Question about Technics SH-GE90 Home Equalizer
Having a hard time connecting various audio components
I have no idea on what order to hook up my various audio components. I have the following components:
- Technics SU-V40 Amplifer
- Technics SL-PD627 CD Changer
- Technics RS-T18 Dual Tape Deck
- Technics SH-8027 Equalizer
- Technics ST-S77 Radio Tuner
- LG DVD/VCR combo
- PC computer
  • 515 Answers
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Posted on Dec 18, 2008
2 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: Hooking up audio components
This was answered here: http://www.fixya.com/support/t1371668-having_hard_time_connecting_various
- OPTiC
http://www.djproaudio.com
http://www.repairny.com
Sony flat-screen bravia tv picture goes black but keeps playing audio when playing Netflix or DVDs.
your dvd player needs its own connection as does netflix and cable,get a new hdmi cable for each
Jul 11, 2015 | Samsung Audio Players & Recorders
I am trying to hook up my cable box so i can watch tv.
At the cable box input, connect the cable (probably labeled "Cable In" or "Signal In").
Depending on the cable box model and available inputs on your TV, connect one of the following (listed in descending order of video quality). Colored phono plugs must match the colors of the plugs on each end.:
  • HDMI (a single rectangular connector at each end - sometimes you need to connect the Audio separately with a two - line cable with red and white phono plugs).
  • YPbBr, AKA Component (Cable with Red, Blue and Green phono plugs, plus a separate Red and White cable set for Audio).
  • S-video (a single round connector and separate Red and White audio cables).
  • Composite (Yellow video cable plus Red and White audio cables, usually sold as a single set).
  • RF out on the cable box connects to ANT or Cable In on the TV with a coax cable.
The various options are always grouped in some manner on both the Cable box and the TV. On the TV, note which input set you use, for example, "Component 1". This is the input you will select to watch whatever channel you select on the cable box.
An unused output on the cable box can go to a video recorder. Some cable boxes may permit setting up two different channels for this purpose; others will only put out the signal from one channel at a time on all outputs.
You may, if you prefer, connect the audio cable from the cable box to a stereo receiver instead of the TV. Usually people connect the audio to the TV, then connect another audio cable from "Audio Out" or "Monitor Out" on the TV to the stereo receiver. That way the sound is from whatever video source is currently selected, and the TV remote control can be used to set the volume. TV sets with this option usually have a setting to turn off the internal speakers so you hear only the external stereo speakers.
Feb 05, 2011 | Televison & Video
I am having troubling hooking up my PS3 to my denon AVR-1907 receiver. I am using the PS3 component inputs and hooking them up to the "VCR" input.
Connect your component cable to the PS3 OUTPUT (there is no input) and connect that to the component IN on your receiver.
Jun 14, 2009 | Denon AVR-1907 Receiver
When connecting XBOX live to LG flatscreen there is no video only
There should be a switch on the cable that says HDTV/TV if you are using component connections, make sure that the switch is set to HDTV.
May 12, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
Multiple game systems through home theatre
what you need to do is hook all of your gaming systems into the "in ports" on your gameing switch, then hook the set of cables you want to use to the "out port" then the other end of those cables need to go to the "in port" on the home theatre system (you can pick which in port you would like to use, it should say which is which on the back by the ports) after doing this you need to find the out port on the home theatre system that corresponds with the cables you are using ie, rca component or hdmi. once you find that port you need to hook a cable to that into your 'in port" on your tv., lastly turn on all of your gaming systems, your tv and your home theatre system. and on your home theatre system select which ever port you hooked the gaming switch into, then turn your tv to the correct channel that you hooked the cables into the tv, lastly go through each swithc on your gaming switch to be sure that they all work, if not, you might want to use all the same cables for all connections, ie, all component all rca or all hdmi, i prefer component.
Mar 29, 2009 | Philips MX6050D System
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
- OPTiC
Dec 13, 2008 | Technics Audio Players & Recorders
No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Feb 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Dvd connection
Yes! You can pass the video signal through the receiver. This is most useful when you have more than one video device (e.g. DVD, cable box, VCR,...), and you can use the receiver to switch to the audio and video for the selected source at the same time.
On the back of your Onkyo HT-SR800 there is a section labeled "Component Video." It has three inputs and one output. So, attach your DVD by component cables to the "DVD In" and then attach component cables from the "OUT" receiver connection to the TV.
If your TV doesn't have a component connection, then this addresses your other question. You can't gain anything with this, because your TV doesn't support it. Connect the DVD to the TV according to the highest quality connection that they both support, in this order: composite, S-Video, component.
If you are using composite, but they both handle composite, than yes, you will get a better picture by going to component (or even S-Video). If both devices support progressive scan, this could be a substantial difference.
Your receiver accepts component, s-video and component video, but keep in mind, it may not do "video switching." So if you connect the DVD in via component, but go out to the TV over composite, then you may not get any video at all (but feel free to try). Try to avoid this, but you may be forced to try depending on the limitations of the various devices that you are hooking up.
Jan 16, 2008 | Onkyo HT-SR800 System
Technics SH-GE90 Home Equalizer Logo
1,124 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
