Black & Decker TRO603 Toast-R-Oven Toaster Oven with Convection Cooking Logo
A
Anonymous Posted on Jul 22, 2012
Black & Decker - CT0649 type 1 - Oven doesn't heat to temperature, previously tripped GFCI.
Positive 120 volts input wire at interconnect melted the interconnect, I replaced. Oven worked , but didn't get to temperature.
3 Related Answers
cactus bob
BOB BROWER
  • 267 Answers
  • Posted on Feb 25, 2009
SOURCE: looking for a crumb tray for a Black & Decker
b&d does not sell this part . take a look at a good will store . there are allways a dozen toaster ovens there , all makes . this this is a way to get you tray for less than 10.00 good luck
Anonymous
  • 137 Answers
  • Posted on Mar 02, 2009
SOURCE: I DON'T HAVE CORRRECT MEAUREMENTS FOR BLACK AND DECKER CT0649
The CTO100 is 18" wide X15"deep X 12" high
The GTO649 is 20,7" wide X 15.5" deep X 10.6" high
grbullets2
Dave
  • 53 Answers
  • Posted on May 20, 2010
SOURCE: Will Purchase Oven or Parts from Non-Working Oven.
Al, your switch is likely a DKJ/1-60. As you know you can\'t find one, however there is a switch that will fix your oven. It\'s part # 05XDE5218104600 and is made for Delonghi ovens. It looks the same as the DKJ/1-60 and works the same. Get it at The Gourmet Depot website for $10 + shipping
2answers
How do i get a manual for a Black& Decker toaster Conf. oven?
Free Black & Decker Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Kitchen Appliance Black & Decker
Products 1 - 50 of 75 - Black & Decker Convection Countertop Oven User Manual ...Black & Decker Use and Care Manual Toast-R-Oven Asador Broiler CTO600.
Free Black & Decker Toaster User Manuals ' ManualsOnline ...
Products 1 - 50 of 81 - Black & Decker Owner's Manual Toaster MGD100. Pages: 0 Saves: 0 ... Black & Decker Toaster Oven Use and Care Book. Pages: 0 Saves: ...
Free Black & Decker Convection Oven User Manuals ...
1helpful
2answers
The heating elements on top do not come on to toast or bake the topside. The bottom elements heat up just fine. How do I troubleshoot? Is it worth fixing?
The following phone number will connect you with service department of Black and Decker and maybe they can tell you if it is cost effective to repair or if you should just buy a new one.
Phone Number: 800-738-0245
(Monday-Friday, 8:30 AM to 8:00 PM, E.T.)
1helpful
I have an Applica / Black and Decker Toaster oven, model CT0650. Can I still buy a temperature control for it?
http://www.directpartsandproducts.com/black-decker-parts-accessories-c-1.html?osCsid=1kicup2s295ac117g8sv0mcuf7
That is an address for a place that carries parts for Black and Decker or their phone number is 1-800-738-0245.
If that doesn't work then try this web address that will return a list of sites that sell oven parts.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
How can I get a manual for the Black & Decker CTO6300 type 1?
mcdevito75 here, You may be able to get manual online at Black & Decker Toaster Oven.
4helpful
My black and decker toaster oven is less than a year old and it has a burned out smell coming from it. I feel it might be a fire hazard and I am not comfortable using it anymore for fear of fire. What can...
Your problem is very likely the timer switch. They are very poorly made and they have a high failure rate. B&D should have a recall on these switches. It's likely a DKJ/1-60 timer switch. They make a very poor electrical contact which causes the switch and possibly the wall plug to overheat. Mine melted the wire insulation at the switch and failed. These switches are impossible to find fortunately because they are all subject to the same failure. There are a couple timer switches made for Delonghi ovens that will work in the B&D and other ovens that use the DKJ/1-60 timer switch. One is part # 5218104600 which works the same as the B&D switch but it only has about a 13 minute toast timer. Turn it counterCW to turn the oven on. There is another switch with a 120 minute timer which is part # 5218101800 but may be harder to find. The 13 min timer switch can be purchased for $10.98 at Gourmet Depot website. Another solution is to replace the bad switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts AC. You will no longer have a timer and you will need to turn the oven on and off manually but at least you will be able to use the oven and the switches are under $10 and much safer than timer switches.
1helpful
Black and Decker Extra Large countertop oven trips breaker
I work for Black & Decker customer service. Our phone number is 800-231-9786.
Sparks coming from any appliance or electronic device is very serious. Please call the above number sometime on Monday between 8:30 and 5:00 EDT. One of our customer service specialists will assist you with this matter.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
2answers
Looking for a crumb tray for a Black & Decker CT0649 Toaster oven
Black and Decker 0650
I have a Black & Decker CT0649 toaster oven. The timer switch on the toast control does not work and I took it out and took it apart. There is no way I can put is back together. Black and Decker will not sell me a new one!
If you have a broken Black & Decker CTO649 I would be interested in purchasing the two timer switches in it before you through it out, $5.00/each. (Negotiable).
I can be reached at [email protected]
Thanks
Al
Top Black & Decker Toaster Ovens Experts
john h
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
