correct this beeping and flashing is an error code that your unit is giving blinking lights or beeping sounds may indicate a problem with the dishwasher caused by power surges. To correct the problem, try pressing the "Start/Reset" pad to reset the dishwasher. If the problem persists, reset (reboot) the control by turning off the circuit breaker supplying the dishwasher for 30 seconds. Turn the circuit breaker back on and the dishwasher should function normally if you still have the flashing and beeping message me back Im going through the error code book as I type this if it still persists after you turned off the power then back on message me back with the number of beeps within 60 seconds as well as the number of flashing lights for instance if it does it every second or once every 5 seconds also if you have any further questions message me back them as well and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situaitons Thanks Rick
Feb 04, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Will not cycle
Check the user guide. May be a error signal. Check the inlet water free flow also.Check whether water getting drained due to drain valve problem.
Remove the hose from your main drain and watch.
May 20, 2010 | Jenn-Air JDB7910 Dishwasher
Newly installed integrated dishwasher will not start
have you checked that the water inlet pipe is not kinked or that it is turned on. some models have water pressure sensors and wont work on low pressure supplys
Apr 26, 2009 | Smeg Dishwashers
Asko Dishwasher F2 Error Flashing
F2 flashes, and wll not stop runing. No water in pan. help
Sep 29, 2007 | Asko D1776 Built-in Dishwasher
Asko 24 in. D3120 Dishwasher Logo
588 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
