Question about LG VX8350 Cellular Phone
Stuck in mute mode
I cannot figure out how to turn the "mute" feature off.
  • 1 more comment
  • jeaniefloyd Feb 11, 2009
    I can't get the phone out of the mute mode.
  • Anonymous Mar 10, 2009
    can't turn off the mute
  • viry2k May 11, 2010
    Is the master volume all the way down?
I got it on photo mode but don't have remote to switch how do I put it back to TV mode without it Its a vizo model va26lhdtv10t
[PDF]USER MANUAL - Newegg.com
images10.newegg.com/User-Manual/User_Manual_89-262-370.pdf
To get the most out of your new VIZIO product, read these instructions ..... WIDE.Switch the display mode. MUTE. Turn the audio off or on. BACK. Go to the ...
How to Fix the Most Annoying Features of Your New HDTV ...www.wired.com/2014/12/hdtv-setup/WiredDec 25, 2014 - You don't need to get your set professionally calibrated to improve itspicture quality. ... That "Showroom" or "Demo" mode is made to make your TV stand out ... All right, you have your picture just perfect-or good enough to kick back and ...Do you have an HD cable box, but the picture you're seeing is still ...hisense stuck in usb mode - YouTube? 1:30https://www.youtube.com/watch?v=FZ6YS3zjf_wJul 23, 2014 - Uploaded by Michael GregoryThis video shows how to get your TV out of USB mode without aremote. ... Don't like this video ...
Jan 02, 2016 | Televison & Video
Rear speakers aren;t working on my 2002 honda goldwing 1800
Sounds like the mute is stuck on. You need to figure out how to un-mute it.
Apr 18, 2014 | 2002 Honda GL 1800 Gold Wing
Have Callmaster lll phones. We want mute button disabled. Agents have figured how to enable the mute buttons on individual phones. Looking for way to permantly disable mute feature on 700 phones. Thanks
First make sure headset/handset adaptors are not plugged into the phone
Press Select
Press Mute
Dial 68 (this will show the current setting)
Press * to change the setting
When the setting is at what you want press # this will save tyhe setting and exit programming mode
Hope this helps.
Mar 16, 2011 | AT&T LUCENT / AVAYA CALLMASTER IV PHONE...
When i turn the tv on the volume is stuck all the way up and if i mute it it stays muted until you turn it off and back on
Muting is not designed to lower volume it shuts it off completely That;s why it resets when turned on and off.
Unless by muted you mean you can lower the volume to a listenable level but it reverts to full when you restart it.
Try using settings and set the volume and the type of sound(mode) you want then when you exit the menu it sshould save those settings.
Please rate my help++++Thanks for using FIXYA
May 16, 2010 | Planar XP15SSA-01 15 in. LCD Television
My newly installed pioneer dvd player keeps getting stuck on mute
check the telephone mute cable is not grounded to the chasis as that would mute it.
Feb 15, 2010 | Car Audio & Video
The sound/volume turned to mute automatically?
Assuming that you are using one, take the batteries out of the remote, then turn the sound up with the switches on the monitor. Tactile switches somethings get stuck. The mute switch could be one of them. If it is the one on the screen, check the "feel" of the mute button compared to the others. Damaged ones usually feel "flat".
Jul 18, 2017 | Computers & Internet
Panasonic Phones are on mute and will not work
The following is generic for most cordless phones:
Did you check to make sure that the phone is not in the intercom mode? If this phone has a base station speaker phone, make sure it is not on mute. Some of these phones have a fax connection. Make sure your phone line is not accidently pluged in to the fax section. Also if the phone has a fax monitoring feature check the the setup menu that the fax is not enabled. If the phone has an answering machine mode, make sure that this feature is turned off.
In the worse case:
There may be a defect in the X-Mit section of the phone. I would suspect the fault to be in the base.
Jerry G.
Apr 09, 2008 | Panasonic KX-TG5632 Phone
MY AMP KENWOOD VR-206
that is not a problem. i have the same reciever and it has done that since i bought it. i read up on it and it is a protection feature in case you had the volume cranked when you turned it off it gives you 3 seconds to reduce volume before the amp turns on. that is why you may hear a click when the mute turns off. it is also known as soft clip because if the amp would turn on at the same time as the reciever it could cause a surge to the speakers damaging them. it is a feature not a problem.
Dec 18, 2007 | NEC /5V 073-20674-14.5A Rev51 VXi VRM...
My NEC Dterm Series E 16D-1 does not display the MUTE feature
Sir, a co-worker with this phone has the same problem, i have a fund the users manual for the phone and the code to turn on/off the mic is Feature then the number 1. for her the mic button lights up when the phone is off. meaning no one can hear her. the link for the users guide is.
http://www.chickasawtel.com/pdf/manuals/elitemultilineug.pdf
hope this helps.
Nov 28, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
LG VX8350 Cellular Phone Logo
207 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
