Question about Festina F6721 5 Watch
Is there a Festiva 6571/4 watch diagram
I need to know which button is which
  • 2,334 Answers
Movement number is needed to find the correct watch setting procedure and pushbuttons.
Posted on Dec 17, 2008
Cant set the time dont know button sequence
You can obtain instructions by going to the Amitron web site (amitron.com), put the cursor over "support " and click on "instructions".
You will see a list of watch diagrams; choose the one that looks like yours and download the instructions.
Jan 25, 2010 | Armitron Digital Sport #45/6853SIL Watch...
Athletic wrist watch stuck in 24 hour mode
Maddening, isn't it? Fortunately the solution is here:
http://www.ehow.com/how_5593310_set-athletic-works-watch.html
1 There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
3 Press the start button to change minutes.
4 Press the reset button again to switch to hours.You will know it worked when the hour starts blinking instead of the minutes.
5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
Apr 30, 2009 | Watches
How to set an old Timex digital watch
You may find a solution here:
http://assets.timex.com/manuals/?timexBrand=core
Rate me, please.
Apr 02, 2009 | Timex 27191 Wristwatch
I don't know which buttons are which on the Reizen Watch
Get explanation here:
http://www.accessible-devices.com/atomicwatch.html
Do not foget to rate, please.
Mar 11, 2009 | Watches
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Jan 05, 2009 | Bulova Watch
How to set this watch
I need to know what kind of watch you are talking about Just like every car has a muffler, they are all differant, same goes with watches. Usually by the buttons will be the words "adjust" or "mode"or "set" try pushing one of these and holding down the button for 4-5 seconds (no less) because somtimes it takes that long to start (blinking).Once you get it blinking just push buttons you'll find the ones that do what you need. If you find out that this dos't work, please let me know, there are differant ways to set watche , this is just the most likly way
Jul 08, 2008 | Watches
Need a Manual
It has a HELP function button on the watch that shows you what each "pusher" does and how to access various modes. Hold the top silver button on watch face to access.
Jun 02, 2008 | Fossil Watches
Festina F6721 5 Watch Logo
172 people viewed this question
Top Festina Watches Experts
Ansel Alberto
Ansel Alberto
240cpa
Are you a Festina Watch Expert? Answer questions, earn points and help others
