Question about Hotpoint 24 in. DF55 Free-standing Dishwasher
Dishlex global 300 pot light flashes
My global 300 dishlex doesn't wash properly any more and the pots light flashes all the time, any cycle , eco or not. dishes don't dry.
I have moved in 8 months aog and started using 1 month ago when I broke my collar bone but the last week I have had the above problems. Can anyone help please.Thanks in advance
Tim
  • 3 Answers
SOURCE: DISHWASHER IS LEAKING A LOT OF WATER
I had the same problem with my machine - ie lots of water coming out front about two thirds of the way through the cycle - engineer (local and very reliable) knew as soon as he came in that I had started bying Powerball 5 dishwasher tablets - they produce too much foam (try opening the door during the cycle and see the amount of foam) and it therefore comes out of the overflow parts on the door. I tried Magnum 5 and got the same problem. Now I stick to either Asda's own basic (not the 5) or I buy the Magnum ones and cut them in half. Has never leaked since!
Posted on Aug 25, 2007
  • 25 Answers
SOURCE: not rinsing or drying
This appliance should be on warranty; call seller.
Posted on Nov 16, 2007
SOURCE: HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Posted on Mar 23, 2008
SOURCE: Dishlex Global 500 dishwasher
theres a round plug in the top of dish washer pull it out and clean could be cloged or the bottom spram arm can be pulled out and cleaned aswell
Posted on Sep 12, 2008
SOURCE: Dishlex dishwasher global 300. Dishwasher
Some diswashers have a sump in the bottom with a float switch. If the water level overflows the float will activate the switch which will kill the machine and run the drain pump continuously.
Posted on Nov 05, 2008
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Our Dishlex Global 300 appears to be stuck in Pre-wash. The Eco light is flashing and the water has drained. All other buttons are unresponsive. I have just replaced the seals and handle assembly.
If your getting 120 volts to your dishwasher, I would first ohm out your thermal fuse for continuity, turn your breaker OFF to your dishwasher first.
Jul 24, 2008 | Dishwashers
Dishlex global 300 : dishwasher dispenser won't
Hi just read your posting.The problem could be a faulty dispenser coil ,or the wires to it are faulty or the computer is faulty.Try selecting a normal eco wash and when you push the start button to start the machine hold the button in until the pre wash light turns off.This should make the dispenser activate straight after it fills.The only way to test which part is faulty is with an electrical meter.Have you or can you borrow one.If so then I can guide you step by step in finding the fault.please reply with additional information and I am sure I can help you further.Looking forward to your reply.
May 22, 2011 | Dishwashers
Dishlex Global 300 starts to fill with water, then
ok this sounds like your water has stopped coming in or timed out b4 the pressure switch is activated. hold eco button down, u will hear a beep then a light will come up, keep pushing the button until u see the light.reply and tell me which light has come up, and i can help u fix the problem.
Apr 24, 2010 | Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Jan 25, 2010 | Dishwashers
Dishlex 300 eco light
pump auto starts if overfull
sound like the machine is overfilling
check the level ,u may need to clear pressure line
or it may be bocked with gunk
if u dont know call for service
it shouldn't be a major.
Jun 16, 2009 | Dishwashers
Pump motor runs continuously, ''Eco'' flashes continuously
Hi
soyunds like it flooded the base
You need to dry out the base of the machine thoroughly and it should re set
Feb 14, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Dishlex global 300 dishwasher, eco light flashing sounds like pump noise but not working
Try taking the dishwasher out of its wall space and tipping it back and forth. Apparently the weight of water gathering in some component triggers the 'eco' function. Failing that, last time it happened to my dishwasher i waited a week for the repair guy to arrive, by which time the water had evaporated and there was no longer a problem..
Jul 26, 2008 | Dishwashers
Hotpoint 24 in. DF55 Free-standing Dishwasher Logo
81 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
