Question about Technics Audio Players & Recorders
Hooking up audio components
I have no idea on what order to hook up my various audio components. I have the following components:
- Technics SU-V40 Amplifer
- Technics SL-PD627 CD Changer
- Technics RS-T18 Dual Tape Deck
- Technics SH-8027 Equalizer
- Technics ST-S77 Radio Tuner
- LG DVD/VCR combo
- PC computer
  • 515 Answers
This was answered here: http://www.fixya.com/support/t1371668-having_hard_time_connecting_various
- OPTiC
http://www.djproaudio.com
http://www.repairny.com
Posted on Dec 18, 2008
2 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
What is the buyasing transistor volt and current of Technics stereo integrated amplifier SU-5
You'd have to at least tell us which transistor you need info on in order for us to tell you the bias voltage. There are several, and all are different.
Oct 24, 2017 | Technics Audio Players & Recorders
I have a vintage Technics SUG9 Amp. I need to know how to hook up the Technics SH80-17 Graphic Equalizer. I Need a find a free manuel. Have any ideas where I can find one on the web? Thanks for your time!
Hi,the model number is "9" or " 91"..there is no such SU-G9 on internet ? than I will try to give you instruction for hookig the Equilaser..
Thanks
You are in the printed REPRODUCTION MANUALS CATALOG section of our site. We are currently rebuilding the entire site. A few of the largest company lists remain to be added or replaced. We will then replace the spare Factory ORIGINAL Manuals Catalog. Then we will work on publishing our PDF Manuals Catalog covering around a quarter million models.
http://www.stereomanuals.com/man/rep/technics/technics_manuals_su_xx.htm
Jul 29, 2011 | Technics Audio Players & Recorders
How do I plug my cable TV into the receiver and then into the TV? Whats wrong with the following: 1. Plug the cable into the antenna jack on the receiver 2. Plug the red/yellow/white cable into the...
When we talk about cables in an environment that also includes "cable TV", digital and analog audio; and video we need to be VERY specific.
Therefore, I could be misinterpreting what you meant in the following.
I doubt the receiver is designed to BE your cable box so hooking the TV-source cable to the FM antenna jack on the receiver is probably a bad idea.
If you HAVE a cable or satellite box, treat it like any other audio/video source and run its BEST audio digitally to the AVR and its BEST video to the monitor or TV (*) where the BEST most-specialized electronics will have the first shot at each function. You could also run basic composite video from the AVR out to the Monitor for the AVR's internal setup purposes.
* Even if it means bypassing the AVR. HDMI or DVI, component, composite are the various video outputs in descending order of quality. The TV deserves the BEST video.
If you're using the red/white/yellow cables for analog audo and composite video then you are making a major compromise in the quality of both.
Dec 23, 2010 | Harman Kardon AVR 120 Receiver
How do you hook up the audio from Visio flat panel to SA EX 300
Wild guess. Is the TV volume turned down and its output set to variable instead of fixed?
May 17, 2009 | Technics SA-EX300 Receiver
I have no sound in teh left channel , could be an integrated ?
Hey, The model of the amplifier is SU-G91 Technics.....If you could help......Thank you.
Apr 08, 2009 | Technics SA-EX320 Receiver
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
Technics su-v98. Powers on but no sound can be heard, not even through the headphones jack.
Make sure it is not on mute. Check rear of receiver to make sure AUDIO IN has not become disconnected. Check input selector and verify that it matches the audio source.
Apr 03, 2008 | Audio Players & Recorders
TECHNICS SU-V50
Hi max
I have done a followup with Technics Parts agents in the US, they will get back to me and then me to you shortly :) A vote as FixYa would help improve my ratings. Thanks
Graeme
Feb 06, 2008 | Technics SUV500 2-Channel Amplifier
700 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
