Http://au.lge.com/products/sidemenu/list/video_digitalsettopbox__lst6100p_PRD|MANU_manu.jhtml
Download the PDF, pages 34 and 35.
Not all IR codes for all devices are available online, moreover you need to know what universal remote you are using.
A user reports "0591" as working code for your machine, dont know if it works. If that does not work, you will need to use autoscan on the remote to find the code.
If it does not , a good solution can be giving the universal remote to the kids and buying an original replacement from LG calling the number listed on the user manual
What is the brand/model of the new universal remote? once i have that i can give you the code, as different remotes use diff sets of codes, ie rca uses 3 numbers as sony uses 4 digit codes in their remotes
What make model universal remote you using?
Try code 10178
Hi, Welcome to Fixya....
Use this code below:Only LG code listed is 10856. Also try code 10178.
Hope, it will solve your problem.
Have you tried these codes?
What you need to do is do it in one step. LikeÂ
1. press TV
2. press and hold SET for two blinks
3. enter 9-9-4
4. tap SET for one blink
5. enter 1-7-4
6. press CBL/SAT key *extra step*
7. pick a key
I require ir codes for an LG LST-6100P HD set top box, all the IR codes as our remote has gone missing therefore we have purchased a universal remote that requires the IR codes
these solutions are not relating to the correct model that being LST-6100P
Still have no solution to
ir codes for an LG LST-6100P HD set top box, REQUIRE ALL the IR codes as our remote has gone missing therefore we have purchased a universal remote that requires the IR codes,
here is a link to the LST-6100P product manual
http://au.lge.com/products/sidemenu/list...
page 6 of the manual clearly show the missing remote.
Cheers.
here is a link to the LST-6100P product manualhttp://au.lge.com/products/sidemenu/list...
Cheers.
Cheers.
ir codes for an LG LST-6100P HD set top box, REQUIRE ALL the IR codes as our remote has gone missing therefore we have purchased a universal remote that requires the IR codes, the universal remote is a PHILLIPS PRONTO 5400
Cheers.
Phillips pronto 5400C
please read the info, the solution is not on e-bay????
