Washer will no longer spin.
I have an admiral washer, model# lcn6753a71, and it will not spin in the spin cycle. i have purchased and replaced the drive belt and the machine still will not spin. it will agitate during the wash cycle and drain while in the spin cycle it just will not spin' leaving my clothes still soaking wet.
  • 3 Answers
Striker plastic on lid that pushes in safety switch may be broken.
Set function knob to SPIN. Open lid and with a flat screwdriver press in the opening of the slot on the right side of the washer lid under where the lid would sit when closed. PRESS GENTLY SO YOU DO NOT BREAK THE SWITCH !!! If washed spins, let it spin out water in the tub and remove the screwdriver. the plastic pusheriner is broken. Look at the lid and see the plastic piece. Remove it by removing the phillips screw from the edge of the lid. Replace the part and you will be good to go.
Part # is 43-0057 at http://www.appliancepartscenter.us/. Cost is about $8.00.Did that fix it?
New Web Sites:
www.Avoid-Forclosure-Free-Information.info
www.Free-avoid-forclosure-information.info
Please contact me immediately if you know a person that cannot make their mortgage payments. I will work with them to avoid foreclosure or bankruptcy at no charge or fees to them.
Steven Goldman, CRS
Broker Salesman
Certified Distressed Property Expert (CDPE)
Certified Short Sale Professional (CSP)
REO-BPO Certified
GRI, ABR, SRES, CNHS, PM, CCI
Realty One Group
10750 W. Charleston #180
Las Vegas, NV 89135
Direct 702-242-1372
Fax: 866-286-2099
E-Mail: crssteven@teamgoldman.info
www.teamgoldman.info
Posted on Oct 01, 2011
HOW fix myadmiral washer model AED4475tq0
check the clutch may be slipping and for good measure check the door switch with multi meter for continuity
Jan 14, 2015 | Admiral Washing Machines
My admiral washer model atw4475tq0 is having trouble spinning and i also have a admiral dryer atw4475tq0 that is making a thumping sound
washer: check clutch assembly links with instructions here https://www.youtube.com/watch?v=tVc6SZ2DD4U
dryer: check support weels (2) for a flat spot or if theyre hard to turn
Dec 11, 2014 | Admiral Washing Machines
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
Washer does not work well on spin cycle admiral aav7000aww
No you need to check ur clutch, u can check it by running the spin cycle for a few minutes then shut it off and turn machine up so u can look under it. get a spray bottle with cold water and alil soap detergent, then spray the clutch with it, if it shows or steams up or sizzles then the clutch is slipping and bad. the cluth is in the center near the tranny, should look like a round siver pc of metal about 5 inches in diameter
Jul 18, 2009 | Admiral AW22 Top Load Washer
Admiral washer, spins too slow so clothes are still soaked
The clothes being wet and the drum spinning slow are probably due to a worn belt, tilt the machine back and the belt can be removed and replaced from below with no tools.
If the machine is constantly filling with water the level pressure switch requires changing. Isolate the machine, use a knife or thin bladed tool and insert between the front panel and the top panel approx 4" from each side to release the clips, the top should lift up, the pressure switch i at the back LH side, you will see a small pipe attached to it from lower down the drum, replace the pressure switch pull off the terminals and the hose and replace using the same order of connections.
Apr 14, 2009 | Admiral AW22 Top Load Washer
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
