Question about Daewoo SW331 Cassette/CD Boombox
CD Player "OP" message
After my daughter accidently sat on top on my CD Player its stop playin and an "OP" message appears in the small display window. What does it means? Radio works, cassette player works. Any suggestions?
0 characters
1 Points
The CD part of my player does not start.
From what it sounds like, the laser lens in your cd player is having trouble reading discs. Is it just one cd or all? assuming it's all. you make want to get a cd lens cleaner's basically a cd with little bristles on the bottom designed to 'sweep away' the dust that accumulates on the lens. However, should you do that a few times (i usually give it about five good runs) and it still doesnt work, try another disc and listen closely for any sort of 'out of place' clicking noises....especially a monotonous repetitively click or ticking.... that usually indicates that the lens carriage has somehow jammed or come off track and needs to be replaced or refitted. refitting them on the track isnt difficult and once you open it up it's pretty self explanatory if you're mechanically inclined. Hope this helps.
May 09, 2016 | Boomboxes
How do i change the AM radio to FM?
Press RADIO BAND.AUTO PRESET until the band you want appears in the display (direct power on). Each time you press this button, the indication changes as "FM" --> "AM". Hold down TUNE + or --, until the frequency digit begins to change in the display. The player automatically scans the radio frequencies and stops when it finds a clear station. If you can't tuned in a station, press the button repeatedly to change the frequency step by step. If FM broadcast is noisy, press "MODE" until "Mono" appears on the display and the radio will play in monatural without any noise. Only strong FM signals can be decoded to stereo. OK.
Oct 22, 2011 | Sony CFD-S300 Radio/Cassette/CD Boombox
The CD player is no longer working. Not sensing it.
buy a cleaning disk, or get a micro fiber cloth, and take the stereo apart and find the laser lens, near the motor that spins the cd, it will be pretty small, gently wipe it clean in one direction, if that doesnt work, the laser has quit working.
Jan 14, 2010 | Memorex MP3134 Radio/Cassette/CD Boombox
Cd player on boombox not spinning properly.
Might be the laser but try lubbing the spindle motor 1st!
Mar 02, 2009 | Coby CX-CD248 Radio/Cassette/CD Boombox
My boombox is displaying the word "Protect" in the display. ???
The protect message indicates that there is a problem with the final stage of the amplifier section. This unit will require repair as a reset will not clear this. There is an audio amp IC inside that needs to be replaced. Figure on about $15 or so for the part.
Dec 09, 2008 | Sony Boom Box With CD Player & Cassette...
Cd's wont play
can you please post here the model and the part # of the cd player.. & please kindly inform me the type of cd she play in the unit, is it a Audio CD..?
Apr 16, 2008 | Boomboxes
Emerson PD6810 CD Boombox Error
My older model PD6810 had the spindle that holds the CD on the player missing causing the ER message to show and the player to stop working.
Aug 21, 2007 | Emerson PD6810 CD Boombox
CD player not working
Insert Lens cleaning Disk, after cleaning the disk If the CD is reading change the lens.
Nov 10, 2006 | GPX C984 Boombox
Daewoo SW331 Cassette/CD Boombox Logo
20 people viewed this question
Top Daewoo Boomboxes Experts
Jonathon summesfield
Are you a Daewoo Boombox Expert? Answer questions, earn points and help others
