Televison & Video Logo
tom gorman Posted on Jul 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sanyo dp50740 wont come on after power surge
After power surge will not come on
Anonymous
Level 3:
Genius:
  • Master 1,182 Answers
  • Posted on Jul 23, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1182
Questions
Helped
292246
Points
3377
Change power outlet and see. If problem persists, it might need attention by a qualified service technician.
3 Related Answers
Mas Baz
Basuki Jrobenk
  • 177 Answers
  • Posted on Mar 21, 2011
SOURCE: What cable do i need to connect my laptop to my
Hello jaygee7414,
Sanyo DP50747 not support for D sub conection (PC in).
To connect PC in, you can use DVI or HDMI input.
Some Laptops already have HDMI or DVI out put. Like HP mini, sony vaio.
Or you can use s-video input.
Thanks.
Tech AV
  • 24 Answers
Once you have connected the laptop to the plasma - you may need to activate the external monitor on your laptop. How to do this is dependent on your laptop manufacturer and the Operating system you are running ie Windows XP, Mac OSX.
An example of the function key and which F key to press is shown below.tech_av_1.jpg
Anonymous
  • 14553 Answers
  • Posted on Apr 24, 2012
SOURCE: my sanyo dp50740 wont turn on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.4_24_2012_12_39_49_am.jpg
1helpful
MY 50" SANYO PLASMAWILL NOT POWER ON FOR MORE THAN 3 SECONDS
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
DP50740 hdmi wont read
You may want to try and find your model in the list below, then read the options we can offer for repairing the main board:
http://www.coppelltvrepair.com/search?Q=DP50740+&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
My sanyo dp 55441 wont come on
Try unplugging the TV, an hour later, now reset the TV back to Factory Settings. Now, the TV should be working properly now. Try a website like Ebay.com to buy a whole refurbish power supply board for the replacement.
It clicks on then clicks off
It sounds that the TV switches ON, and switches OFF, after three relay clicks. It is likely to the fault to its main board. Contact any service technician. This is not a user repairable fault.
google.com/+GopakumarGopalan
1helpful
1helpful
Dp50740 power led goes on and off
What you have is most likely a failed main board. These sets are known for this problem. There are several different variations of the main boards. Make sure you order one that matches yours. The main board part # will start with J4@#. The main board part # should be on a sticker either on the main board itself or on the coax input terminal casing. I hope you got the TV for a good price !!!
Sanyo dp50740 will not come on after power surge is there a reset?
Connect TV to a different power outlet and try. Switch off TV manually, remove plug from power outlet after switching off power, and retry after 48 hours. If problem persists, it might need attention by a qualified service technician.
What cable do i need to connect my laptop to my Sanyo DP50740?
Hello jaygee7414,
Thanks.
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
