Question about Funai F413TA 13" TV
Funai 13" TV with VCR Combo
My original remote control got broken, and cracked and finally just quit working. I purchased a new factory replacement model, but it does not work at all. It won't turn on set or change channels or anything. So neither the old remote or the new one work. Is it possible that the remote feature on my set is broken? Where is it located? How can I check it to see if the problem is in the remote or in the TV itself?
    Novelist:
    Champion:
  • 236 Answers
You can check the remote by holding it very near an AM radio. Have the radio turned on and tuned about the middle of the AM broadcast band and push the button on your remote. You should hear a popping sound come through your radio speaker. If you can't hear anything, try moving the remote around and tuning the radio. If all fails then the remote is not working. If you DO hear the popping sounds then you have a problem with the IR receiver in you TV. There's a little plastic "window" in the front of your set where the IR signal enters. If dust has collected on the inside this could block the IR signals from entering. Also the IR receiver itself may have gone bad. The remote for this TV has to be an exact replacement. I've had this problem too by trying a substitute. Stargazer
Posted on Mar 17, 2007
I Need A Remote Code For An Emerson EWC19T5 and One For All URC 4021 remote
Hello
Setup codes for Emerson Tv with One For All URC-4021 remote control are:
0154, 0236, 0463, 0180, 0178,
0171, 0623
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, a Motorola cable
box, and an RCA VCR.To control devices other than the default brands,perform
the following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next
NOTE: If the device does not have a POWER key, press PLAY
OK.
Sep 26, 2011 | One For All URC-3021 Remote Control
I have no remote for the tv Sylvania 6313ce 13" TV/VCR. I am trying to program a rca remote for it so I can change the channel to 3 so the converter box will work, how do I do that
This particular TV may have the same code as a Magnavox,Emerson, Funai ,or Zenith. You will have to look in the remote control manual for these codes. This TV was put together by other manufacturers. And in many cases they program these to their origin! Thanks for asking and show a few hands of support!
Jan 11, 2011 | Sylvania 6313CE 13 in. TV/VCR Combo
Need Comcast DTA remote to control Panasonic TV/VCR combo
Try website 1-800-Remotes Factory original.To buy an exact remote or very close to the original.
Apr 25, 2010 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
I just got a dish installed and cannot program the remote control
What you can try:
- Check the DirecTV code set for the following brands:
Funai, Symphonic, Sylvania, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, and Misakai
Your set and the above-named are all built by Funai.
Even if you find one that works, it probably will not give you full functionality as would the original TV remote, which you can probably find at http:\\www.remotes.com
Before you buy any 'universal' remote, please don't expect it to absolutely work with your set; there is no such thing as a 'universal' remote.
If you find one that interests you, take the time to look up the mfr.'s website and check the code lists for your set.
Sep 04, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
TV Remote control
my remote control quite working - I have replaced batteries, but it still will not even turn on the tv.
Oct 12, 2008 | Toshiba MV13L3 13 in. TV/VCR Combo
Sansui COM3101A 13" Tv/VCR Combo Problem
You can try the codes for Orion, Emerson, and RCA. Call the number on the back of the set to see if the original remote is available.
Sep 28, 2008 | Sansui COM3101 13" TV/VCR
Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
Jan 14, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Funai F413TA 13" TV Logo
170 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
