Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Ghost Files I have a Sansa c250 player. A couple of months ago I purchased a Micro SD card for the expansion slot, and I believe this is where the trouble started. When I've added or removed songs--either to the fixed drive on the c250, or the Micro SD card--some of the files are still showing up on the playlist. In some cases, there are duplicate copies of the same title listed on the c250, but the songs I deleted are not there when I view the files from my computer. Do I need to reinstall something or format it to erase some obsure file that is retaining old information? And, if so, how do I format it without erasing necessary system files, or where do I find what I need to install? Thank you for your help!!
  • d1ckfac3 Jan 01, 2009
    i just got a sansa c250 refurb. i loaded it up with mp3's (load A) when i first got it, connecting to my computer via usb, no problem. i listened to them for a few weeks, but then it came time to change things up. i deleted the old mp3 files and loaded it up with new ones (load B) , which appear in the file folder when the player is connected to the computer. once disconnected, (load A) file names appear in the player. when you try to play one of the songs, it gives you an error: 'bad file' appears on the screen and sometimes it locks up altogether. when you reconnect to the computer, the (load B) files still appear.
  • 8,596 Answers
I would run the Sansa Recovery Tool for the c200 series - it will erase/format all the songs without deleting system files - it is available from Sandisk's website.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Can I attach an 8 GB Micro SD Card in the expansion slot of my Sansa e250? If not, what is the maximum storage size it supports?
The e250 uses microSD cards, not microSDHC cards. The maximum size of microSD cards is 2GB. Anything larger are microSDHC cards.
Mar 16, 2010 | SanDisk Sansa e250 MP3 Player
Sansa MP3 recognizes 8 gb micro sd card as a 4 gb card
your reader does not support the 8gb device, look for firmware upgrade for the reader
Jun 29, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 doesen't detect 4gb micro sdhc card
I will have to double-check the documentation that came with that specific MP3 player, but I know that some Sansas will only support upto 2 GB in the expansion slot.
Jun 09, 2009 | SanDisk Sansa e260 MP3 Player
How do I use the SanDisk adaptor and the SanDisk 2GB microSD
The micro card (the smaller one) can be used alone in a port that accepts (microSD ports)such as those on a Sansa c240, c250, e250 etc.
If you have a regular SD slot (larger than microSD) then you plug the micro card in the adapter and plug the whole into a regular SD slot.
Plug the card in your computer and copy paste the files. Or plug the micro card in an MP3 player that accepts it and use you music transfert software.
You only have one card (the micro SD one), which you can use in two possible slots.
Hope it helps.
May 19, 2009 | SanDisk 2GB microSD Memory Card
Micro sd memory card not recognized
Make sure your usb mode is msc plugin your sansa and go to my computer click on Sansa folder and you should see your removable disk this is your expansion card
Apr 17, 2009 | SanDisk Sansa e260 MP3 Player
Sansa c250 frozen
try to dry it using a brush and medical alcohol and a hair dryer and check if it would give u result
Oct 09, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa c250 Micro SD card not recocnised
You need to create a folder named MUSIC on the MicroSD card to copy your MP3 files into
Mar 28, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Computer says no files on device
Open device manager under the Control Panel to view hardware and devices. There should be a tab under portable devices that recognizes the Sansa c250. If their is a yellow exclamation point, then most likely the device has stopped working. Right click on it, and uninstall the device. Unplug your Sansa, wait a couple seconds, then plug it back in. Let it do its thing. If this does not solve your problem, then you should deffinately call the manufacturer.
Sep 22, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
119 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
