Question about Miele Novotronic H350-2B Electric Single Oven
Oven Door Doesn't Completely Close
The door on my oven has never completely closed and sealed. There is roughly one centimeter of slack between the door's closed position and the fully sealed position. I've removed the door and replaced it, and it appears to be fully seated in the hinge mechanism. I can't see any adjustment. Any ideas?
  • 4 more comments
  • Anonymous Apr 28, 2008
    I have the same with my Miele oven and have just removed and rehung the door. The top of the door sticks out by 1-1.5cm and I do not have this problem with the top. Any ideas?
  • Anonymous Mar 16, 2014
    B900ss b oven door not closing fully
    oven door is locked in closed position
  • Anonymous Mar 19, 2014
    I can't get me oven door back on after removing it for cleaning. The hinges have snapped back into place and I can't get them to the 'door removal position'.
  • Anonymous Mar 22, 2014
    The Oven Door has dropped slightly on the right hand side and catches when fully open. Is there any way to adjust/raise the height of the door ?
  • Anonymous Mar 24, 2014
    Door stays partly open unless you lean against it. No spring tension.
    President:
  • 1,462 Answers
No adjustment. probably needs new hinges - hinge spring gone slack
Posted on Mar 20, 2007
Oven door won't close
remove door completely then reinstall door
Feb 21, 2014 | Ovens
The door will not close completely
Hi someone lifted up on the door this ishowyou remove oven doors open the door about 1/3 then push down towards the floor it should go back into place, if not you may have to remove it clean the hinges then re-install it , I don't think anyone could have bent the hinges cause that would b very hard to do, but i have seen it done before , get back to me Frank
Dec 04, 2011 | Thermador Professional Series PO301...
Oven door won't close completely
You will probably have to replace the springs I doubt if they can ve fixed. you can open the door all the way and you will see a hole in the spring just inside the door. you can stick a nail in that hole, both springs that will hold the door open and you can lift the door out and check the springs I will tell you to have patience its not easy.
Apr 21, 2010 | Kenmore 47702 / 47704 / 47709 Electric...
The oven door (Model SMW272) does not close completely. It may need an adjustment or a new seal?
Generally speaking, if a oven door does not close properly, and it is a drop down door, then it usually due to weak springs in the hinges.
There is no adjustment provided, so the only solutiom is to replace both door hinges.
Please rate my nsolution.
Thankyou.
Jan 28, 2010 | Thermador SMW272 Electric Double Oven
Re Neff B1451 oven door not sealing against oven body at top
If you take the hinges off, you can fit some washers between the hinges and the door to make it close it further. Probably not as good as new hinges, but cheaper. 2mm of washers will close a 5mm gap
Dec 30, 2008 | Neff B1451 Single circotherm plus Electric...
Lower oven door
here is my video might help you.
Mar 02, 2008 | KitchenAid KEBC277 Electric Double Oven
Oven Door will not close properly
Don't buy Bosh. This is a common problem with them and they are not interested in a fix (ie a thinner door seal would help or adjustment to springs...
Feb 11, 2008 | Ovens
Miele Novotronic H350-2B Electric Single Oven Logo
1,946 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
