Question about Motorola Mobility H500 Wireless Headset
Motorola H500 I am pressing buttons but the indicator lights wont turn on and the headset it not working at all. I dont know if I disabled the indicator lights but when I put it on charge the indicator light is on and stable.
  • 4 more comments
  • mickbennett1 Sep 06, 2008
    i hold the button in but it wont turn on
  • Anonymous Oct 31, 2008
    No lights no nothing, I tried holding down the main button, but still did not work.
  • sstocking Dec 04, 2008
    Seems Dead. Have used product about a week with no problem. Fully charged, turned on and seemed fine, then no lights of any kind and no connection to phone? Is there a reset sequence for the headset???
  • zliyb Feb 17, 2009
    first time to use it, just dead...
  • SyedsAli Feb 19, 2009
    Ever since I bought it was working fine. Yesterday, it started to sing in my ear with tet-tet-tet-tet-tet kind of beeps and I put it on charging. The blue light came on but it was dim. Today I turned it on again and connected after sometime it give me the same tet-tet-tet-tet-tet and died. I have pressed and held the Call button from 1 sec to 10sec and flashed about 3 times in a sec too. No change. Now I have put it back on charging with my fingers crossed.
    Any suggestions more than "press and hold" and "charging" can be a big help. Thanks.
  • Anonymous Feb 21, 2009
    It did the noise. I tried to charge it but nothing. It went dead. I put it back on the charger for hours but it will not come on at all. No lights, not anything at all.
    Problem Solver:
  • 8 Answers
Also, be sure the bluetooth is fully charged prior to syncing.
Posted on Sep 07, 2008
    President:
  • 2,961 Answers
Press and hold the main button for 3 or so seconds an it wil flash 3 times to indicate that it is active.
Posted on Mar 24, 2007
How do I pair my Motorola H500 headset to my Iphone 4s, it keeps searching> Is is compatible
Turn your h500 off. Then long press the multifunction button untilnit lights up steady blue. Then search on your phone to locate and pair with the headset.
Mark
Motorola Support
Jun 17, 2015 | Motorola Mobility H500 Wireless Headset
Motorolla h500 no steady blue light
Starting with your headset turned off, press and hold the call button for some 6 to 10 seconds, until the indicator light is steadily lit (it will flash some times as if it was being turned on, but don't release the button at that phase). With the light steadily lit It is in pairing mode. Now make your phone's bluetooth application search for new devices. After a while, the H500 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the indicator light will flash rapidly, and then, it will enter the stand-by mode. Otherwise, turn your headset off, and go through the whole process again.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out.
Regards, Carlos
May 11, 2012 | Motorola Mobility H500 Wireless Headset
My son has a xbox360 and were trying to get xbox live to connect and it wont we had it working just fine on his brothers hes not home so we hooked it up to the other xbox 360 and it wont connect
1 Disconnect all accessories and wired controllers from the Xbox 360.
2 Hold the "Guide" button down for three seconds on any wireless controllers, then respond to the prompt on your television screen to disconnect the controllers from your system.3 turn on the wireless headset by pressing the "Power" button in the center of the earpiece. 4 Press the "Connect" button on the front of your Xbox 360 system. 5 Press the "Connect" button on the wireless headset. The ring of lights around the power button of the Xbox 360 system should spin and blink once. One of the lights should remain lit up, indicating the port number that the headset is using. If you do not see any lights on the system, you may have a faulty wireless headset.6 Press the "Guide" button on your wireless controller to reconnect the controller to the Xbox 360 system. If you are using a wired controller, you can plug it back into the system.7 Press the "Connect" button on the top of your wireless controller to sync the controller with your system. You should see the connection light around the "Guide" button on the controller light up, indicating which port you are connected to. You should also see a corresponding port light in the ring around the power button of your Xbox 360 system 8 Press the "Connect" button on the wireless headset until the port light on the headset matches the light on the controller and Xbox 360 system. For example, if you are the first player, the light for port number one should be lit up on the Xbox system, the controller and the headset. When all lights correspond, your headset should be properly connected.
Sep 29, 2011 | Microsoft Xbox 360 Console
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
Forgot how to pair with a cellphone and dont have the manual
Turn on headset by pressing the power button. Wait a few moments until the indicator light is steadily lit blue to indicate headset is in pairing mode
Jan 03, 2011 | Motorola Mobility H371 Bluetooth Headset
I have charged the blue tooth but I do not know how to turn it on to pair it with my phone
Well, try to press the Call button: it is the button that has got telephone drawed. Hold it until you see the blue light steadily lit. That means that you just turned on and putted the headset into pairing mode. Now find Motorola H500 over your mobile phone. You will need to put a pass, and it is by default (i think, on ALL Motorola Headsets): 0000. You're ready for using!
Dec 18, 2010 | Motorola Mobility Universal Bluetooth...
How do I put my Motorola h505 in paring mode
Here are the steps to put it into pairing mode. Also please make sure you click the YES button below my response here to indicate my answer was helpful. It would mean a great deal to me if you could do so. Thank you
1. With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
2. If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step 1.
Oct 11, 2010 | Motorola Mobility H500 Wireless Headset
I got the H500 given to me but not manual to show me how to make it work w/my cell phone
Starting with your headset turned off, press and hold the call button for more than 6 seconds, until the indicator light is steadily lit (you'll notice that the light will flash as if the headset was being turned on, but don't release the button at this step). You headset is now in pairing mode. Now, make your phone's bluetooth application search for new devices. After a while, the H500 will appear on the phone screen. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). You just have to pair any two blueotooth enabled devices once. All subsequent connections between them should be achieved by bringing them both within range, with their bluetooth radios turned on. If they fail to do so, a simple press on the headset's call button should suffice to established the link.
Hope it works for you.
Regards, Carlos
Jun 14, 2010 | Motorola Mobility H500 Wireless Headset
Motorola h500 sch-r350 forgot code
Starting with your headset turned off, press and hold the call button for more than 6 seconds, until the indicator light is steadily lit (you'll notice that the light will flash as if the headset was being turned on, but don't release the button at this step). You headset is now in pairing mode. Now, on your phone, go to 'Menu > Tools > Bluetooth > Registered List > Add New Device'. If the phone's bluetooth radio is off, you'll be prompted to turn it on. Do it. After a while, the H500 will appear on the phone screen. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
Cheers! Carlos
May 21, 2010 | Motorola Mobility H500 Headset
Motorola Mobility H500 Wireless Headset Logo
421 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
