Question about Samsung SyncMaster 932B LCD Monitor
My samsung syncmaster 932bw color problems(too bright )
My samsung monitor seems to be too bright or two dark, with way too much blue.. and i just cant seem to get the colors right.
Also in some video games now the surface of the water is solid and looks likes its coverd in ice or something.
I have windows xp and nvidia 8800.
I had the same type of a monitor before, and had almost the same problem, I forget how i fixed it before.
anyways any help would be great
stabelabel
  • 51 Answers
SOURCE: Samsung SyncMaster 730B monitor green color problem
video controller card has gone bad need new video controller card.
Posted on Mar 16, 2009
  • 259 Answers
SOURCE: SyncMaster 2253BW LCD Monitor doesn't fill screen in game's
you can change the size of the screen by going to the set up screen (menu) then adjusting the third box down the coarse and fine and the verticle and horizontal positions my settings are course 1798 fine 48 h position 56 v positiion 50 hope this helps regards Jim
Posted on May 13, 2009
supertech6
  • 513 Answers
SOURCE: samsung syncmaster 914v monitor problem.
This is likely the LCD panel itself - you are describing a left/right image error that can be only created by the left/right division by the LCD driver wrapped around the outside of the LCD panel.
If your monitor uses a separate circuit board to drive the LCD, it could be this driver board.
Either way, it will require an LCD panel - $$$
Posted on Mar 29, 2010
SOURCE: I rebooted my PC and now screen is darker and my colors are off
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Is the power button on while the screen is dark? If yes, it means your monitor has gone bad and the problem could be that the picture board of your monitor is bad that is why it is not displaying anything because another monitor works fine with you PC.
It means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Posted on Apr 29, 2010
budmrtn
  • 11361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 17, 2010
Our samsung syncmaster 2493hm fades to black when on websites with dark color backgrounds. How Come? Is there a fix?
Its probibly the MagicBright settings, press the button next to the menu button (its down arrow) and change the settings to something else, i changed mine from "Dynamic Contrast" to "Game" and everything is as they should be now.
Jul 13, 2011 | Samsung SyncMaster 2493HM Monitor
Lock on monitor adjustments don't know how to turn off the lock so we can adjust brightness and color
Follow these instructions :
  1. Turn on your Samsung monitor (if it isn't already.)
  2. Press the "AUTO" button on your Samsung monitor. This will run the automatic configuration utility. This will look at your current computer settings and adjust your monitor to best match those. This will take a few seconds. If this has calibrated the monitor to meet your needs, you are finished with the process. If it hasn't, continue to Step 3.
  3. Press the "Menu" button on your Samsung computer monitor.
  4. Use the arrows and the "Enter" button on the monitor to highlight and select various settings categories.
  5. Use the "Brightness" menu on your Samsung monitor to adjust how bright or dark you want the image.
  6. Use the "Colors" menu to adjust how prominent certain colors are displayed on your Samsung monitor.
  7. Use the "Contrast" menu to adjust the level of black on your Samsung monitor.
  8. Select "Save and Exit" to save your changes and exit the Samsung monitor's on Screen menu.
Dec 24, 2010 | Samsung SyncMaster 174V 17" Flat Panel LCD...
Check the contrast (darkness/lightness) on your Samsung LCD. There's a menu button on the monitor, press that and select contrast setting from the Menu.
Apr 29, 2010 | Samsung SyncMaster 932B LCD Monitor
I have owned a Samsung 932BW a couple of years. First symptom noticed was a blank screen and a blinking blue light around the on switch. From another desktop computer, I have swapped video cards,...
reynolds3d, Nothing new here. Happens a lot. 932BW will need to have some work done to the unit's SMPS probably. Read my fixya profile and make decision on what you will do based on info found there. 12fixlouie
Feb 20, 2010 | Samsung SyncMaster 932B LCD Monitor
When computer is starting up monitor goes blank. I have to turn it off and back on
Sent in for warranty repair to Samsung. Appears there has been some problems with 932B & 932BW.
Nov 30, 2009 | Samsung SyncMaster 932B LCD Monitor
It has a very dark screen, I can barely see my
Check the pins on both end of the connector, make sure they're straight other wise, reposition it with fine long nose pliers. Make sure the connectors are push and screwed tight also. Let us know!
Oct 10, 2009 | Samsung SyncMaster 205BW LCD Monitor
I have a blue line in my monitor
line driver element defective. no repair possible, to my knowledge. replace LCD or ignore line.
Mar 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Mar 16, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Syncmaster 913v color problem
Appears to be something in the connection. Check the video cable and pins on the video connector. Also verify the color settings have not been changed on the monitor. There should be an area where you change the RGB levels.
Feb 14, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung SyncMaster 932B LCD Monitor Logo
196 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
