Question about HP PSC 2175 All-In-One InkJet Printer
Printer won't work
My printer is actually hp psc 2170 all in one (you only have 2175 on your list choice). I can't get my printer to print since I copied a photo. All the screen says is "1 copy / 100%" and I can't get ANY buttons to work, not even the on/off button.
  • Anonymous Jan 06, 2009
    I have the same problem. Unplugging the printer and letting it go through it's startup does not help.
    I have the same problem. Did the unplug and restart but didn't help. Does anybody have another solution?
    Scholar:
  • 78 Answers
Unplug the printer from the power and replug it in, the printer will go through its post(the little dance they do when they start up) and should come back to a ready status.
Gremlin11
Posted on Dec 13, 2008
Can't cancel a HP PSC 750 Printer print job.
Right click on MyComputer and click Manage. Then go to Services and Applications and then Services. Find the Print Spooler services in the list and right click to stop it. When it is stopped try to cancel the document again. Then start the print spooler service again.
Regards,
nicolasiac
Feb 12, 2010 | HP PSC 750 All-In-One InkJet Printer
Problems with HP psc 1315 and Vista
Let windows vista load the printer driver and it will work.
its a try that worked for me,,,
vote please thanks
May 09, 2009 | HP PSC 1315 All-In-One InkJet Printer
I have deleted my hp psc 1315 printer, my Compaq
go to hp's website and download the software for your printer it's really easy and doesn't cost anything.
Mar 01, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP psc 1215 does not print
I did it on my own. I just uninstalled the printer and reinstalled using the installation cd. Although the cd was old (from when I bought the printer and now I have vista) it works now. Good luck all.
Jan 10, 2009 | HP Photosmart 3210 Printer
My printer will not align the print cartridges
Okay i used to have the same problem, but all you have to do is this:
1.  Plug in HP PSC 2110xi All-in-One to the computer 2.  Turn the printer on 3.  Unplug the power chord from the printer (don't turn it off before you do this) 4.  Wait at least 45 seconds (and actually wait 45 seconds, don't guess) 5.  Plug the printer power chord back into the outlet 6.  If the printer does not automatically turn on, turn it on 7.  When it asks you to align cartridges, press enter, and follow the directions
This time it should work :]
Dec 10, 2008 | HP PSC 2110 All-In-One InkJet Printer
Hp psc 1100/1200 all-in-one does not scan with vista..
I had the same problem. Click Start, Windows Photo Gallery, from that screen, you can select import from scanner. The 1200 series printer should be a choice to select. You are then able to preview the image or document, then press scan. I found this out through the HP support website.
Aug 07, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 1315 all in one printer
George..which printer do you actually have..there are two model numbers listed..
Feb 19, 2008 | HP PSC 1210 All-In-One InkJet Printer
Vista compatability download for my HP PSC 1500 all-in-one series
Yes the download are the same for all the models..this is the link to download the driver for vista...
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&softwareitem=mp-37852-1&os=219&product=428800&
I hope this helps
**Please rate accordingly**
Thank You
Computerrep
Jan 30, 2008 | HP PSC 1510 All-In-One InkJet Printer
Hp psc 1210 all in one
Please follow the below given instructions to resolve the issue.
Please click on Start >> Programs >> HP >> HP Director.
Click on Settings >> Print Settings >> Printer Settings.
Click on Quality Tab at top of Printer Settings Window >> Set the Paper type as " Plain Paper " .
Click on Layout Tab at top of Printer Settings Window > Set the Paper size that you are using >> Click on Apply and then on OK.
Try Printing, that should resolve the issue that you are experiencing with.
If the issue still persists, try installing alternate drivers by following the below given instructions.
Installing the Alternate drivers:
1. Right click on My Computer, select Explore and then goto Control Panel, and then select Printer and Faxes.
2. Double-click the Add Printer icon. Click Next.
3. When prompted, choose Local, and then click Next.
4. In the Manufacturers list, choose HP.
5. In the Printer list, choose the HP Deskjet 870C printer, and then click Next.
6. Choose the port as parallel port, and then click Next.
7. The printer name should be listed as HP Deskjet 870C Printer.
8. Click No when the "Do you want your Windows based programs to use this printer as your default printer?" message appears. Then click Next.
9. Click No when the "Would you like to print a test page (recommended)" message appears. Then, click Finish.
Configure the alternate printer driver
1. Right-click the HP Deskjet 870C printer icon placed in the Printers window.
2. Select the Properties menu item.
3. Select the Details or Ports tab.
4. Select the DOT4_00x (where the "x" represents any digit) port from the Print to the Following Port list.
NOTE: The All-in-One model number should appear as part of the port destination.
5. Leave the printer identified as HP Deskjet 870C printer, and click the Apply button.
6. Close the Printer Properties window.
If Deskjet 870c is not listed, you may even try with Deskjet 990c or 550c
Hope that above information will work.
Regards,
Lawrence
Jan 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP 2210 xi printing problem - alignment
Try your question here http://www.techsupportforum.com/hardware-support/printer-support/49664-hp-psc-2210xi-problem.html
May 14, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
161 people viewed this question
Seeker5211
Seeker5211
