Question about Nokia 5200 Cellular Phone
I want to codes - Nokia 5200 Cellular Phone
  • Anonymous Feb 08, 2009
    Samsung propel.
I want to unlock my motorola v600 can u help please?
Posted on May 22, 2009
    Problem Solver:
  • 3 Answers
LG SECRET CODES:
LG all models test mode: Type 2945#*# on the main screen.
2945*#01*# Secret menu for LG
IMEI (ALL): *#06#
IMEI and SW (LG 510): *#07#
Software version (LG B1200): *8375#
Recount cheksum (LG B1200): *6861#
Factory test (B1200): #PWR 668
Simlock menu (LG B1200): 1945#*5101#
Simlock menu (LG 510W, 5200): 2945#*5101#
Simlock menu (LG 7020, 7010): 2945#*70001#
Simlock menu (LG 500, 600): 2947#*
LG-U81XX SPECIAL CODES
Code to read phone version :
- Phone without SIM
- Enter 277634#*# or 47328545454#
- Select 'SW Ver.info'
Code to reset phone :
- Phone without SIM
- Select 'Factory Reset'
Code to enter UNLOCK MENU :
- Phone wit SIM inside
- Enter 2945#*88110#
Test Menu 8330 : 637664#*#
Test Menu 8180 V10a: 49857465454#
Test Menu 8180 V11a: 492662464663#
Test Menu 8130-8138: 47328545454#
Test Menu 8110-8120: 277634#*#
MOTOROLA SECRET CODES
On the main screen type
IMEI number:
*#06#
Code to lock keys. Press together *7
Note: [] (pause) means the * key held in until box appears.
Select phone line - (use this to write things below the provider name):
[] [] [] 0 0 8 [] 1 []
Add phonebook to main menu:
[] [] [] 1 0 5 [] 1 []
Add messages to main menu:
[] [] [] 1 0 7 [] 1 []
Copy SIM memory (phonebook menu):
[] [] [] 1 0 8 [] 1 []
Eng Field options (main menu):
[] [] [] 1 1 3 [] 1 []
Slow (Frequency of search menu):
[] [] [] 1 0 1 [] 1 []
Medium (Frequency of search menu):
[] [] [] 1 0 2 [] 1 []
Fast (Frequency of search menu):
[] [] [] 1 0 3 [] 1 []
Enable EFR:
[] [] [] 1 1 9 [] 1 []
Function :
[] [] [] # # # [] 1 []
Change pin:
[] [] [] 0 0 4 [] 1 []
Unblocking using the "puk" number:
[] [] [] 0 0 5 [] 1 []
There are lots of similar codes exist. If you change the last number to 0 you can deactive that code. The 3 digit number at the middle are from 0 to 999. I put the most interesting codes. (EFR):Enhanced Full Rate Codec.
You can change GSM frequencies to 900/1800 by entering the enginnering model. Following the below steps:
enter menu and press 048263* quickly, then you will enter the secret engineering menu
under "Opcode"
input 10*0*3 for GSM 900
10*0*4 for GSM 1800
10*0*5 for GSM 1900
10*0*6 for dual band GSM 900/1800
10*0*7 for dual band GSM 850/1900
To add extra message space 4 your Motorola C350 C450 C550 or C650, press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.You will receive an extra 50 msgs memory space.Switch phone off and back on.(not tested)
NOKIA SECRET CODES:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that supports WLAN like N80
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
*#7328748263373738# resets security code.
Default security code is 12345
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin#
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.)
Press and hold "0" on the main screen to open wap browser.
Posted on Dec 13, 2008
    Problem Solver:
  • 17 Answers
Try code from Online sites...
Posted on Aug 13, 2011
  • 18 Answers
On the main screen type in:
*#67705646# This will clear the LCD display(operator logo).
For the n/w unlocking code u can get the code from unlocker
Posted on Sep 14, 2009
Nokia 5200 could not be reset even with code 0000 & 12345, seems code is changed
now what to do?
plz
Posted on Sep 07, 2009
Where do I find my link code
Link code for which service provider? See below:
CableVision UR2-CBL-CV04 code: 096
Charter DIGITAL code: 0463
Comcast M1057 code: 0463, 10463
Cox COX code: 0463
Direct TV RC23 code: 10463
Dish Network VIP508 code: 720
Dish Network VIP622 code: 720
Motorola DRC800 code: 0463
One for All URC-6690 code: 0464
Phillips PDVR8 code: 115
Phillips PH5DSS code: 115
Phillips PHDVD5 code: 115
Phillips PMDVR8 code: 115
RCA RCU807 code: 135
Rogers DCT3250 code: 0463
Shaw DCT3416 code: 0463
Sony RM-VL600 code: 8043
TiVo HD code: 0091
TiVo SERIES 3 code: 0091
Oct 13, 2015 | Proscan 26LB30QD 26 in. LCD HDTV
Master reset code for nokia 1202-2 IMEI # 358016/03/449348/0 CODE:0562271
Nokia Mobile Sets Secret Codes
Mobile Set: All Nokia Mobile Sets
Use For: Default Security Code.
Code: 12345
Mobile Set: Nokia Mobiles
Use For: Turn On Enhanced Full Rate Codec.
Code: *3370#
Use For: Turn Off Enhanced Full Rate Codec.
Code: *#3370#
Use For: Turn On Half Rate Codec.
Code: *4720#
Use For: Turn Off Half Rate Codec.
Code: *#4720#
Use For: Show Software Version.
Code: *#0000#
Use For: Also For Show Software Version.
Code: *#9999#
Use For: Show IMEI (International Mobile Equipment Identity).
Code: *#06#
Use For: Show Lock Status of Your Nokia Mobile Set.
Code: #pw+1234567890+1#
Use For: Show Lock Status of Your SIM.
Code: #pw+1234567890+4#
Use For: Show Security Code of Your Mobile Phone.
Code: *#2640#
Use For: Reset Game Score And Timer.
Code: *#73#
Samsung Mobile Sets Secret Codes
Mobile Set: All Samsung Mobile Sets
Code: *#06*
Mobile Set: Samsung 811
Use For: Unlock code / Change roaming code / ID.
Code: 47*869#08#9
Mobile Set: SGH-600 , SGH-2100
Code: *#9999#
Use For: Show Software Version (instructions).
Code: *#0837#
Use For: Show Serial Parameters.
Code: *#0001#
Use For: Activates the smiley when charging.
Code: *#9125#
Use For: Battery status (capacity, voltage, temperature).
Code: *#9998*228#
Use For: Program status.
Code: *#9998*246#
Use For: Change Alarm Buzzer Frequency.
Code: *#9998*289#
Use For: Debug screens.
Code: *#9998*324#
Use For: Watchdog.
Code: *#9998*364#
Use For: EEPROM Error Stack - Use side keys.
Code: *#9998*377#
Use For: Trace Watchdog.
Code: *#9998*427#
Use For: Change LCD contrast - Only with version G60RL01W.
Code: *#9998*523#
Use For: Memory status.
Code: *#9998*636#
Use For: Jig detect.
Code: *#9998*544#
Use For: SIM File Size.
Code: *#9998*746#
Use For: SIM Service Table.
Code: *#9998*77
Jun 03, 2012 | Nokia Cell Phones
Remote code for 26" LCD Dynex tv
Remote code for who? Dish network? Comcast?
Cox COX code: 0463
TiVo HD code: 0091
Jun 06, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Hi I need PHILIPS P568 IMEI 351265412565412 unlocking codes.... please help me.
Codes for imei 351265412565412, model Philips P568 Unlocking codes: Code for NCKKN is : **00012*39094694# Code for NSCKN is : **00022*35077294# Code for SPCKS is : **00032*36089094# Code for CKCCK is : **00042*37037294# Code for PCKKP is : **00052*33054694# Code for XXXXX is : **00062*37035294# Code for XXXXX is : **00072*33775294#
Repair codes: Code for NCKKN is : **00013*43714762# Code for NSCKN is : **00023*43070742# Code for SPCKS is : **00033*43251752# Code for CKCCK is : **00043*43072702# Code for PCKKP is : **00053*43718722# Code for XXXXX is : **00063*43872702# Code for XXXXX is : **00073*43878442#
New Algo Codes Unlocking codes: Code for NCKKN is : **00012*7563374371217567# Code for NSCKN is : **00022*7161634379412367# Code for SPCKS is : **00032*7262814378202967# Code for CKCCK is : **00042*7367634371472367# Code for PCKKP is : **00052*7969374375277567# Code for XXXXX is : **00062*7367434371470367# Code for XXXXX is : **00072*7931434377110367#
Repair codes: Code for NCKKN is : **00013*2159969789537257# Code for NSCKN is : **00023*2185567789015457# Code for SPCKS is : **00033*2103668789074247# Code for CKCCK is : **00043*2185763789017417# Code for PCKKP is : **00053*2159365789531217# Code for XXXXX is : **00063*2165763789817417# Code for XXXXX is : **00073*2165337789813157#
May 17, 2010 | Belkin Cameras
QUIERO SABER CUAL ES EL CODIGO PARA UNA TELEVISION SHARP SP
aver si te ayuda esto
Code 000 for RCA TV Code 003 for RCA TV Code 004 for RCA TV Code 005 for RCA TV Code 006 for RCA TV Code 007 for RCA TV Code 019 for RCA TV Code 054 for RCA TV Code 055 for RCA TV Code 082 for RCA TV Code 096 for RCA TV Code 098 for RCA TV Code 099 for RCA TV Code 100 for RCA TV Code 101 for RCA TV Code 102 for RCA TV Code 103 for RCA TV Code 129 for RCA TV Code 179 for RCA TV Code 181 for RCA TV Code 188 for RCA TV Code 190 for RCA TV Code 196 for RCA TV Code 202 for RCA TV Code 203 for RCA TV Code 212 for RCA TV Code 215 for RCA TV Code 233 for RCA TV Code 281 for RCA TV Code 352 for RCA TV
estos son los codigos
May 05, 2010 | RCA RCU600M Remote Control
How to get free GTA SanAndreas CHEAT CODES?
here are all the cheat codes
Adrenaline Mode
Cheat code: MUNASEF Aggressive Drivers
Cheat code: YLTEICZ All Cars Explode
Cheat code: allcarsgoboom All Cars Have Nitro
Cheat code: COXEFGU or SPEEDFREAK All Green Lights
Cheat code: ZEIIVG Always Midnight
Cheat code: NIGHTPROWLER or XJVSNAJ Beach Party
Cheat code: CIKGCGX Black Traffic
Cheat code: IOWDLAC Blow Up All Cars
Cheat code: CPKTNWT Boats Fly
Cheat code: AFSNMSMW or FLYINGFISH Cars Float Away When Hit
Cheat code: BSXSGGC or BUBBLECARS Cars Fly
Cheat code: RIPAZHA Chaos Mode
Cheat code: STATEOFEMERGENCY Clear Wanted Level
Cheat code: ASNAEB Country Vehicles and Peds, Get Born 2 Truck Outfit
Cheat code: BMTPWHR Elvis is Everywhere
Cheat code: ASBHGRB or BLUESUEDESHOES Everyone is Armed
Cheat code: FOOOXFT Faster Clock
Cheat code: YSOHNUL Faster Gameplay
Cheat code: PPGWJHT or SPEEDITUP Fat
Cheat code: BTCDBCB Foggy Weather
Cheat code: CFVFGMJ Full Weapon Aiming While Driving
Cheat code: OUIQDMW Funhouse Theme
Cheat code: CRAZYTOWN or PRIEBJ Gang Members Everywhere
Cheat code: MROEMZH or ONLYHOMIESALLOWED Gangs Control the Streets
Cheat code: BIFBUZZ or MROEMZH Have a Bounty on Your Head
Cheat code: BAGOWPG Have Jetpack
Cheat code: ROCKETMAN or YECGAA Have Parachute
Cheat code: AIYPWZQP Health, Armor, $250k
Cheat code: HESOYAM Hitman In All Weapon Stats
Cheat code: NCSGDAG or PROFESSIONALKILLER Huge Bunny Hop
Cheat code: CJPHONEHOME or JHJOECW Increase Wanted Level Two Stars
Cheat code: OSRBLHH Infinite Ammo, No Reload
Cheat code: FULLCLIP or WANRLTW Infinite Health, Except for Explosions and Falls
Cheat code: CAINEMVHZC Infinite Oxygen
Cheat code: CVWKXAM Invisible Car
Cheat code: WHEELSONLYPLEASE or XICWMD Large Health Boost
Cheat code: BAGUVIX Max All Vehicle Skill Stats
Cheat code: NATURALTALENT Max Muscle
Cheat code: BUFFMEUP or JYSDSOD Max Respect
Cheat code: OGXSDAG or WORSHIPME Max *** Appeal
Cheat code: EHIBXQS or HELLOLADIES Mega Jump
Cheat code: KANGAROO or LFGMHAL Mega Punch
Cheat code: IAVENJQ or STINGLIKEABEE Never Get Hungry
Cheat code: AEDUWNV Never Wanted
Cheat code: AEZAKMI or IFIRSTDOZ Ninja Theme
Cheat code: AFPHULTL or NINJATOWN No Wanted Level
Cheat code: TESTEDUCATIONALSKILLS Orange Sky 21:00
Cheat code: OFVIAC Overcast Weather
Cheat code: ALNSFMZO Peds Attack Each Other, Get Golf Club
Cheat code: AJLOJYQY Peds Attack You With Weapons, Rocket Launcher
Cheat code: BGLUAWML Perfect Handling
Cheat code: PGGOMOY or STICKLIKEGLUE Pink Traffic
Cheat code: LLQPFBN Rainy Weather
Cheat code: AUIFRVQS Recruit Anyone - 9mm
Cheat code: SJMAHPE Recruit Anyone - Rockets
Cheat code: ROCKETMAYHEM or ZSOXFSQ Reduced Traffic
Cheat code: GHOSTTOWN or THGLOJ Riot Mode
Cheat code: IOJUFZN Sandstorm
Cheat code: CWJXUOC Six Star Wanted Level
Cheat code: BRINGITON or LJSPQK Skinny
Cheat code: KVGYZQK Slower Gameplay
Cheat code: LIYOAAY or SLOWITDOWN **** Magnet
Cheat code: BEKKNQV Smash n' Boom
Cheat code: JCNRUAD Spawn Bloodring Banger
Cheat code: CQZIJMB Spawn Caddy
Cheat code: RZHSUEW Spawn Dozer
Cheat code: EEGCYXT Spawn Dozer
Cheat code: ITSALLBULL Spawn Hunter
Cheat code: OHDUDE or OHDUDE Spawn Hydra
Cheat code: JUMPJET or JUMPJET Spawn Monster
Cheat code: AGBDLCID or MONSTERMASH Spawn Quad
Cheat code: AKJJYGLC or FOURWHEELFUN Spawn Racecar
Cheat code: PDNEJOH or VPJTQWV or VROCKPOKEY Spawn Rancher
Cheat code: JQNTDMH Spawn Rhino
Cheat code: AIWPRTON Spawn Romero
Cheat code: AQTBCODX or WHERESTHEFUNERAL Spawn Stretch
Cheat code: CELEBRITYSTATUS or KRIJEBR Spawn Stunt Plane
Cheat code: FLYINGTOSTUNT or URKQSRK Spawn Tanker Truck
Cheat code: AMOMHRER Spawn Trashmaster
Cheat code: TRUEGRIME or UBHYZHQ Spawn Vortex Hovercraft
Cheat code: KGGGDKP Suicide
Cheat code: GOODBYECRUELWORLD or SZCMAWO Sunny Weather
Cheat code: AFZLLQLL or PLEASANTLYWARM Taxis Have Nitrous, L3 Bunny Hop
Cheat code: VKYPQCF Thunderstorm
Cheat code: MGHXYRM or SCOTTISHSUMMER Traffic is Cheap Cars
Cheat code: BGKGTJH or EVERYONEISPOOR Traffic is Country Vehicles
Cheat code: FVTMNBZ Traffic is Fast Cars
Cheat code: EVERYONEISRICH or GUSNHDE Very Sunny Weather
Cheat code: ICIKPYH or TOODAMNHOT Weapon Set 1, Thug's Tools
Cheat code: LXGIWYL Weapon Set 2, Professional Tools
Cheat code: KJKSZPJ or PROFESSIONALSKIT Weapon Set 3, Nutter Tools
Cheat code: UZUMYMW
May 02, 2010 | Rockstar Games Grand Theft Auto: San...
We have a RCA remote and need the codes for an Emerson TV. Can you help?
The codes to program an RCA RCU300WBL remote control for an Emerson TV are:
Code 004 for Emerson TV Code 006 for Emerson TV Code 012 for Emerson TV Code 023 for Emerson TV Code 025 for Emerson TV Code 026 for Emerson TV Code 029 for Emerson TV Code 030 for Emerson TV Code 033 for Emerson TV Code 035 for Emerson TV Code 036 for Emerson TV Code 037 for Emerson TV Code 038 for Emerson TV Code 041 for Emerson TV Code 042 for Emerson TV Code 043 for Emerson TV Code 046 for Emerson TV Code 047 for Emerson TV Code 048 for Emerson TV Code 049 for Emerson TV Code 073 for Emerson TV Code 123 for Emerson TV Code 162 for Emerson TV Code 171 for Emerson TV Code 177 for Emerson TV Code 179 for Emerson TV Code 191 for Emerson TV
If you have a different RCA, remote control you can post more details, or take a look at the RCA Code Finder Website at:
http://remotefinder.rca.com/default.aspx?site=rca
Aug 08, 2009 | RCA RCU300WBL Remote Control
Need code for phillips big screen lost manual for jumbo remote
Code 002 for Philips TV Code 003 for Philips TV Code 004 for Philips TV Code 008 for Philips TV Code 012 for Philips TV Code 019 for Philips TV Code 062 for Philips TV Code 068 for Philips TV Code 069 for Philips TV Code 075 for Philips TV Code 076 for Philips TV Code 086 for Philips TV Code 087 for Philips TV Code 088 for Philips TV Code 130 for Philips TV Code 132 for Philips TV Code 134 for Philips TV Code 167 for Philips TV Code 183 for Philips TV Code 196 for Philips TV
Jul 12, 2009 | RCA RCU600M Remote Control
Nokia 5200 Cellular Phone Logo
1,426 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
