Question about Toshiba Satellite A105 Notebook
Toshiba satellite a105 screen problem
Toshiba satellite a105-s4064 Screen does not work. When you first cut on the laptop you get a whitish looking screen with some lines going vertical across bottom, then it fades to black(within a min).
Had a problem with it for a while(months). Started off you could move the screen to certain spots and it would work. then lately(past month or two) it was just barely open and it would work. This week it will not come on at all.
It does work on a external monitor.
Is this the inverter? LCD screen? cable(s)?
everything looks normal when apart.
please help.
  • 1 more comment
  • santore Dec 27, 2008
    Ok, tried a new LCD screen and it didn't fix it. same thing
    cable?
    which one?
    inverter?
    I did activate the internal screen. and I get nothing from looking at it from an angle w/ a light.
    It comes on like greyish with some horizontal lines(only a few) then fades to a dark black after a minute
    guess ill try inverter next, then i guess it must be the chipset on the mobo?
    (I said vertical above but I dunno what I was thinking when I typed that.)
  • santore Jan 06, 2009
    ok figured since i had backlight it wont the inverter so i replaced the cable from the motherboard to the inverter and lcd and that  fixed it!
    problem solved!
    thanks
  • 107 Answers
You need a new lcd, The connectors are bad...
Posted on Dec 13, 2008
  • Eric Mitchell
    Eric Mitchell Dec 27, 2008
    Then I would try your inverter board/cables if not you may have the internal screen disable (key combo on keyboard) try looking at the screen with a flash light (at an angle) and see if you see and image
  • Eric Mitchell
    Then yes if you change the inverter/cables and lcd and it does not work the you need a new mobo
Can I get an updated usb for toshiba A105 S4064 through an update or download
updated usb? I'm not clear on what update or download you are looking for? If you are refering to a 3.0 usb no.
Dec 30, 2012 | Toshiba Satellite A105 Notebook
I can't hear sound from my laptop even with the builtin speakers. It's a Toshiba Satellite A105-S4064.
On the front of the laptop there is a circular knob, play a music cd and then turn the knob from left to right and see if the sound comes back, if that doesn't work then make sure where the speaker is in the bottom right hand side of the screen click on it and make sure the volume is turned up.
If it still doesn't work then reload the sound drivers. At this point if the sound still won't work then that means that either the speakers or the motherboard is bad and you won't know for sure unless you replace the speakers first.
Nov 28, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite a105 s4004
Here, I found this:
Toshiba Satellite A105. How to remove and replace laptop FL inverter and LCD screen.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
Jun 23, 2009 | Toshiba Satellite A105 Notebook
Recovery console key convination for a laptop?
Hi there.
Restart the PC and hit F2 while it boots up, this will take you into the bios, look for boot devices and set the CD to the first boot device, save the changes and exit the bios. The compuer will restart and boot from the CD drive.
Once the OS has installed go back into the bios and set the HDD (hard drive) to first boot device.
Good luck and thanks for using FixYa!!
May 11, 2009 | Toshiba Satellite A105 Notebook
I had to replace my Toshiba A105 screen recently due to damage. I installed the new screen myself and it worked fine for a while, but now it has a pink vertical line about an inch thick running down the...
Ok then, take it apart again and make sure all the connections are well seated, check the inverter (circuit board under the screen) the ribbon cable that goes behind the the screen and the block connector that attaches to the motherboard. If all theses connections are well seated and you still get the pink line, the screen is defective and you need to send it back.
Good luck and thanks for using Fixya!!
Feb 23, 2009 | Toshiba Satellite A105-S4004 Notebook
LCD dark with white vertical line down it
It is the C-Board Panel Attached to the Display Panel And Is Integrated into the Screen .. You will need a screen replacement..
Your part is.... Toshiba Satellite A105 15.4" LCD Screen LTN154X3-L06
Feb 13, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105-S4064; can't get battery to charge
If you put strain on the jack (e.g. hang power adaptor from it whilst using or charging) then the socket on the mainboard can get hot due to poor contact and melt.
There is no way to fix this except to completely dismantle the laptop and fit a new socket - most likely a repair centre will charge you for a new mainboard.
Try another adaptor to see if that is the problem (broken wire in cord) - otherwise look closely at the socket in the notebook.
Aug 08, 2008 | Toshiba Satellite A105 Notebook
NETWORK DRIVERS
network driver for satellite a80 129
and motherboard driver either
Jul 18, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
714 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
