Question about Sherwood RD-6500 Receiver
How do i change it to a 5.1 stereo unstead of a 2.1 stereo
    Brigadier General:
  • 8,546 Answers
Not knowing what input, source or material we're talking about here I have to hipshoot...
Your digital source will be the determinant of the highest non-simulated surround mode you can select.
http://www.sherwoodusa.com/pdf/RD-6500(English).pdf
Posted on Apr 04, 2009
    Genius:
  • 1,199 Answers
Are you running optical or digital connections if not you can not get 5.1 sound! If you are useing one of those types of cables then hit the select button and hit select then the dts option! or auto in option! this should fix ya!
Posted on Dec 13, 2008
Do I need to mix oil with the gas to run the snowblower?
No. Most engines that take a load like pushing and throwing snow use a 4 stroke engine that has oil in the motor unstead of mixing gas like a two stroke.unless if specified on the gas cap or a sticker on the machine hope this helps oh change oil every two snow seasons or depends on how much u use the blower
Nov 22, 2015 | Garden
I have a yamaha speaker yst-m7 but with no hookups I need all the wire
Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum 3.5 mm. stereo mini jack x 2.
3.5 Stereo mini plug cable.
RCA Pin plug cable.
3.5mm stereo mini jack x 2.
3.5 stereo mini plug cable
RCA Pin plug cable
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
May 20, 2011 | Yamaha YST-M7 Computer Speakers
I have a 2003 honda element and changed the battery but do not have a code to put in to get my radio to work.how do i get the code and how do you put it in.Thanks
1. First, you need make sure your stereo is off, then hold down the 1st & 6th preset buttons for the radio while turning the stereo back on.
2. A batch of 8 numbers (your stereo's serial code) will appear for about 20 seconds. Write them down.
3. Contact your local honda dealer and let them know you need the 5-digit code to unlock your stereo and then give them the 8-digit serial code you got from the 2nd step. They will give you the 5-digit code that you can then enter into the stereo by again turning on the stereo and pushing the according preset buttons.
4. The stereo will give you 10 tries before it locks you out as a saftey feature and then you will have to wait an hour or disconnect the battery and try again. Hopefully you can enter the code in fewer than 10 tries anyway.
Feb 28, 2011 | Element Skateboards Honda Element...
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
How do you install an audio output device?
this depends on what kinda audio output you want to install ..but the general idea is to get the audio signal from the computer from the green out in the back on the sound card (it is a 3.5 jack ) ..and there is the stereo out-put for the computer's sound..It can be amplified in any device that has a stereo input on 3.5 jack ..
if you want something more complicated..the map of the out-put (the scheme) will be shown in the sound manager (of teh driver ) ..when you make the output changes..This is on a color code..and can be 2+1...3+1..4+1..and the surround 5+1..when you choose surround 5+1 from the sound manager ..it is shown all 3 outputs and the role they play ..bass+center ...Front ...and rear ..they are 2by 2 stereo paired on left and right ..
Sep 02, 2010 | HP PAVILION A6230N DESKTOP PC
I need a 1992 mercedes 400 se sparkplug wiring diagram
most older mercedes benz firing orders are written on valve cover. I beleive it will tell you on one of the rear intake manifold runners. the way a benz engine cylinders are marked they read-1 2 3 4 on the l(passanger side) and 5 6 7 8 on the r(drivers side) unstead of 1 3 5 7 and 2 4 6 8. maybe this will help you good luck getting the plug sires back into the plastic troughs.
Apr 12, 2009 | 1992 Mercedes-Benz Mercedes Benz S Class
Wiring speakers to amp for both 5.1 channel and 4 speaker listeni
I am assuming that you want to have a normal stereo ( 2 channel ) from, CDs, Radio Etc.. To be able to play from all of your speakers for a more surrounding sound experience, for parties or just more sound. I am also assuming you currently have your speakers wired like standard 5.1 in the bottom diagram on page 19 of your receiver manual. To change the way the sound is coming from your speakers you will need to refer to the “Sound Field Programs” part of your manual starting on page 52. You will want to be in the input source you would like to change “ie: radio” Let assume you want to change radio, once the radio is on; Rotate the “N” Program selector, (or press “5” and then “12” Prog < /> repeatedly ). You will want to change to program, “7ch Stereo” this should take your 2ch signal and send it to all connected speakers. If this does not work, please let me know.
Feb 23, 2009 | Cerwin Vega E-78 Main / Stereo Speaker
Help on my HDTV
Make sure that you have the HD cables for the 360 (red, blue, green). After that, make sure the selector switch ON the CABLE is set to HD. Hope this helps :)
Ryunn
Jun 14, 2008 | Televison & Video
Help!!!!!
Hi Linda,
It is showing two because the source of the sound that you are listening is probably stereo only thus only two sound comes out. You could try to change the mode to 5 channel stereo or prologic or dts-6channel mode in the surround mode to hear your sound in all 5 speakers. best thing to do is watch a dvd which would use all 5.
Regarding a/b yes if your receiver supports it which i think it does there should be place for it in the back of the receiver.
good luck
smeags.
Feb 19, 2008 | Audio Players & Recorders
Sherwood RD-6500 Receiver Logo
97 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
