Microsoft Zune  Black  Digital Media Player
Problem for Microsoft Zune Black (30 GB) Digital Media Player...
I can't unlock my Zune.
By becka_smiles on Dec 13, 2008
When i try to turn it by turning from the play and pause button it won't turn on. It only turns on if I plug it in to the computer w/ the usb cable and when it does turn on I press down an it doesn't scroll down it just stays on the same spot
I have the same problem! And, of course, I've tried to turn the switch to unlock. I've actually had the problem once before and it fixed itself when I updated the software. But, that was several months ago. I installed the newest update software 2 days ago and the problem just started tonight. I haven't found any info on the microsoft support webpage about this problem.
Comments:
Dec 15, 2008
- I FIXED MINE TODAY!!
Well, I was really frustrated after I did a reboot and a system restore (which cleared everything off my zune and reloaded the most updated software.) It still didn't fix the problem. I called a zune support person and they were impressed that I had done all the steps that they would have asked me to do. She was ready to take my credit card information and have it sent in for repair. I am out of warrant and it would have cost $129.95 regardless of what it took to repair it. That is a flat fee for anything that gets sent in to be repaired. Obviously I was ticked.
So . . . I looked at the switch again and noticed that it wasn't perfectly flat. The long side was tilted down toward the screen with the back tilted up. I tried (carefully) to pull it up with my fingernail and finally got it to pop back up to proper position. THIS FIXED IT!
I'm not sure what would have caused this switch to be tilted, but I think it has to do with my hard acrylic case. I always have it in the case for protection, but I had recently taken it out to clean a speck of dust that was driving me crazy because it was stuck on the screen. The case is a very tight fit. I think the lock button got bent when I was taking it out or putting it back in.
I hope this helps someone else and avoids them paying Microsoft $129.95!!! Ha, Ha, IN THEIR FACE!!
Jan 07, 2009
- Read my comment above.
Jan 07, 2009
- There is a solution!
Same Problem
Apr 18, 2009
-   Wish someone would give a little info about how to remove the cover to see if that is what the problem is with the switch.. -   Matt K R
Mar 14, 2009
-   i have a worker from India with the same problem and i looked at the repair you made and tried it on his i took the buttom out three or for times and it corrected his locked problem it is sad that they would charge that much when they created the problem guess Bill is getting low.-   Guest
Mar 02, 2009
-   YOU ARE AWESOME. I just had the same problem with my daughters Pink 30G Zune and you are right it was just a tilt of the lock button. Saved us all 129.99. YOU ROCK. Thank you kindly -   Guest
Jan 08, 2009
-   OMG, I was so pissed at my Zune...and this totally worked! It's been broken for at least a year and I was unable to lock it, and then for the last 3 months it's been locked. THIS WORKED! THANK YOU! -   Guest
Jan 03, 2009
-   My zune is perminently in lock and can't do anything with it. Removed the button to try and fix and it dose not unlock. It has to be a program problem. Anyone got any ideas? This all started with the big freeze new years eve. now it just always locked.-   cresconn
Best Solution
posted on Feb 15, 2009
Very Helpful)
Bhav91
Rank: Apprentice
Rating: 100%, 12 votes
My lock switch broke off. so with a paper clip I took off the little plastic under the switch. with that off, i could see the small black toggle switch and i was able to set that to the unlocked position. I cant lock my zune now but the zune works.
Was this helpful?
Yes
No
8 people thought this was helpful
Popular Solutions for Microsoft Zune Black Digital
Questions and Unsolved Problems for Microsoft Zune Black Digital
Do you recommend Microsoft Zune Black (30 GB) Digital Media Player (JS8-00001)?
Answer
Answer
my zune cuts itself frequently and the sound sometimes comes in distorted
Answer
I got a first-gen Zune 30GB that had been sitting in the box untouched for a few years. I installed... (More)
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 01, 2009
Whoa, thank you! I was surprised mine was tilted the exact same way and this fixed it!
$129.95 fee avoided.
Thank you for posting this solution.
:D
Describe your MP3 and Digital Media... problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top MP3 and Digital... Experts
Top Audio & Video Equipment Repairmen
in , FL
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
