Question about Mitsubishi WS-65809 65" Rear Projection Television
Question about your asnwer to my issue.
You mention the High voltage regulator may be shot, and to got to sears for a replacement. My question is which part should I replace? There is an 11 pin IC that is listed as the HV REG and there is a FET/Transistor that is part of that circuit.
  • 1,199 Answers
I would replace both because the falting of HV reg can cause the FET transister to fail also!
I hope this answers your question!
have a good day!
Posted on Dec 13, 2008
How do i fix this unit sharp 14v-w150m having a shot down problem. it shots down the high voltage during occelation. thank you.
You have a bad capacitor. I do not know your TV model number. Find a 160 volt to 250 volt capacitor at 1mf. Replace with same value. This will fix hundreds of TVs.
Dec 28, 2014 | Sharp Televison & Video
On the 1967 sears super 12 tractor what part number replaced sears part number 606A190 for the voltage regulator
you have a starter generator... you can go to most specialty 12 volt shops ( starter re-builder ) or online and find a good quality universal V.R. can't remember if thats a 6 or 12 volt system... google 12 volt external voltage regulator and you will get an idea what I am talking about. I've done this repair a number of times
Oct 23, 2014 | Garden
My 1999 r1 revs flick upto 7000 and back down to 1000 then to 0
Bad voltage regulator. Mine went bad then started to 'over charge' the battery. I put a voltage meter on it while the bike was at idle. It read as high as 16.1v. After I changed the voltage regulator it idles at 14.1v.
I replaced the battery due to it not being able to hold a charge. After I put in the new battery the tach shot up to 7k (while riding) then down to zero. As soon as I got home I put the volt meter on the battery and found out that the battery was being over charged. The voltage regulator took care of the issue. I hope this helps.
May 30, 2012 | 2000 Yamaha YZF-R1
Jmc8130dds microwave died. any thoughts. previously numerous messages about locking the screen on its own.
I think it is time to replace the microwave oven, the fuse has blown and there are numerous reasons why, shorted power transformer, shorted filament winding in the magnetron, cracked high voltage diode with a high level short, and a shorted high voltage capacitor, not to mention issues with the keypad and microprocessor control board.
Mar 20, 2012 | Jenn-Air JMC8130DDS Microwave Oven
Polaris quad 500 4by4 my battery went dead,i jumped it with a 12 volt battery ran it for a minute,i gave it throtle and my lights blew out high and low.
Your lights burnt out because of too high of voltage. This is also probably the reason your battery is shot. There is a voltage regulator on the atv that regulates 12-15 volts from the stator. If it is not regulating voltage it can jump as high as 25-30 volts which in time will boil your battery and burn out your lights which are rated for no more than about 15 volts. Let me know what year your 500 is and I can help you locate the voltage regulator, Daniel.
Oct 30, 2011 | Polaris ATV
1999 Kawasaki KLX 300 lights not working
Hi, Xim1645 a regulator-rectifier on a motorcycle converts alternating current to direct current. The reason you need one on a bike is that the bike is equipped with an alternator, which is just a device that takes power (in the form of rotation) from the engine and converts it into alternating current (AC). Think of the alternator as a type of generator. Now AC is a fine source of power for lights, but you can't feed AC into a battery or into a fuel injection computer and expect it to work.
The rectifier's job is to convert this AC power into Direct Current power so it can be used to charge the bike's battery and otherwise power all the 12 volts (DC) devices on your bike (electronics, tachometer, etc.) It's worth mentioning that generally a rectifier is combined with a voltage regulator, which makes sure the alternator doesn't generate too much (or too little) power/voltage. If your alternator were to generate too much voltage you'd risk overcharging the battery, burning out your bike's electronics, etc. And if it generated too little your battery would slowly drain (this is the most common failure in a voltage regulator) I bring this up because on most bikes they tend to combine these two functions into a single rectifier/regulator. It is also worth mentioning that all rectifier/voltage regulator must be physically or electronically (by wire) grounded in order to function properly.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Kawasaki KLX300R service manual repair 1997 2005 KLX300 Download Manuals... $15
OEM Parts for Kawasaki
1999 Kawasaki KLX300R Owner Manual
Kawasaki KLX 300R
Jan 03, 2018 | 1998 kawasaki KLX 300
Light doesn't come on, does not purify the runs
If the little orange neon light no longer comes on, it is a problem with the high voltage board and transformer. The board sits on top between the plates and the fan.
In my instance, the board had become corroded and shorted the terminals of the voltage regulator located on the board. Also, the ground strap around the ferrite core of the high voltage transformer had become corroded an needed replacement. Also, check the circuit paths from the nearest components to the Voltage Regulator pads. Mine blew one of the circuit traces.
All in all, I replaced the Voltage Regulator, Mouser P/N: 595-UA78L12ACLPE3, Transistor P/N: 512-2N4403BU, Timer IC P/N: 595-NE555P.
The voltage regulator feeds the latter two, as well as the high voltage transformer, I replaced those components as a precautionary measure.
The terminals do get corroded, so check those as well. There are no terminals on the high voltage board other than on top of the proprietary potted black box that feeds the target and neon light. Be careful with the terminal on that box because it breaks easy once corroded. As mine did.
Those components fixed my problem with the high voltage board and no neon light.
Hope this helps, let me know if you have any other questions.
Sep 19, 2009 | Ecoquest Flair Air Purifier
Yamaha dt 175, voltage question. When idling, my DT measures 7 volts across the battery terminals. When revved it jumps up to over 13 volts. This is a six volt bike. I know the battery is completely shot....
You need new regulator and new battery.The battery works as a filter as well.If it is in bad condition it does not filter anything and in high rpm the current is very high.
Jun 08, 2009 | 2006 Yamaha DT 125 X
Electrical gremlins
This is covered by a recall. Your dealer should be able to replace it Free-of-Charge. If they don't know what you are talking about call 1-800-FOR-MERC and talk with them.
May 14, 2008 | 2007 Mercedes-Benz G500
Hi.JVC AV-32F803/Y Turn on and shot it self off in a few seconds?
Sound like no High Voltage, have you tried the Horizontal output. Also look at caps in power supply for leaky ness.
Sep 21, 2007 | JVC AV-32F803 32" TV
Mitsubishi WS-65809 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
