Question about RCA D52W19 52" Rear Projection Television
Problems powering up
With our D52W19 RCA television it takes pressing the power button about 5-7 times before the television will power up. this process takes about 5-10 minutes, with the green light coming on and going out three times before waiting about 30-45 seconds before pressing the power button again. i called a tv repair store and they said that i should wait till it stops coming on completely, but this is rather frustrating, and i would like to attempt to fix it myself.
  • 1 more comment
  • azsonicsnake Dec 18, 2008
    is there any procedure i need to follow before just firing up the soldering iron and fixing those? do i need to discharge anything? and if so, how would i go about it. thank you very much for your time! i really appreciate the help.
  • azsonicsnake Dec 20, 2008
    i took the tv apart today, and discovered that my cp150 cap is bubbled on the end. so, where would i go about finding these capacitors? thanks again!
  • azsonicsnake Dec 23, 2008
    Thank you so much ladywinn! I replaced the three capcitors in my tv tonight and it turned right on. I cannot thank you enough for your advice! Definetly a top notch Guru!!!!
  • RCA Master
  • 5,138 Answers
These sets have alot of problems with poor solder connections resolder all pins on flyback transfomer, check 3 capacitors on power/deflection board cp(150) 2200uf 16v (cp120) 220uf 35v (cp114)220uf 35v they are green with gold writing.Also it is better to fix it Now because the longer you keep trying to play set it can cause more damage to it.
Posted on Dec 18, 2008
  • ladywinn
    ladywinn Dec 18, 2008
    No not on deflection board/,AC board carrys 350 volts on it.Its the one with ac/ cord .If cp150 looks bubbled up on top it is bad so then replace other 2 caps.Let me know if you need anymore help.
  • ladywinn
    ladywinn Dec 21, 2008
    Radio shack has capacitor make sure you replace all 3 capacitors in same circuit. Electronix Parts 1-800-223-3205 or order on line.
My RCA D52W19 HDTV Ready TV will not turn on. The power led comes on three times after pressing the button on the tv itself or attempting to power on with the remote. The condition has been getting worse...
Hi Aaron,
I just want to ask you something before I give the solution, does the unit gone to start-up problem (needs warm-up before it finally turn on, needs to pressed the power button key several times, needs to unplug from the outlet and plug it back in)before, you have said that you've encountered it last few months?
Jdvillanueva
Sep 29, 2011 | RCA D52W19 52" Rear Projection Television
I REPLACED RCA D52W19 CAPACITORS ONE TIME 5 YEARS AGO,AND THE TV CAME ON AND WORKED,IT LASTED 5 YEARS,BUT RECENTLY IT JUST WONT POWER ON,I REPLACED THEM AGAIN BUT IT WONT COME ON AND FLASHES THE POWER...
You have a bad flyback transformer. This is a common problem that eventually goes bad in the ITC 222 chassis. You have to get the model number with the code at the end of it after the /. And sometimes you must have the numbers from off the flyback itself. Try to contact MCM electronics for the flyback at 1-800-543-4330. First see if they can match it with the model number with the code after the /.
Jul 15, 2011 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52 doesn't power up and have a picture
press and hold the power button for a few seconds. it should blink some codes. does your tv try and power itself on a few times. does it not show power at all. need more info to determine cause.
Jun 13, 2010 | RCA D52W19 52" Rear Projection Television
D52w19 rca hdtv.will not tourn on. when u push the
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
If still you are having the same problem then please check the resolution configured in the Screen,try to reduce the Colour and the brightness of the TV
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 03, 2010 | RCA D52W19 52" Rear Projection Television
I have RCA D52W19 52 and i got problems with it
On deflection board,first board on bottom to the left CK capacitors cp150 2200uf 16v if it is puffed up on top it is bad replace 2 other caps in same circuit cp114,cp120 220uf 35v, also resolder all pinns on FBT flyback transfomer.
Nov 12, 2009 | RCA D52W19 52" Rear Projection Television
My TV won't turn on.
If this is a RCA Picture Tube Rear Projection, the Deflection Board will cause this problem. I do not know though if it is available.
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
RCA MODEL D52W19 I PRESS THAT POWER BUTTON GREEN LIGHT FLICKS FOR
try unplugging the tv for a few hours. then plug it in and push the power button on the front of the tv.
it has something to do with this processor issue inside the tv....its pretty much a stupid thing.
should have been a recall because everyone has the same problem on here.
this is pretty much just a band-aid over cancer, but i've been having to do this for about a month now, and it works.
Apr 10, 2009 | RCA D52W19 52" Rear Projection Television
Rca projection tv
Capacitor on Deflection board cp150 2200uf 16v if it is puffed up on top it is bad 2 more caps cp114 cp120 220uf 35v replace them if cp150 is bad.they are green with gold writing on them.
Dec 27, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 tv
3 capacitors On Deflection board cp150 2200uf 16v see if it is puffed up on top if so it is bad also replace 2 more caps in same circuit cp114 cp120 both are 220uf 35v they are green with gold writing.For Parts 1-800-223-3205. www.electronix.com
Tv will not come on immediately...
3 capacitors cp150 2200uf 16v if it is puffrd up on top then it is bad ,other 2 caps cp114 cp120 220uf 35v they are green with gold wring on them located on Deflection board . Resolder all pinns on FBT on same board.
Dec 26, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
106 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
