Question about Toshiba CZ32V51 32" TV
Television goes off without turning off
My 32" Toshiba Tv occasionally turns off and the red power led on the front blinks for 1-2 minutes and then TV turns on again.This happens after the set is on for a few minutes
    Genius:
  • 1,074 Answers
Your set needs to be repair by a tech you are having a problem in your power suply which is intermittent.either your hrizontal ic is shorting out, or your regulator or your microchip ic.or the diode that couple the collector of the horizontal transistor with the b+ from the fly back.or check for lose solder in the horizontal output or power supply. good luck
Posted on Mar 20, 2007
Toshiba 32A41 32" TV - I turned the TV off at the power switch on the front of the TV. The solid red LED turned off as it has for 12 years. NOW, neither the remote nor the power switch on the front of
Sounds like the power supply is down mate unless it's just a fuse replacement it's probably more cost effective to buy a new one.you could try gumtree or eBay for one with a damaged screen.
Dec 01, 2014 | Toshiba Televison & Video
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Sep 04, 2012 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
Sony Bravia KDL-46V3000 turns off with blinking front light.
Sounds like the power supply may be failing. Count the beeps next time, that will give you the error code.
Jun 18, 2017 | Sony BRAVIA KDL-46V3000 Television
Toshiba 42HP95 Plasma tv
http://www.fixya.com/support/t101749-tv_turned_itself_off_turn_back
Worked for me, was ez, and I am a huge skeptic and not very "TV technical."
Dec 23, 2008 | Toshiba 42HP95 Television
We have thomson tv 32" color crt sort length model 29df45 c s /icc20
tv power goes off when vcd / dish receiver is connected
Aug 12, 2008 | Thomson 29DM400 29" TV
I have a phillips universal CL034 remote control and i dont know the code or how to program it to my television
without knowing the brand of the tv i have to give you generic instructions on how to program the remote without knowing the codes:
  1. Turn your tv on manually
  2. on the remote press TV once
  3. Press and hold the set button until the LED red light blinks twice, then release the set button
  4. enter 9-9-1. the led will blink twice
  5. aim the remote at the tv and slowly alternate between pressing POWER and TV. Stop when the TV turns off after pressing power.
  6. lock in the code by pressing and releasing the set button. the led will blink twice.
Jul 02, 2008 | Televison & Video
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Set Randomly Turns off (Power LED Blinks) and Comes Back On ~1-2 minutes Later
if you have not gotten this fixed get it to a repair shop your problem is intermittent there might be lose solders or component in the power supply is failing and needs to be replaced.good luck blessing from belize
Jan 18, 2007 | Toshiba CZ32V51 32" TV
TV is not powering up and red light keeps flashing
I had the same red blinking led problem on my Toshiba Theaterview tv. I resolved by:
- Unplugging the tv.
- Press several times (3 or 4 times) the tv Power button.
- Plug the tv back in and press the Power button once to turn the tv on....tv worked!!!
I've had the problem before and tried unplugging the tv for a couple of days and that had also worked, but I this recent solution seems to be faster.
Erick
Jul 29, 2006 | Toshiba 55H70 55" Rear Projection...
Toshiba CZ32V51 32" TV Logo
80 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
