Question about iLO 3200 32 in. LCD Television
Picture doesn't fit screen
We like to watch Nascar and the running order is at the top of the screen. On our TV you can't see it. We have tried the different picture settings, like panoramic, full, cinama, etc. but that doesn't work. How do we change it to show all of the picture? Thanks
  • Anonymous Jan 17, 2009
    when i put up web pages etc they do not fit screen leave margins whole pages there just dont fill screen when try to make bigger leaves wide margins
I have same problem but I have DISH network..is the a menu or settings associated with the DISH that I can adjust myself?
Posted on Feb 27, 2008
    Champion:
  • 217 Answers
What typy cable box are you using? You should be able to change the settings through the cable box to match your resolutions that the tv can handle, if you don't have the settings on the remote control, call your provider and they should be able to talk you through it
Posted on Mar 17, 2007
How do i make picture fit screen? top and bottom of picture is missing
Some receivers have the ability to do this for you, for instance, all ViP and Hopper receivers from DISH can stretch or shrink the screen to fit. Most HDTvs also have this feature, independent of the type of input, using your TV remote find the button that says something along the lines of screen size, picture fit, stretch, aspect, etc. While watching a program that looks unlike the way you want it to, tap the button until the picture changes to the style you most prefer.
Mar 02, 2015 | Evesham Televison & Video
The picture doesn`t fit the screen. Daewoo DWX-28W5GB telly
Sometimes the box that sends the signal to the TV preconditions the signal to 4x3 or 16x9, depending on the capability of the TV. I always opt to the "no fit" option and allow the intelligence of the TV to fit the screen.
If you have "off air" TV signal without that preconditioning, I cant help.
Oct 02, 2017 | Daewoo DTQ-20U9SC TV
I have a 550 series plasma Samsung Tv 54''.. I cannot get the picture to pick up for example the football score at the top of the screen, nor the NASCAR readout at the top. I get a piece of it but can't...
The problem may be not in your TV but in your receiver, if you use a cable or satellite receiver. Sometimes those also have similar settings for picture mode - it's rare, but I've seen it.
If not, then it must be tv's zoom mode is just set to something other than "standard".
Nov 17, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
The ticker tape during football or nascar is not visible
If your watching a standard resolution(4:3) picture in wide screen format (16:9). than the picture will be stretched and the tops and bottoms cropped. look in your video or set up menu to change the resolution settings to standard 4:3
Sep 27, 2009 | Mitsubishi WD-65731 65" HDTV
Picture is only in middle of screen, top and bottom of screen is blacked out
If you are watching widescreen format movie or tv programming on a non-widescreen tv, that is how it will appear. The widescreen is a wider picture so to show it on a less wide screen, it has to shrink down to fit. and leave blank space top and botton.
If not, sorry.
Sep 12, 2009 | Toshiba 36A40 36" TV
Picture is crooked
A year, to 1.5 years is very normal for bulbs. Just remember they are rated by the hour. The more you use it the faster the bulb goes out.
To fix the picture
NOTE: The TV must be on a flat level surface.
1. From the front of the TV, lift the foam to access and loosen slightly, the brass Rotation Locking Screws on the Adjuster
Assembly, (Use a 10mm wrench.)
2. From the rear of the TV, access the black Rotation Adjustment screw and adjust so the test pattern center lines are
parallel to the sides, top and bottom of the screen frame, (Use a mirror to veiw the picture from the rear of the
set.)
3. Tighten the two Locking Screws. Use Locktite to secure the Adjustment Screw.
Jun 14, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Ilo lcd tv..picture too large??
I had the same problem and tried everything with the tv to get it back to normal. I would look for what was suggested by tvtek, but also look on your cable remote or box for an "aspect" button. That fixed my problem. If your problem occurs with DVDs as well then you may have another issue, but if it is with cable only, try this. When I called our cable company the tech said alot of people this button without even knowing it.
Feb 26, 2008 | Televison & Video
Tv picture not all showing up
the source has to be set to16 x 9 output also the tv may need to know that it is receiving 16 x 9 input or 3x4 input hope this helps
Jan 06, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
iLO 3200 32 in. LCD Television Logo
157 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
