Question about Amana Haier AP125HD Air Conditioner
Heater not blowing hot air display says lo
My amana AP125HD portable unit in the heater function will slow down and blow cool air. The display where the temperature should be says "LO", this is not in my manual.
When the coils freeze up , from intake of outside air, when using the heat pump mode, the unit will try to defrost the coils before going back to heat mode. mine did this alot. does it kick back to heat after a few mins? also after 2 years , mine started having issues with the exhaust blower control and would go into warp mode and bang noise.seems like common issues for this unit.whether the amana, or haier version.
Posted on Feb 18, 2011
Why doesn't my torpedo heater get as hot as it should ?
If this is an electric portable heater with a fan on the back .With the unit cool,take an air compressor with a blower attachment and blow the air into the heater in the opposite direction (that the air flows when it is running) and get all the dust accumulation out of the unit.IT SHOULD HEAT UP FINE AFTER THAT
Nov 28, 2013 | Heating & Cooling
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
Service info
http://www.amazon.com/gp/product/B002YJ2ST6/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
Jul 11, 2013 | Amana Haier AP125HD Air Conditioner
Ptac153b50am not blowing hot air
Have an identical unit. Replaced the heater core which has built in limit switches. Didn't fix. Finally fixed it by replacing the heater relays (small black boxes soldered into the circuit board). Can purchase at Digi-Key online for $4 apiece or buy a new circuit board for about $100.
Jan 04, 2013 | Amana PTC153B50AM Split System Air...
I purchased a Haier Amana commercial cool portable air conditioner tonight and there seems to be something missing. There is a little hole in the rear of the unit that is discharging water, there is no...
Since there are no specific numbers for your equipment, I will respond generically. Part of the cooling process is removing moisture from the air. This sounds like it is a condensate drain. You may be missing a hose or a pan or both, that collect the moisture removed from the air. This is the only reason I know of for any A/C unit to be discharging air unless it is a water cooled unit.
Sep 09, 2017 | Amana Haier AP125HD Air Conditioner
Hi, I have an amana ap125hd portable air conditioner and for some reason is doesn't produce cold air anymore. Then fan blows and the compressor kicks in, but to no avail, no cold air. I took the unit...
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Jul 09, 2011 | Kitchen Ranges
How do I remove the back of the amana AP125HD portable air conditioner?
What are you trying to do? what kind of problem are you having?
Jun 30, 2011 | Amana Portable Air Conditioner
My 1 year old Amana portable air conditioner (model AP125HD) is not getting as cold as it should. My attempt at troubleshooting was to reset the unit, check to see that the options are properly set, be...
inside there is a filter attached to the motor. you will have to unscrew and open the unit to clean it off. it will be approximatly 6 to 8 screws to remove. i used a damp cloth to wipe the dust which was as thick as carpet(lol) cuz my unit is 4 years old and after that it is as cold as ever. also refrain from using the inlet hose as it attract more debris to that filter but still use the exhaust. hope this helps
Jun 26, 2010 | Amana Haier AP125HD Air Conditioner
Heating & Cooling Logo
309 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
