Question about Maytag MDB7100AWB Dishwasher
Dishwasher wont drain
We purchased a Maytag quiet 100 about 3 years ago. We only used it a dozen times before it quit. We didnt use it for a time and then discovered the child proof lock was on. After fixing that it now wont drain. It had water and stuff in it for a time intill vacuuming everything out. Any thoughts? thanks.
  • rgcmhunt Dec 13, 2008
    have taken everything apart I think its clean. During cycle it sounds like its trying to pump. It makes the noise anyway.
  • 275 Answers
Water pump might be too old and or maybe got rusty and died.. will need to replace..
Posted on Dec 13, 2008
Maytag jetclean quiet plus fills but wont wash or drain.
The mother board is going out, or the drain pump is failing. Try un plugging it...... by which i mean turning the power off to the unit and doing a soft reset. See if it recycles into the normal mode and works.
Mar 06, 2015 | Maytag Dishwashers
My maytag quiet series 100 dishwasher wont drain
hose or pump collged or the wire of the pump is disconected.
Feb 21, 2010 | Dishwashers
We got our maytag 300 quiet series about 3 years ago from home depot. about a year ago the option buttons/lights on the right side went dead. It was out of warranty and still worked so i ignored it. Now...
Our Maytag dishwasher (an earlier model) quit too. Found that the door latch operates two micro-switches which supply power to the machine and one of the switches no longer made contact when operated. The switch pair and the plastic latch parts are sold as a package for about $15 on the internet. A number of lights in the door are held in place by a small colored lens for each light and the lenses have disintegrated leaving the lights to hang by the wires inside the door cavity. Plan to use contact cement to glue the lights in place. I don't know if this will help you, but it doesn't take long to open the door cavity. Make sure to remove power to the machine before opening it up.
Feb 05, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Dishwasher purchased 8 years ago, $200 repair 4
For what you pay for dishwashers its normally better to replace them
Apr 24, 2009 | Maytag MDB7100AWB Dishwasher
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag Dishwasher Model DWU9200BAB
Do you have an air gap between the disposal and the dishwasher? If not required raise the hose and as high as you can. It must be above the water level in the sink. Try attaching it to the underside of the counter. At some point the hose should be above 32 inches. It the problem is with the dishwasher itself. Don't fix, replace. They are not really designed to last over 10 years. The new ones , especially in the last year or two are a BIG improvement over any older one. So quiet you can't tell they are even running, they clean so much better and are much more energy efficient. Stainless steel interiors are just a fad. The plastic tubs are actually less likely to leak and are by there nature more quiet.
Jul 02, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Grinding noise for maytag quietseries 200 usually when it first starts up Our Maytag Quiet Series 300 just started with the same thing. We have had it a little over 2 years. We thought maybe it was the...
It may sound loud and like something is terrably wrong - but when we researched and took the pieces of the sprayer arm out all the way down to the drain - we found 2 small pieces of nut shells - that's it ! They were making the dishwasher sound as if it had something really wrong with it. We removed the nut shells - put all the parts back together - it runs perfect!! Just remember to place the parts and screws in the order they came out - so you put it back together correctly
Jul 01, 2008 | Maytag 24 in. MDB9750AW Dishwasher
Quiet Series 100
It sound like a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if pump spins when it should force the water up into the sprayer arms. In case it doesn't spin you should replace the pump. Good luck !
Sep 11, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Maytag MDB7100AWB Dishwasher Logo
22 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
