Question about Motorola Mobility RAZR V3
Cell phone won't ring but I can get it to vibrate
I can turn on the vibrate and that works but will not ring at all with the volume button all the way up
    Brigadier General:
  • 7,752 Answers
The speaker need to be replaced on the phone if that does not work then the ringer may need to be replaced on the phone.
Posted on Dec 26, 2008
My phone won't ring anymore model Huawei H868c
The volume keys are located at the right side of the phone. Press the top button to increase the volume. Hope that works.
Oct 07, 2015 | Huawei Cell Phones
Lg neon will not ring or vibrate
If you have made sure it's set to ring and/or vibrate and it's still not working, then turn off your phone and take out the battery. Put the battery back in and turn it on, then see if it works. This will probably fix the issue. If you haven't made sure it's set to ring/vibrate, you can do so by going to "Menu" > "Settings" > "Audio & Ringtones" > "Ringtone" > "Volume" and make sure the volume is up and not on silent. You can also quickly adjust this by the up and down arrow buttons on the side of your phone without having to go to the menu. I hope this helps :)
Apr 29, 2011 | LG Neon GT365 Cell Phone
Can the jitterbug ringer be turned off?
You can set your phone to Vibrate or silent mode so that the phone vibrates rather than rings. With the phone on and open, look at the inside screen while adjusting the ringer volume using the rubber volume button on the outside of the phone. As you adjust the volume, the inside screen will display the ringer volume level. It ranges from Max to Vibrate. Simply turn it down until the level reads Vibrate.
If you would like more step-by-step instructions, please call our Customer Service department at (800) 733-6632. We are available 24/7.
Feb 14, 2011 | One Touch Jitterbug One-Touch Cellular...
My iphone doesn't ring or vibrate, but does with earplugs on.
hey bro,
i fix more problem like your's. by change the flex up. with volume+vibrat button+headphone.
change this and all your problem will be good.
memeh Fixphone
Mar 29, 2010 | Apple iPhone 3G
I have a Samsung Smooth (U350)using Verizon. The alarm only icon is on and the phone does not ring when I have an incoming call. If I put it in vibrate mode, it does vibrate for an incoming call. How do...
To get the Phone to Ring - open the Phone and on the side there is the Volume Control buttons up and Down - press the Up button and than press the OK button to "set" the Volume to high.
I am not sure what you are trying to you with the alram - follow dirctions above and if it is not sloved let me know
hope this helps
thanks
Mar 19, 2010 | Samsung Smooth SCH-u350 Cell Phone
How do I get my from from vibrate to ring?
well there are two options.. 1. there might be a little side bar on your phone with an ^ arrow and a v arrow if you press the ^ arrow it could turn the ring on 2. if you press and hold the # button for around 10 seconds that will probably make it work.
hope i helped!
Jun 28, 2009 | Motorola Mobility TracFone w175 PayAsYouGo...
Cell Phone
There are two button on the left side that are for changing the volume. Up will go from mute to vibrate and then to the top volume and then down will go the other way.
Oct 21, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
BUTTON ON THE OUTSIDE TO TURN THE VOLUME DOWN
try a full facroty master reset, if still persists,
take it to someone who knows how to 'flash' it
Mar 12, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
162 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
