Question about Samsung SWA-4000
Just connected the SWA-4000 wireless amplified to my samsung ht-z310 - the readout on the display is "Rear Chk" there is no sound from the rear speakers- any help is appreciated
  • Anonymous Dec 26, 2008
    Same exact problem.
  • rick226044 Jan 01, 2009
    rear chk display shows on moniter and rear speakers go off and on inderpendantly.
Actually the SWA-4000 IS compatible with the htz-310t. I'm using the htz-310 system with an SWA-4000 and it works perfectly fine. under the list of compatible systems with the SWA-4000 you'll see the htz-310. so i don't know where the other answerer is getting his facts.
once you press the nubmers on the remote, 0, 1, 3 5 or whatever the numbers are. turn the system on with the on button on the system not of the remote.
if the blue led is on on the swa-4000 then it's communication, there's a link.
if you do a sound test it will not send the static to the rear speakers, at least it doesn't for me. however there IS sound ouf of those speakers. so i know they work.
Posted on Nov 14, 2009
Swa-4000 wireless module isn't compatible with htz310. You need to buy Samsung's swa-3000 to work with your htz310. I had the same problem. It tells you in your owners manual under conectivity where it explains about hooking up a wireless module(pg.55-60). I hope this helps.
Posted on Feb 15, 2009
It keeps saying "rear check" on the display. and i have reset everything and it doesn't connect to the rear speakers. the 3 front speakers will work just fine and thats with the sub. what do i do to fix...
Best solution - DON'T BUY SAMSUNG - every thing I have ever owned that is SAMSUNG has gone wrong (TV's, surround sound, blueray, microwave, you name it it's gone wrong!)
Aug 21, 2010 | Samsung SWA-4000
Hi I just set up Samsung SWA-4000 and for some reason I cant get it to link up it says Rear Check on the receiver and then the module goes to stand by
This means that its lost the connection to the wireless transmitter, the error means Rear CHK or check hence RCHK. Seems that if the unit is not quite in line of sight the connection can be flaky. I would check the positioning of the reciever. Try moving it, see if you cant get a better connection.
May 18, 2010 | Samsung SWA-4000
Samsung SWA_4000 Sound problems rear speakers stop working intermitantly with error Rchk on led
Nov 14, 2009 | Samsung SWA-4000
I'm having problems getting my swa-4000 system to work tried the code and holding down the reset button i have an ht-x715t system and the tx card is in right any idea's thanks
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Jul 03, 2009 | Samsung SWA-4000
How do i hook this up Samsung HT-WX70 Theater System with Wireless Speakers
1. Connect the front left, front right, center, and sub woofer speakers to the back of the home theater system.
2.
With the home theater system off, insert the TX card into the TX Card connection (WIRELESS) on the back of the home theater.
Important:
Make sure to insert the TX card with the slanted portion of the card facing left.
3. C
onnect the rear left and the rear right speakers to the back of the SWA-3000.
4.
Plug the power cord of the SWA-3000 into an electrical wall outlet, and then switch the power switch on the back of the SWA-3000 to [ON]
Hope this helps!
Jun 27, 2009 | Samsung HT-WX70 Theater System
Hi, I have Samsung HT-X50 connected with SWA-4000. It was working fine, then for somereason I had to remove and reinsert Tx card. After doing that SWA-4000 is not connecting to HT-X50. Blue light blinks...
You have to reset the connection:
Hope this helps!
Jun 09, 2009 | Samsung HT-TZ515T Theater System with...
SWA-4000 Sound Interference Problem
i also have this problem not when watching dvds but when watching cable tv. would like to no what the problem is
Feb 23, 2009 | Samsung SWA-4000
Wireless speakers
Google "Samsung SWA-4000" The HTz310 is wireless "ready" only. You'll need to purchase this unit for about $100 to make your (Rears only) wireless.
Dec 07, 2008 | Samsung HT-Z310T Theater System
Samsung SWA-4000 Wireless connection problem - Not connecting with main unit
I have had the same problem with the wireless unit and thought the same, it didn't work. The way to fix this is simple. You need to do the 0, 1, 3, 5 on the remote and turn on the home theatre system on the main switch on the front panel (as I was doing this on the remote, and it was failing). The blue light should then stay illuminated. If not just switch the main on/off button again, and it shoud work.
Nov 08, 2008 | Samsung SWA-4000
Problem with wireless conection between Samsung SWA-4000 and Samsung home theatre.
turn the main dvd player off, and press 0,1,3,5 on your remote, then turn on the player and the rear wireless receiver at as close to the same time as you can. should then light up the blue "link" light permanently.
Oct 19, 2008 | Samsung SWA-4000
Samsung SWA-4000 Logo
2,561 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
