Question about Alpine CHAS-634 6-Disc CD Changer
Not sure what the problem is
I have a 1994 Mercedes Benz C280 with the original factory head unit. I have added an Alpine CHA-S634 cd changer. Everything has been working fine since I installed the changer over 3 years ago. I took my car in for service last week and when I went to pick it up, I turned on my head unit. The head unit displayed an error message "C--ERR". This error code is not in the Mercedes manual and nobody at the dealership has ever seen that code. The antenna doesn't come up on the car, but there is obviously power to the head unit as we are getting the error message. I have power to the changer. I have removed the cd cartridge and then re-inserted it. I have disconnected the cd changer cable and then re-connected it. Still, nothing but the error message. Any thoughts? I'm at a loss!!!
Thanks,
Jim
  • Patrick Razvoza May 11, 2010
    Have you tried entering the radio security code?
    New Friend:
  • 73 Answers
Check the changer and see if cds are inserted correctly or if 2 cds are in one slot.
Posted on Aug 26, 2009
Does cd changer CHA 5604 play Mp3?
CD Changer CHA-S604 does not read MP3 discs. Alpine CD Changer CHA-S634 reads MP3 discs only.
Mar 08, 2011 | Alpine CHA-S624 6-Disc CD Changer
The magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame inside the caring which releases the...
Hi
Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine.
However Error1 means Battery inside CD Changer needs to be replaced.
And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer.
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again.
grease the moving parts with light lubricant.
Thanks for contacting fixya.com
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
Jammed CD & Magazine in an Alpine CHA-S634
Mine jammed after I dropped it, trying to swap it into a new car :-)
Same problem, however. Three of the six CD trays had wandered into the righthand mechanism (which selects and plays one cd at a time). Nothing else at all, most fortunately, was broken.
I removed the cover (3 screws on each side), and the small black faceplate that holds the eject button. The main faceplate came off too, needless to say; no screws, just tabs.
You have to remove the side brackets also, and the angle-adjust spring loaded pins on both sides need to be slid out. Then the body of the cd changer rotates out of its cover.
Now, you can see down into the mechanism. A CD was still stuck in the reader, along with several shifted trays. I could simply remove the CD, and with a small screwdriver, shifted the trays back over so that I could then successfully eject it. I removed and realigned the trays, which had been jammed, and it worked once more! Reassembled and reinstalled ;-)
Apr 26, 2009 | Alpine CHAS-634 6-Disc CD Changer
Manual removal of cd magazine
Seems to me an error of the installers, just go back and ask them to remove the magazine properly.
Aug 08, 2008 | Alpine CHA-1214 12-Disc CD Changer
Error 1 on alpine cha-s364
Quick Note: It's really helpful to your cause if you make sure you include more information about your system and what you're doing to get an error.
It's also a good idea to make sure you type in your model number correctly - you've typed in cha-s364 (the actual model you're talking about "I think" is a CHA-S634 - please verify!!
Here's a link to the user manual
As for the E-01 Error message on your CD Changer:
The E-01 reading is an error message, usually because the changer magazine is jammed in the changer. To manual eject out the magazine, take a thin plastic ruler (at least 5-1/2" in length) and slip it between the bottom of the magazine and the changer. Now, push in. This will hit a release button in the back. If the magazine does not eject, you will need to send the unit in to be serviced. To locate the nearest authorized service center to you call 1-800-ALPINE-1.
Note: if the magazine is half way out, but jammed, DO NOT try to release the magazine. You will need to send the unit in to be serviced by a technician.
May 29, 2008 | Alpine Car Audio & Video
Alpine cha-5624 cd changer
Need to order a 6disc container for CHA 5624;I lost the original:(. Tom H. Willett
Mar 23, 2008 | Car Audio & Video
CVA-1004 head unit set-up
check the cables, it may be one color switched
Sep 28, 2006 | Alpine CVA-1004 Car DVD Player
Alpine CHAS-634 6-Disc CD Changer Logo
292 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
