Question about Hitachi 43UWX10B 43" Rear Projection Television
Hitachi tv color will not line up
How do you get the bulbs to line up. The red is about four to five inches off to the right of the vertical cross hair. We moved it as far left as it will go but will not move no more to the left. How do we get it to line up. We found how to to adjust it horizonally but can not get it to fully ajust vertical could you please email me back at mkizer@rjia.net and tell me what you think we can do. cause service man wants to much just to come look at it. mary
  • MK2168 Nov 25, 2007
    All of sudden the the red is vertically off. No damage to the tv , it wasn't bumped, moved or harmed in any way and it just happened.
  • chief7 Jan 25, 2008
    have the same problem, HELP!
You dont need to buy the 2 stk just buy one and you need to know what is the red and change it, in the board is red or blue, or the other is the plug from the deflet bobin (yoge or yuge) it will plug in the side of the stk.
Posted on Nov 10, 2007
    Genius:
  • 1,694 Answers
Convergence repairs run 300-400. Electronic parts called IC's
will need replacement.Skill level moderate to high needed.
Part # Stk 392-110  X 2
Posted on Oct 18, 2007
2 Suggested Answers
MikeNJ1964
  • 398 Answers
SOURCE: Hitachi tv
One of your convergence IC's has burned out and needs to be replaced. A good rule here is to go ahead and replace both STK392-110 IC's with the new improved STK392-150's. If you have never replaced convergence IC's and realigned convergence circuits, allow a qualified tech to handle it for you. When I do a housecall for a set like that I charge $150 but shops in your area will vary so ask around.
Posted on Aug 14, 2007
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
43fdx15b Hitachi 42in red vertical lines magic focus inop for red
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors.Shops usually charge from $200-$300
Sep 26, 2009 | Hitachi Televison & Video
Unable to align red crosshairs in horizontal range
No there are no quick fix options for this fault. The convergence amplifiers operate similar to a high power audio amplifier, so if there is an impairment anywhere in the system, it will result in distorted audio, or in the case of television convergence amplifiers, one or more colors won't align. The convergence power pacs need to be replaced and the out of tolerance precision resistors located near the power pacs need to be carefully checked and replaced as necessary. And the power supply fuse links to the power pacs checked and replaced as needed.
It is also possible that there are root faults that cause the amplifiers to go bad which include bad connections or a bad digital control module. This repair is possible for anyone having basic electronics knowledge and soldering skills. After the above repairs are performed it may be necessary to perform the static convergence realignment procedure using the outer cross hairs as you mentioned, and realigning them.
Apr 23, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Red vertical line appears intermittently
you have to have the entire screen replaced. hitachi tried to fix mine twice and couldnt, i finally took them to court and won. want my advice? get a new tv and never by a hitachi again!!! they are the worst!
Jan 23, 2009 | Hitachi 55HDX61 Television
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 43FDX01B Convergence Problems
Hitachi remote part # HL01643........I like the original remote
to do adjustments.................T.
Aug 06, 2008 | Hitachi 43FDX01B TV
Hitachi 50UX19K
in the tv menu or on the front of the tv there is an adjustment to align the color guns ( there are three, red blue and green). it will come up as a black screen with a color cross in the center. while this may clear up your problem the cross doesn't always clear it up completely. if the set is really old you might consider a new one.
Apr 22, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi inspire projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Dec 02, 2007 | Televison & Video
Hitachi tv
Mar 10, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
525 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
