Hi! I have a HTC P3600 and the loud speaker stopped working.
At first the sound was screechy like a bad sound system then simply stopped working.
I thought i might be the loud speaker that was busted so i replaced it with a new one but still i get no sound from it...
All options and notifications are on sound and all i get is silence...
Hope you guys can help me with a clue of what's going on here.
Thank you
SOURCE: unable to sitch on gps on htc p3600
More information might be necessary:
Are you still using the original software that came with your phone, or have you flashed a new ROM onto it? Have you flashed a new radio ROM onto it? If you don't know what I'm referring to, then you are probably using the original software. :)
The easiest way to test your GPS on the P3600 is to go outside and stand in the open without any obstructions in the sky (ie: no trees, buildings, etc. around).
Start the camera and in the upper left corner you will see a little camera icon with arrows pointing left and right. Press the left arrow until you see a camera with a cross-hair over it. This starts the GPS on the phone and it will say "GPS Initializing GPS...". Give it a few minutes, especially if you have not used it before. It might take as long as 5+ minutes. If it times out and says it was unsuccessful, just try it again. It should work after the second or third try.
If not, then you probably have either a hardware problem with your GPS, or the Radio ROM needs to be re-flashed. If that's the case, it is more complicated, and I will get into that with you in detail if needed.
SOURCE: how do i replace htc trinity p3600 screen
Download the complete disassembly guide for this phone from:
http://rapidshare.com/files/90486167/DimantosGuide2DisassembleTrinity.zip
SOURCE: HTC p3600 windows 7 driver
http://www.microsoft.com/windowsmobile/en-us/downloads/default.mspx
try downloading windows mobile decice centre from the above pasted link..
have the same problem with my htc touch diamond.
im having it sent for repair, htc acknowledges the problem.
I have the same problem. It seems the problem appeared when I was using the speaker while I was driving my car. It was plugged to the when I received a phone call so it might be the reason why???
I replace the speaker but then no sound at all. So what's best? A screechy sound or no sound at all???
HTC Diamond speaker stopped working, so now I am using a phone without a ringer and alerts/alarms. HTC repair is expensive.
I have the same problem but I don't know where can I find speeker neither how can I change it? If there is somebaody to help me?
