Question about Sony Cyber-Shot DSC-T1 Digital Camera
Unable to focus camera.
I have made thousands of good pictures with this camera over the past 2 or 3 years without problems. Usually carrying it in my pocket. Recently I removed it from by pocket and attempted to frame a picture on the LCD an all that was visible were fine line streaks and no focus, though the object can be made out slightly. I checked other pictures already taken and they showed up good on the screen. I reset camera and problem did not go away. Does anyone have an idea on the problem and how much it would cost to fix?
  • Protus Nov 18, 2007
    I have what appears to be a stuck shutter. When I take pictures they are over exposed and often show faint images of objects that I have pointed the camera at just moments before taking a picture. If I set the camera to burst, the first shot is over exposed but the subsequent shots are fine. te video is also unaffected by this issue. I am fairly handy, if I could instructions/steps to fixing the stuck shutter I'm fairly certain I could make this repair myself.
    Novelist:
  • 107 Answers
The common cause of lines across the picture is a stuck shutter. This will cause over exposed pictures, out of focus, with lines across them. If the problem is infact a stuck shutter it will require full disassembly to fix, which will be somewhere between $100 and $200 to fix depending on where you send it. An image sensor failure, or focus motor failure can also cause simular problems - but they also cost simular amounts to fix. David Millier Advance Camera Repair
Posted on Mar 13, 2007
Unable to get sharp pictures, poor focus with P90
There is a focusing issue with your lens focusing motor or electronics controlling it. Unless it is a very expensive camera it may not be cost effective for repair.
Sep 01, 2017 | Nikon COOLPIX P90 Digital Camera
When I import from the camera to iphoto, duplicates of every picture import
I have the same problem!!! Every single time I import from my Nikon D90 I get duplicates of each photo on Iphoto. It never happened in 4 years, just recently does happen. Is it a setting from camera or from Iphoto? How to avoid this, without having to create separate folders on desktop as mentioned above. I just want to plug the USB and download on Iphoto without doing anything else. It gets frustrating as I usually download thousands of photos each month.
Jan 18, 2013 | Nikon D90 Digital Camera with 18-105mm...
My Canon Rebel will not autofocus. It takes pictures just fine with manual focus. I see several posts about this and no solutions other than the user doesn't know how to take a picture. We've had the...
A few suggest about this problem. First in manual or auto focus mode does the green in focus confirmation light come on in the lower right corner of the viewfinder? Are you shooting in One Shot-AF, have you selected an Auto Focus Point are your pictures in focus? I know you've been using this camera for 2 years and these questions you need to ask yourself. If that green confirmation light comes on then the picture will be in focus. a few things that will mess up focus are little or no contrast. No contrast like huge expanses of water, sky, glass or infinity will render a auto focus system near useless. Something that is good is that you haven't said anything about error codes which is good. These questions my sound lame but ask yourself this when was the last time I cleaned the lens (Front Element) use a lens cloth for this and huff on it if a little moisture is needed. Do you change lenses often and when was the last time you checked your sensor for dirt? If you have had the lens off you should check the rear lens element for finger prints or oil. A dirty rear lens element will cause everything to look as if it's shot in a dream world. Check your camera sensor buy taking a (manual) focus shot of a piece of clear blue sky download it to the computer increase the size to 100% and check out the blue for dirt. A camera that's two years old and used "normally" may need the sensor cleaned. But go back to this infocus light if it's coming on and the pictures are out of focus then you have another problem as in dirt.
Hope this was a little insight into your problem
Jan 11, 2011 | Canon EOS Rebel XSi Digital Camera
Dealy on snapping pictures
Check your focus modes to see if you are using one that is different to usual. When a DSLR has no focus lock it won't take a picture. Also verify that the focus motor in the lens is working ok. Google 'lens focus tests' and see what you can come up with.
Sep 11, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Pictures are coming out dark and often can't get it to focus
Having gone over a year without a response to my query, I assume lowering the ISO took care of the grain problem.
Jul 25, 2009 | Nikon D40x Digital Camera
Canon EOS Digital Rebel 300D will not take pictures
Have you tried to take picture by switching off the autofocus to manual focus in a prperly lit environment?
If it takes a picture, then it has something to do with your auto focus system of your camera. In such a case: try taking out the battery, the memory card etc and switch off the camera and keep it for like that for about 5 minutes. And then insert only the fully charged battery and try again.
If it still gives you a problem and keep trying to focus You will need to take it to the nearest Canon Service centre.
Mar 08, 2009 | Canon Digital Rebel / EOS-300D Digital...
Viewfinder of Sony DSC-H2 does not work anymore
Viewfinder has focus lever at bottom, please adjust viewfinder internal focus as per your eye sight looking on-screen display. Every thing will be fine after that.
Feb 04, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Pictures out of focus suddenly
Make sure the lens is clean and does not have greasy residue on it.
May 07, 2008 | Sony Cyber-shot DSC-H5 Digital Camera
Fuji Finepix S5200- Problem with autofocus
Hi I had exactly that problem and in frustration left it in the cupboard for 2 months and then it worked again perfectly, but the same problem has reappeared, I have had a quote from Fuji in Singapore s$246 for new lens and it is only 2.2years old! Can sympathize and would think twice about buying another or even fixing it.
Mar 18, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Sony Cyber-Shot DSC-T1 Digital Camera Logo
136 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
