Question about Epson Stylus RX650 All-In-One Printer
Cleaning Printhead on a Epson RX650 Printer
Would like to know how to clean the print head on a Epson RX650 by removing the the print head
  • 78 Answers
Truely, this is a job best left to the professionals. I have been doing these for a few years now and I can tell you that it is fiddly and tricky. The best solution for cleaning a printhead is through software. This is how the professionals do it and it is the only successful method. Removing the printhead in these unit is only ever done when they are replaced and this is not something that can be done without the epson service software as there is a printhead number that must be entered into the eprom to make the head work.
If cleaning of the head through the soft ware has failed, try moving the head to the left of the unit. where the head parks is the ink system assembly, also known as the purge unit. Make yourself a solution of dishwashing liquid and water, about 70% water. Fill the small pad area that the head sits on to almost over flowing and move the head across to park position. Leave the printer for 24 hours and then conduct the deep clean from your software. If you are still unable to clear the heads, than the head is faulty and will need to be replaced. Again, there is codes to enter through service software that is unavailable to all except registered epson warranty service centres, so it will be something to be done by the professionals.
I hope this is helpfull.
Posted on Dec 13, 2008
How do I fix my printer it prints blank sheets it acts like its printing but the paper is still blank I did nozzle and print head checks nothing still blank
I hate to state the obvious, but how long has it been since you've changed the ink cartridges on the printer. If you have done both the nozzle cleaning and print head alignment and nothing appeared on the paper, I don't know what else it could be.
This following suggestion is very rare - if you recently replaced the cartridges and your printer hasn't printed since then, it is possible that you installed them incorrectly; OR perhaps you left the head protector tape on the cartridge. But then it wouldn't "see" the cartridge.
In the "rare" situations, you should try to remove and replace the cartridges to assure that they are properly installed.
Mar 05, 2015 | Epson Stylus CX6600 All-In-One InkJet...
After cleaning the printhead, when asked to print, the carriage moves to the left and the printer turns off.
Head cleaning is mechanical process, printing is electrical process. If nothing at all ink out/spray from head in printing process, problem with electricity. Damage board or short circuit at head cable. Check board first, may be some component "burn". It is suggested to contacted Epson customer support before further damage occurs.
Please check this bellow tutorial for more details of print head cleaning:-
However check the link bellow for the user guide to your printer, kindly go through it where it gives detailed instructions of various problems along with cleaning of printhead,may be you have performed something wrong to assemble/install the printer after cleaning the print head or some connection problem.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Mar 12, 2011 | Epson Stylus Photo R1800 InkJet Printer
How to remove epson print head for cleaning (stylusDX4850)
-The printhead of this model is not user removable.
-It has to be disassembled by a trained technician to remove the printhead.
Sep 02, 2010 | Epson Stylus DX4850 All-In-One InkJet...
Epson rx650 printer service shutdown repair. Can anyone help to get this printer going again? For 6 days it gave message service required and then an error message with only shut down option. Regards...
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
NOTE ! You can lost Epson lifetime guarantee on print head by refilling ink cartridges!
Latest versions changes:
Apr 26, 2010 | Office Equipment & Supplies
Epson stylus c66 printer will only print in yellow.
Sounds like your printhead is clogged... This does not mean the printer is dead as cleaning the printhead requires only two things.
  1. Patience
  2. A cleaning solution.
The former is often harder to come by than the latter because most printer owners want a quick fix...
The cleaning solution needs to be one that is compatible with inkjet printers. I personally use and sell this type here but you will find that it's available from various suppliers although the best fluid is apparently the older style Windex (the ammoniated version).
To actually complete the clean you need to follow these instructions:
  • Turn the printer on
  • Press the "ink" button once and wait for the printer to move off the parking pad
  • Remove the printer power cord and move the printhead all the way to the left side of the printer (out of the way)
  • Take a piece of kitchen paper towel folded about 4 times so it's about the size of the parking pad (the white bit of plastic the printhead usually sits on.
  • Soak this pad in the cleaning solution
  • Place the pad on the parking pad and then carefully move the printhead back over the pad so it sits flat underneath the printhead
  • Leave the printer for 12 hours
  • Return, look at the printer, wonder if it's ready (after 30 minutes) and then force self to go do something else :-)
  • Move the printhead out of the way and remove the now ink soaked pad from the pad and replace with a fresh one (again soaked in cleaning solution)
  • Move the printhead back into position and leave for a further 12 hours.
  • Remove this last pad and then plug the printer back in
  • Press the power button an allow the printer to start up again
  • Run ONE cleaning routine and a single nozzle check to see if the printer is now printing out of more nozzles.
  • Chances are you'll need to leave the printer for another 30 minutes or so to let the ink settle down again.
With a little luck this will have fixed the other colours and you should be able to print again. You may need to print a couple more nozzle checks or one more cleaning routine or even repeat another 12 hour wait with the solution soaked pad.
Whatever you do, don't waste ink or time trying to force the printer to do more than 2 cleaning routines at a time...
As to why this works.. in a nutshell, the cleaning solution wicks up into the printhead nozzles where it rehydrates and breaks down the ink clogs putting them back into a more readily ejected solution.
The solution needs time to do its work though so this is why you leave it for the best part of a day or more to do its work..
The C66, like many of the earlier durabrite ink printers are very prone to clogging to try to keep the printer ticking over and exercised and you should find you won't need to repeat this procedure again.
Hope this helps.
Mar 15, 2009 | Epson Stylus C66 Inkjet Printer
Ink heads
Removing the printheads from Epson printers is not recommended as you can successfully clean them while they are still installed and with less chance of borking the printer by forgetting where that screw went :)
To do this you need to turn the printer on, let the printhead move off the parking pads (where the printhead rests) and then immediately pull the power cord so the printer stops.
This will allow you to freely move the printhead to the far left out of the way.
You now need some ammoniated windex or a similar cleaning solution (try asking your ink supplier) compatible with inkjet printers.
Using a kitchen paper towel, carefully fold it four times and then soak this in the solution before putting the paper pad so it sits over the parking pad. Now move the printhead so it sits over the solution soaked pad and leave for 12 hours (don't turn the printer on or plug it back in).
Remove the original pad and put in a new one and leave for a further 12 hours.
Note: This approach allows the cleaning solution to wick up into the printhead nozzles and break down the clogs, returning them to solution and allowing you to clear them out. It requires time to let the solution do its work which is why it's critical you don't try to rush things..
Now, remove the pad, plug the printer back in and turn the printer on... Wait for the printer to stop it's initial routine and then run a cleaning routine and a nozzle check...
Leave the printer for a further hour just to let things settle some more and then print a new nozzle check...
You should find that that the printhead will have cleared out a great deal of clogging.
If your printhead has been clogged for some months you might want to change the pads more than once and extend the period over 2 to 3 days.
Whatever you do, don't try brushing the printhead back and forth over the soaked pad and avoid more than one cleaning cycle in a 3 hour period.
Hope that helps.
Mar 09, 2009 | Epson Stylus R380 InkJet Photo Printer
Epson RX650 with a G5 Mac. Printing beautifully,now pgs are blank
It definately sounds like blocked print heads, try head cleaning 4 or 5 times, leave overnight and try another 4 or 5 times the next day. This usually works, if not you will need to try something a little bit stronger. Try this link:
Blocked print heads are more far more common if you are using non-genuine Epson inks. Please take a moment to rate this solution. Thanks.
Mar 04, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
Printer heads cleaning
Your printer should have a self-clean function. Usually this occurs every time you put in a new cartridge. Read the manual. You usually have a feature that through the software provided you can request a manual cleaning.
Jun 27, 2008 | Office Equipment & Supplies
One of the best solution that we can provide you is head cleaning. One of the effective method of Head cleaning is listed below.
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) , your printer will require service.
Jun 03, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus RX650 All-In-One Printer Logo
385 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
