Gas not lighting so not heating
The system is supposed to have an igniter instead of a pilot light. The gas is not lighting. I also do not smell gas.
    Novelist:
  • 124 Answers
DON''T FIDDLE WITH GAS. CALL A SUPPLIER OF THE UNIT YOU HAVE AND ASK FOR THE MOST COMPITENT SEVICER THEY CAN RECOMMEND. SOUNDS LIKE A BAD IGNITOR TO ME.
Posted on Dec 13, 2008
Gas smell when igniting burner.
Hi Jerry
Warning : Gas systems are generally safe but any gas smell should always be investigated by a certified technician as you can never be too safe.
That being said, let me try to assist you as best I can from my experience with gas appliances.
If the smell has been there since you bought the unit, it is probably the pilot you are smelling. Generally, a pilot light is first ignited using either an electro-mechanical switch or using electricity to create a spark.
While ignition is taking place, a small amount of gas is allowed to flow through the ignition pilot nozzle. The spark is meant to ignite the pilot flame. When the pilot flame is lit, a thermocouple is heated up and then allows gas to flow to the main burners. The gas in the main burners then ignites directly from the pilot flame. This is generally how gas burners work but there are many types of equipment and not all of them work on the same principles.
Generally when you smell gas before igniting the main burner but detect no smell after the main burner is on, it has to do with problems in the ignition stage. This could be caused by a number of things but often the ignition probe is the problem. The ignition probe arcs a spark between two probes or between a probe and the burner which is meant to ignite the pilot gas nozzle (or in some cases ignites the main burner directly). Everytime this spark is made, a small amount of carbon forms at the connection point of the sparks. The carbon can build up over time and cause difficulty sparking the ignition of the pilot burner. Spilled food can also cause this or speed up the buildup of carbon.
If the gas can't ignite the pilot immediately, the pilot keeps allowing gas to pass into the air until ignited which is what you could be smelling. Check to see how long after you try to start the burner does it actually ignite. More than a couple of seconds and you will be smelling the gas that escaped without being burned off.
You can try disconnecting the unit from mains power and cleaning the ignition probes on each burner. If the unit has a mechanical starter you should take extra care not activate it during cleaning as you could get a electric shock. Clean the probe with a damp cloth or paper towel and don't use any cleaning agents.
If this does not eliminate the smell you are getting before ignition, you should get a technician to test the unit. The explanation above is also very general as I don't know what specific system you are using so use the explanation given as general knowledge only and get a technician to perform the repairs.
Jul 17, 2016 | Kitchen Ranges
Can't seem to access Hotpoint Stove Pilot Light?
Your range uses electronic ignition, not pilot lights. For surface burners the igniter sparks when the gas valve is turned to the "light" position. All burners should spark when any gas valve is in the light position. For the oven the ignitor is also electric but does not spark but rather heats up or glows. What is the problem with your range?
Nov 30, 2014 | Hotpoint RGB745 Gas Kitchen Range
I have a Maytag gas over/stove, Model number MGR5755QDW. The broiler heats, but the oven does not. What are the possible causes and how do I troubleshoot?
If you are having problems with the oven, the first thing to do is figure out if you have a pilot light system or a glow bar system.
Problems with the pilot light system.....The flame has gone out, re-light the pilot. The pilot flame will not light - possible oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's a internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Problems with the glow bar system.....You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works -click here.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Jan 26, 2010 | Kitchen Ranges
Blower but no heat, no gas or no pilot ignition?
The pilot has to be lit.And to do so turn the knob to pilot.Then press it down and gas will come threw the pilot,then light the pilot,and hold the button down for about 45 seconds,count slow.The pilot has to heat the thermocouple up before the pilot light will stay on.Once it stays lit,turn the knob to on.
Oct 20, 2009 | Heating & Cooling
Turn oven on and smell gas will not light
I had the same problem when I bought a house with a gas range. If you wait ten seconds or more there is a unit that heats up and ignites the range instead of a pilot. You will hear a click every few seconds then while it ignites the stove. I was afraid to wait because I smelled the gas. But after paying someone $100 for a service call that is what happened.
It is electrical and in the back of my stove there is a cord that goes in the wall. make sure it is plugged in. It also affects the burners however they have a light option on the dial, the oven does not.
Hope that helps.
May 31, 2009 | Tappan TGF320 Gas Kitchen Range
Maytag gas oven doesn't heat, but oven's pilot light is on.
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Mar 03, 2017 | Ovens
The heater in my central heating is not getting turn on but the fresh air and cooling is getting turn on
Check the pilot light.Older standing pilot systems use thermocouples to verify the pilot is burning before the gas valve opens.If the pilot wont stay lit replace the thermocouple.
Newer systems light the pilot.On a call for heat the igniter lights the pilot. When the heat is verified the gas valve opens . Some systems use an circuit board with flashing led lights to help troubleshooting.
Jan 11, 2009 | Heating & Cooling
Smell gas no heat
hi thanks for the question yes this problem is very popular in gas ovens even though theigniter lights up its not hot enough to ignite the gas and also with this problem it wont reach the set tempeture thanks the appliance doc
Aug 29, 2008 | Tappan TGF320 Gas Kitchen Range
Oven won't heat
try replacing the oven igniter/ glow bar the thing you see light up it sounds like it is weak you can tell if it glows with a white color in the bar it should glow a bright orange color
Aug 28, 2007 | Tappan TGFS_63 Gas Kitchen Range
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
