Question about OKI C5100n Laser Printer
Non-printing gap/line down page
On my OKI C5250 color laser printer, a 3mm thick 'white line' (i.e. non-printing gap), from top to bottom of the page, appears one inch in from the right hand side of the printed page. However, if there is an embedded graphic, the 'white line' does not appear (suggesting a software rather than hardware problem). Can any of you geniuses help me? Thanks
  • 2 more comments
  • Zeb Daniels Mar 11, 2007
    Thanks. In fact I have now solved the problem. A tiny screw had fallen off inside the toner cartridge and fallen to the bottom blocking a small part of the toner 'opening'. Once removed, all is well.
  • Anonymous Mar 19, 2014
    It is like the toner is not coming out of that part of the printer. I replaced the toner cartridge and printer about 30 pages and it is still leaving that line. Is there something I can clean, how do I clean that thing? thanks
  • Anonymous Mar 26, 2014
    C5650
  • Anonymous Mar 29, 2014
    by using tally9 software in this we can't print the head line on top page.How i do?
  • OKI Master
  • 705 Answers
Hey Danzo, This error is usually caused by dirt (usually toner) on the laser lens. There should be a cleaner pad somewhere on your machine (though I am not totally familiar with Oki) that will wipe across the lens. If there is no pad, you may have to find access to the lens and wipe it manually with a tissue or similar
Posted on Mar 11, 2007
When the paper prints, the color is missing in areas. It looks like a streak mark down the page. The black ink is full color, they yellow and cyan have a white, non-printed streak down the center, and...
Inspect the rollers for dirty or damaged surfaces. Clean up any loose toner or other debris in the machine. Note: avoid touching any roller with bare skin; especially in the fuser section or the photosensitive drum in the toner section. Skin oil can cause poor print quality or premature degradation of the roller surface.
Jul 06, 2017 | OKI C3200n Led Printer
We have an Oki B4600 Laser Printer. It is about 6 months old and has started printing vertical white lines through our pages. It originally came with a toner that was half full (I was told) so we quickly...
This is a simple and common problem with many LED print head printers. You just have toner dust on the surface of the print head. Run your finger along the head and all will be well.
Jun 16, 2017 | OKI B4600 Laser Printer
When I print on my Oki Data printer I am getting a line down the middle of my page that is white I suppose because its taking my color away. I just changed the Fuser - how can I fix this - I have projects...
i would try and clean all the l.e.ds which are located as you lift the cover they are conected to the underneath run your finger along them and see if that helps.
Nov 10, 2009 | OKI C5200n Laser Printer
Huge Margin with Kyocera FS 1000+
If the FS-1000 prints too far down the page or leave too much top margin or leaves a gap at the top of the page etc (<- for google searches). This is a problem with the felt pads on the three solenoids/clutch electro magnets that are under the right panel (2 under the engine/button board, 1 under the inner plastic cover, sometimes 4 in total on other kyocera printers). They get compressed over time meaning the metal leavers come into contact with the solenoid meaning they are released too slowly. Simply replace the felt pads with .5mm cardboard or another non-sticky non-metallic material. Too thick and it prints too far up the page.
Sep 28, 2008 | Kyocera Mita FS 1000+N Laser Printer
Oki dp5000 thermal printer
Try cleaning the print head as described in the user guide. There could be old ink clinging to the head. If this doesn't take care of the problem, you could have a burnt element, which is non-fixable problem.
Sep 01, 2008 | OKI DP7000 Thermal Printer
Black smugs on any glossy print
check the fusing area. (where the paper is heated)there is an adjustment for envelop . set it to normal because the pressure on fixing unit is too loose.
Jul 11, 2008 | HP Color LaserJet 2600n Printer
OKI C5250 Printer
My informed guess without seeing print sample is that your oki needs fuser unit replaced. Look at orange rollers should br smooth no wrinkles.
Dec 20, 2007 | OKI C5200n Laser Printer
Oki c5100n printing yellow color offset
What is the stats % of drums if low under 50% change them, soon as you add non Gen you throw a spanner in any attempt to fault find, fix is possible toner more than likely drum/drums, do a print of each colour and change drums as indicated by failure in its colour to print, check transport belt is OK and led heads are clean
Nov 13, 2007 | OKI C5100n Laser Printer
Oki c5100n printing colors offset
posted by Halfwalkeer on Nov 13, 2007 Report abuse
Just replaced the color toner cartridges in the c5100N, two OKI (cyan and yellow) and one non-OKI (magenta). Now it appears that registration is completely off.
When printing an image, there is a band of yellow at the top about 6mm high, and a band of purple (not cyan) at the bottom about 6mm high. It seems that the yellow printing LED array is printing offset. I've verified this with a typical test page that shows yellow blipped up by several mm.
What the hell happened ? How can I fix it ?
Thanks -
Dean.
Comment by Halfwalkeer, posted on Jan 02, 2008 Drums are all at 34%. Please don't tell me that the drums only have a 50% lifetime on them, because that would just suck royally. When you say the problem is most likely drums, in what way ? What could have gone wrong ?
I was able to more or less fix the problem ... It took several iterations of ColorMenu->Adjust Registration followed by Maintenence Menu->Menu Reset, but it was finally able to pull the registration back into line.
I got worried at one point - after it was "fixed" the printer was powered off. Upon powerup again, registration was off by several centimeters ! Another round of the above finally "fixed" it again, but I haven't powered it down again.
It was a cheap printer. Maybe this is why ...
postsolution.gif Post Solution addwq.gif Work Queue sameproblem.gif Have the same problem? X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Solution #1 posted on Jan 02, 2008 0%20stars.png
4d566c2.jpg Soulvisitor
Rank:guru_s.gif Guru
Rating: 86%, 674 votes
Comment by Soulvisitor, posted on Jan 02, 2008 I was thinking about the band of yellow being caused by cleaning blade wearing on drum, drums are garenteed by oki if over 50 %, under that one is on their own ie purchase new if having problems with them
If you can fix problem doing colour calibration then faulty drum is not likely the issue.
Cant stress how many problems are caused by non gen consumables in machines, highly dont recommend their use.
OKI C5100n Laser Printer Logo
350 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Clive
Clive
Timothy Van Der...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
