Question about HP Compaq Pavilion dv5000z Notebook
HP DV5000 Speaker problems... Lag??
Okay... So my problem is kinda strange. Sometimes when i'm turning off the laptop the speakers sound all like crackly and laggy. I didnt think anything of it at first just that maybe cause i was turning it off without closing all the programs i was running causing the sound to lag out. But then recently I was on youtube and fail... It started to do the laggy thing but then it'd like stop and then do it again... So I was wondering if it's not the drivers maybe my sound card is failing? Any help would be awesome.
  • 408 Answers
It may be the speakers are going bad or you may need to update your sound card drivers.Try going to your setting for your sound and make sure the settings are correct.Make sure they are set for laptop stereo speakers with full hardware control.
Posted on Jul 28, 2009
How do I fix the internal speaker sound of HP 3380 MT?
The earphone connector may be defective and will have to be replaced.
Jan 19, 2016 | HP Computers & Internet
My sub make a strange noise. It doesen't work anymore.Tks.
Strange noises can come from your amplifier or the sub itself. The most likely cause of the strange noise is the speaker just before it dies! If you have been using the sub-woofer at high volume levels then you probably have damaged it. Try testing the sub-woofer using a multimeter(on ohms setting) it should give you a reading from 8 to 4 ohms. Sometimes they may give readings as low as 1 ohm. When testing the speaker/sub you should hear a soft scratchy, thumping or clicking sound. This indicates that the speaker may still be working. If you don't have a multimeter try a 1.5 volt battery (say a AA), DONT USE HIGHER VOLTAGE BATTERIES they may damage the speaker! You will hear a clicking, scratching etc sound from the speaker which may indicate that it is still OK. If the speaker seems OK the problem may be in the amplifier, which I suggest you bring to a professional repairer. When buying speakers and amplifiers make sure the power handling of the speaker is equal to or greater than the amplifier output power. This should stop speakers from getting damaged. Make sure the speaker and amplifier specifications are rated in the same manner ie RMS PMPO Peak. A 100 Watt PMPO speaker will not survive the output of a 100Watt RMS amplifier!
Feb 08, 2011 | Audio Players & Recorders
HP DV9000 SPEAKER PROBLEM
Try reinstalling the audio drivers. This site has them all
http://h10025.www1.hp.com/ewfrf/wc/softwareList?lc=en&dlc=en&cc=us&os=228&product=1842189
Happped on a cutomer's laptop once and reinstalling the driver worked.
Hope this helps
Sep 13, 2009 | HP Pavilion dv9000z Notebook
One speaker works all the time the others only sometimes
Could be intermittant wiring issue or the speaker itself.
If you have another spare car speaker you can hook up temporarily, I'd start there. Disconnect one of your "bad" speakers and hook up a known good one. If the temp. speaker works OK all the time, then you know you wiring is okay.
Let me know if more ?s!
Mar 22, 2009 | 1996 Chevrolet Cavalier
Left computer speaker is unpredictable
Take no offense but after 8 years, you got your moneys worth. Unless you're good with the soldering iron and schematics, call it a great investment and update your speaker system. I imagine your computer is newer than the speakers and you can take advantage of some 5.1 surround sound! It's really great if you do any gaming,too.
Since you'll probably be getting rid of them anyway, you might want to crack it open and see if there's any loose wiring that can be fixed.
Thanks for using Fixya.com. Please rate this tip accordingly. I wish there was a better solution but I usually get 5 years out of mine so I feel jealous. :-)
Jan 11, 2009 | Harman Kardon HK695 Computer Speakers
Internal speaker problem
connection frayed
um haard 2 fix if u want i can give u a step by step how 2 fix
just contact me at femi.amoo@gmail.com
Jul 17, 2008 | HP Pavilion dv6000z Notebook
LG 42PC5D Sound Lag
Turn the volume on the TV all the way down. Its becasuse you have the sound come from both sources. its kinda fun to play with.
Sep 24, 2007 | LG 42PC5D Television
HP Compaq Pavilion dv5000z Notebook Logo
160 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
