Question about Roland Mc-909 Sampling Groove Box System
16 step pads at the bottom are sticking or inoperable
Is there a way to fix this without sending it to Roland?
Yeah call roland support and order the pads... i just fixed mine... the pads are 12.00 each 1-8 and 9-16
Posted on Jul 14, 2009
Display on Spd-S
this could be fixed at a cost of nearly 100$
Jun 13, 2008 | Roland Spd-S Sampling Percussion Pad...
Tip
TD20 backing voice plays on everything no matter what...
no matter what pad i hit the slapbass wave sound would play..
i unplugged all midi connections..
i turned the backing parts volume down..
i removed all my patterns from the kit...
i did a factory reset...
and there it was STILL!! dang it!!
after calling Roland and hearing they have never heard of this problem before
i took the unit apart and removed the backup battery.
( didnt want to send my unit off..omg i am broke enough.)
i also pulled the ribbon cables from their holders and and then i put everything back...it factory reset when i turned it on..
(yes i had myown personal backups beforehand)
BooM! Mr TD20 was back without that slapbass wave! yahooo!
i dont know what caused it, but i was doing some major midi routing
experiments with my comp thru Sonar6P, midiman 4x4, and my Roland VSynth...and it did just kind of show up at some point when i had the backing voices turned down i guess..
it still persisted even after the TD20 was turned off for a day and half and i turned it back on to see if it still was happening...yep, i was hoping it would fix itself..lol..i hope this helps fellow musicians..play on!!
on Oct 18, 2011 | Roland TD20SX V-Classic Electronic DRUM...
How to recover files from a crashed Compact Flash on my Roland SPD-S?
It's possible your CF card is full.
1. Connect the card to your computer as you have done. 2. Copy the files off it and save same them to a folder on your desktop.3. Right click only the Flash drive and navigate to "Properties" or "Get Info" if your a mac user.4. Take not of the file system it is currently using.5. Re-format the card with the same file system using your computer.6. Replace the card into your Roland SPD-S and Re-format using these steps: a. Select patch mode or wave mode. b. Press {SHIFT} and {SETUP} (CARD UTIL) c. Press the PAGE buttons to select "CARD FORMAT" then press {ENTER} d. A"[>] to format." indication appears. Press [>] e. A "format, sure?" indication is displayed. Press {ENTER} to start formatting.
7. Once formatted you can replace the card in your computers card reader and copy the files you backed up earlier onto it.8. Re-place the CF card in your Roland and it should work. If not then you may have a irreparable CF Card.
Oct 26, 2012 | Roland Spd-S Sampling Percussion Pad...
Headphone jack will not send audio through any cable. There must be something wrong with the motherboard chip.
Did you check the solder connection on the jack where it connects to the motherboard? That's a high stress point and could simply be a broken contact that needs to be resoldered. Should be 3 or 4 pins likely.
Aug 30, 2017 | Roland TD9 Drum Module
When I switch on the power in the roland HPD 15 handsonic, the number screen in the centre has the light but is blank, and the semicircle which has the numbers for different percussions has two lights on...
I had this problem and was about to send it back to Roland but tried a Factory Reset . It managed to fix it self but it has happened again so I woul dbe interested in finding a more perminnat solution .
Did you fix the probolem?
robin
Jan 23, 2012 | Roland Elektronische Musikinstrumente...
My roland vs 2000 says not found any drivers when i turn it on can it be fixed
I think your best option is to try downloading and installing the latest system update from the Roland Site link below.
http://www.rolandus.com/products/productdetails.php?ProductId=602
May 06, 2011 | Roland Vs-2000CD Digital Studio...
I have a very loud hiss/buzz sound coming from my Roland. It goes away if I lower the high volume knob. This just starred to happen recently. I tried changing connections from ch1-4 but no fix.
If this ties to a keyboard, make sure the keyboard and this are BOTH plugged into the same receptacle. You should send a higher level from the keyboard (turn volume up to around 70% or so) and use less volume at the input gain of this amp. Use more at master volume if the amp has one if needed. If the hiss is there with NO input cables plugged in and input gains at 50%, that is objectionable, the amp probably needs servicing. Unused channel gains should be clear down.
Apr 11, 2011 | Roland Elektronische Musikinstrumente...
I plug two roland pk-5a to have 1 octave above the other one but the problem is I can't play in the BASS MODE or MONO MODE with the HOLD function on and stop the note I play on one unit when i play a note...
If you have two MIDI sources that you send on the same MIDI or to the same MIDI sound generator you have to use a "MIDI MERGER" or you will get notes stuck on. A MIDI merger assembles complete messages before sending them to their destination. Without it, the messages are mixed which makes them garbled.
Mar 24, 2011 | Roland PK5A MIDI Controller
Sustain petal sticking, also stick without petal. Have taken action given in manuel. Still sticks.
Roland uses normally closed contacts... so if your cable or plug breaks contact, then will sustain. Check your cable for intermittent connection.
Dec 24, 2010 | Roland FANTOMG8
Roland Mc-909 Sampling Groove Box System Logo
515 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Greg Cann
Greg Cann
Vito Vacirca Jr.
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
